How to uninstall windows 8 - Computers & Internet
Xtra mail
Here's a great web page that tells you how to reinstall things that you have deleted from Windows 8: How to Restore Accidentally Uninstalled Built in Apps in Windows 8
Jun 19, 2014 | Computers & Internet
Tip
Removing IE 8
<p>If you have problems with Internet Explorer 8, you might want to try <a href="http://support.microsoft.com/kb/956197/LN/">Compatibility View</a> or our <a href="http://support.microsoft.com/gp/pc_ie_v8intro">guided help</a> <span> </span>to see whether you can fix the problem. However, if you just want to uninstall, or remove, Internet Explorer 8, this article helps you do that.<br /><br />When you remove Internet Explorer 8, your earlier version of Internet Explorer is restored with your customizations (such as add-ins, Favorites, and your home page).<br /> <p><b>Resolution:</b><br /> <p>To uninstall Internet Explorer 8, follow the instructions for your version of Windows. To follow these steps, you must be logged on to Windows as an administrator<br /> <p><b>Important:</b> You cannot uninstall Internet Explorer 8 if it is set as not removable. This occurs if you install Internet Explorer 8 before you install Service Pack 3 (SP3) for Windows XP. If this scenario applies to you, then you must uninstall SP3 before you can uninstall Internet Explorer 8. For more information about this issue, click the following article number to view the article in the Microsoft Knowledge Base: <br /> <p><a href="http://support.microsoft.com/kb/950719/">950719</a> You cannot uninstall Internet Explorer 7 or Internet Explorer 8 after you install Windows XP Service Pack 3<br /> <p>To uninstall Internet Explorer 8, follow the instructions for your version of Windows. To follow these steps, you must be logged on to Windows as an administrator. <br /> <p><b>Steps for Windows 7</b><br /> <p>To uninstall Internet Explorer 8, follow these steps: <br /> <p>1. Close all programs. <br />2. Click StartCollapse this imageExpand this image, and then click Control Panel.<br />3. Click Programs and Feature.<br />4. In the tasks pane, click Turn Windows features on or off.<br />5. In the list of windows features, clear the check box next to Internet Explorer 8.<br />6. You receive a warning message in a pop-up window. Click Yes.<br /> <p>Internet Explorer 8 will now be uninstalled. The system will restart after the installation. <br /> <p><b>Steps for Windows Vista or for Windows Server 2008</b><br /> <p> loadTOCNode(3, 'resolution'); To uninstall Internet Explorer 8, follow these steps: <br /> <ol> <li> Close all programs. <li> Click Start</b>, and then click Control Panel</b>. <li> Click Uninstall a Program</b> under the Programs</b> category <li> In the Tasks pane, click View installed updates</b>. <li> In the list of installed updates, double-click Windows Internet Explorer 8</b>. <br /><br /><b>Note:</b> If Windows Internet Explorer 8 does not appear in the list of installed updates, try the <span><b>alternative steps for Windows Vista or for Windows Server 2008</b></span>. <li> In the Uninstall an update</b> dialog box, click Yes</b>.<br /><br /><b>Note:</b> If you are prompted for an administrator password or for confirmation, type the password, or click Continue</b>. <li> Follow the instructions to uninstall Internet Explorer 8. <li> When the uninstall program is finished, restart your computer. </li></ol> <p><b>Steps for Windows XP or for Windows Server 2003</b><br /> <p> loadTOCNode(3, 'resolution'); To uninstall Internet Explorer 8, follow these steps: <br /> <ol> <li> Close all programs. <li> Click Start</b>, and then click Control Panel</b>. <li> Click Add or Remove Programs</b>. <li> In the list of currently installed programs, click Windows Internet Explorer 8</b>, and then click Remove</b>.<br /><br /><b>Note:</b> If Windows Internet Explorer 8 does not appear in the list of installed updates, try the <span><b>alternative steps for Windows XP or for Windows Server 2003</b></span>. <li> Follow the instructions to uninstall Internet Explorer 8. <li> When the uninstall program is finished, restart your computer. </li></ol> <p><b>Alternative steps</b><br /> <p><b>Alternative steps for Windows Vista or for Windows Server 2008</b><br /> <p> loadTOCNode(3, 'moreinformation'); To uninstall Internet Explorer 8, follow these steps: <br /> <ol> <li> <p>Carefully select and then copy the following command: <br /> <p><b>FORFILES /P %WINDIR%\servicing\Packages /M Microsoft-Windows-InternetExplorer-8*.mum /c "cmd /c echo Uninstalling package @fname && start /w pkgmgr /up:@fname /norestart"</b><br /> <li> Click Start</b>, and then type <span>Cmd.exe</span> in the Start Search</b> box. <li> In the list of programs, right-click Cmd.exe</b>, and then click Run as administrator</b>.<br /></li></ol> <li> Right-click inside the Administrator: Command Prompt window, and then click Paste</b> to paste the command that you copied in step 1. <li> Press ENTER to uninstall Internet Explorer 8. <li> When the uninstall program is finished, restart your computer.</li> <p><b>Alternative steps for Windows XP or for Windows Server 2003</b><br /> <p> loadTOCNode(3, 'moreinformation'); To uninstall Internet Explorer 8, follow these steps: <br /> <ol> <li> <p>Carefully select and then copy the following command: <br /> <p><b>%windir%\ie8\spuninst\spuninst.exe</b><br /> <li> Click Start</b>, and then click Run</b>. <li> In the <span>Open</span> box, type <span>Cmd.exe</span>, and then press ENTER. <li> Right-click inside the Cmd.exe</b> window, and then click Paste</b> to paste the command that you copied in step 1. <li> Press ENTER to uninstall Internet Explorer 8. <li> When the uninstall program is finished, restart your computer.</li> <li> <b>More Information:</b></li> <li> After you uninstall Internet Explorer 8, you may notice Application event log errors after each reboot. To resolve this problem, delete the following Internet Explorer User Accelerators and Internet Explorer Machine Accelerators registry keys in HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\GPExtensions: </li> <li> {7B849a69-220F-451E-B3FE-2CB811AF94AE} {CF7639F3-ABA2-41DB-97F2-81E2C5DBFC5D}</li> <li> <b>The information in this article applies to:</b></li> <li> Windows Internet Explorer 8</li></ol>
on Mar 15, 2011 | Computers & Internet
How do i uninstall knctr
Quickly and completely remove Knctr from your computer by downloading "Should I Remove It?", its 100% FREE
http://www.shouldiremoveit.com/download.aspx
This will remove Knctr from your computer.
Or, you can uninstall Knctr from your computer by using the Add/Remove Program feature in the Window's Control Panel.
  1. On the Start menu (for Windows 8, right-click the screen's bottom-left corner), click Control Panel, and then, underPrograms, do one of the following:
    • Windows Vista/7/8: Click Uninstall a Program.
    • Windows XP: Click Add or Remove Programs.
  2. When you find the program Knctr, click it, and then do one of the following:
    • Windows Vista/7/8: Click Uninstall.
    • Windows XP: Click the Remove or Change/Remove tab (to the right of the program).
  3. Follow the prompts. A progress bar shows you how long it will take to remove Knctr.
  4. If for some reason uninstallation fails, please install Microsoft's uninstall fixer utility which will help fix problems with programs that can't be uninstalled at support.microsoft.com.
Hopefully it works and solve your problem. Please rate, thank you. Sharing is caring. :)
Oct 24, 2013 | F-Secure Anti-virus Client Security...
I want to uninstall windows 8
uninstall windows 8
Uninstall Windows 8 using the Boot Option in msconfig.
1. Type msconfig in start search and hit Enter.
2. System Configuration box will open up. Navigate to the Boot Tab and select Windows Developer Preview. Next click on Delete.
3. Click on Apply button and then finally click on OK.
4. Now, you just have to format the partition where you had installed Windows 8 Developer Preview and then you can get your disk space back. To do so, Open Computer folder and right-click the drive on which it has been installed. Select Format.
http://www.youtube.com/watch?v=Kldwy7Il4HQ
youtube video uninstall windows 8 preview
hope this helps
Sep 24, 2012 | Microsoft Internet Explorer 8
I want to know on how to uninstall IE8 on my computer i am running a windows XP service pack 3. I just want to install a fresh copy of IE8 . . . . .
Hi josephc_agni,
  2. Click Start, and then click Control Panel.
  3. Click Add or Remove Programs.
  4. In the list of currently installed programs, click Windows Internet Explorer 8, and then click Remove.
    NOTE: If Windows Internet Explorer 8 does not appear in the list of installed updates, try the alternative step given below.
  5. Follow the instructions to uninstall Internet Explorer 8.
  6. When the uninstall program is finished, restart your computer.
ALTERNATIVE STEP:
  1. Carefully select and then copy the following command: %windir%\ie8\spuninst\spuninst.exe
  2. Click Start, and then click Run.
  3. In the Open box, type Cmd.exe, and then press ENTER.
  4. Right-click inside the Cmd.exe window, and then click Paste to paste the command that you copied in step 1.
  5. Press ENTER to uninstall Internet Explorer 8.
Dec 05, 2010 | Microsoft Internet Explorer 8
I have lost the use of internet explorer - I get a run time error. I have tried to download from their website but my system says there is a newer version already loaded so it won't load the one I down...
Steps for Windows 7To uninstall Internet Explorer 8, follow these steps:
  2. Click Start vistastartbutton.jpg, and then click Control Panel.
  3. Under Programs, click Uninstall a program.
if that fails then there is a manual way to do this using the CMD prompt...
  1. Carefully select and then copy the following command: FORFILES /P %WINDIR%servicingPackages /M Microsoft-Windows-InternetExplorer-8*.mum /c "cmd /c echo Uninstalling package @fname && start /w pkgmgr /up:@fname /norestart"
  2. Click Start, and then type Cmd.exe in the Start Search box.
  3. In the list of programs, right-click Cmd.exe, and then click Run as administrator.
    Note If you are prompted for an administrator password or for confirmation, type the password, or click Continue.
  4. Right-click inside the Administrator: Command Prompt window, and then click Paste to paste the command that you copied in step 1.
Jul 30, 2010 | Dell Inspiron 1720 17" Widescreen...
Explorer 8 removal
Steps for Windows 7 loadTOCNode(3, 'resolution'); To uninstall Internet Explorer 8, follow these steps:
  2. Click Start Collapse this image Expand this imagevistastartbutton.jpg, and then click Control Panel.
Steps for Windows XP or for Windows Server 2003 loadTOCNode(3, 'resolution'); To uninstall Internet Explorer 8, follow these steps:
    Note If Windows Internet Explorer 8 does not appear in the list of installed updates, try the alternative steps for Windows XP or for Windows Server 2003.
Please rate the answer. Thank you!
Apr 27, 2010 | Microsoft Internet Explorer 8
Ever since upgrading to Internet Explorer 8, I find that I cannot print emails, open up many attachments, and retrieve other information. For example, if I click on a link, I get the following message:...
Ther are known conflicts with Vista and IE8 - particularly with Vista 64-bit.
I would suggest uninstalling IE8 and reinstalling IE7 or using an alternative browser such as "slimbrowser" (excellent program) or similar.
IE8 can be uninstall by using Add or Remove Programs module in Windows XP, but in Windows Vista, Windows Internet Explorer 8 is not considered to be a ‘program’. Instead, IE8 is categorizing as an ‘update’. Thus, users will not be able to find Windows Internet Explorer 8 in “Programs and Features” of Windows Vista.
To uninstall Internet Explorer 8, go to Control Panel, and click on Uninstall Programs link or Programs and Features icon. Then on Tasks pane on the left, click on View installed updates link. Locate and select Windows Internet Explorer 8 in the list of installed updates, and then click on Uninstall button. Click on Yes when asked that are you sure want to uninstall the update.
If there is no option of IE8 been found on “Programs and Features” or “Add or Remove Programs” dialog box, or uninstallation of Internet Explorer 8 is unclean (causing error message such as setup cannot continue because a more recent version of Internet Explorer has been detected on this computer when trying to downgrade to IE7), try to manually run the spuninst.exe.
To do so, go to C:\WINDOWS\ie8\spuninst\ folder (your drive letter may be different), and run spuninst.exe.
Restart the computer after uninstallation completed.
Hope that helps :)
Nov 09, 2009 | Dell Studio XPS 435 PC Desktop
I have the vista system and IE dosent show up in add remove files, I have downloaded firefox. How would I go on to uninstall IE? PS. venexcsd Said it was posible and it depended on the above information,...
Hello.
Welcome to Fixya.
If you want to knw how To Uninstall Internet Explorer 8 on Windows Vista Follow these steps: loadTOCNode(3, 'resolution'
  3. Click Uninstall a Program under the Programs category
  4. In the Tasks pane, click View installed updates.
  5. In the list of installed updates, double-click Windows Internet Explorer 8.
  6. In the Uninstall an update dialog box, click Yes.
7. Follow the instructions to uninstall Internet Explorer 8.
8 . When the uninstall program is finished, restart your computer.
Good Luck^^
Nov 02, 2009 | Acer Aspire 5920-6727 Notebook
Computers & Internet Logo
124 people viewed this question
David Payne
David Payne
