Question about Car Audio & Video
How to remove monsoon Amplifier from a 2000 VW passat?
How do you get to the screws? This is impossible
    Problem Solver:
  • 11 Answers
The whole top should come off!!
Posted on Jul 30, 2009
My 2000 VW passat 1.8 wont start. when i push the clutch and turn the key it makes a clicking sound, what does that mean?
flat battery or bad batt terminal connection .........its the starter relay clicking .........check all earth wires re attached properly from removing head
Sep 03, 2014 | 1998-2005 VOLKWAGEN VW PASSAT LOWER CHROME...
Where is the 6 disc changer in this 2001 vw passat?
In the trunk left side near rear tail light access. you will find a door, first aid storage is near same location.
Jan 29, 2010 | Level 9 Sound Designs Monsoon Planar Media...
2003 vw monsoon stereo control my ipod?
there are adaptors that go between antenna and radio that ipods will disrupt the signal and work that way
Jul 21, 2009 | 2003 Volkswagen Passat
Removing 2000 VW passat door panels for speaker install.
The door panel comes off With a T-10 torx or a Hex (Allen) wrench
that will fit and A large Philips Screw Driver..
Remove the Plastic cover on the inside Door handle.
And the Screw or Screw along the Bottom of the door panel.
Then remove the screws that hold the handle the the door.
They are located behind the Plastic plate you removed with a tiny screw driver earlier... Be careful not the mark up the cover whaytprying it up. It is best to pry from underneath. Where marks if made can not be seen
After the screws are out 4 I believe. The Use of a CLip tool ir best.
For getting behind the panel to pop it off. A screw driver will work.
After all the clips are released. Pull the light at the bottom of the panel down and out. Disconnect it ur push it back thought the hole it came from..
reverse to install
SKETCHLAB.com
Apr 23, 2009 | 2000 Volkswagen Passat 4Motion
Hello, I have a 2000 VW passat with a Monsoon radio system. How do you install a new head unit and speakers while maintaining the factory amp? If this is impossible, Can I use the current speaker wires...
Hello ctr1russo,
While it's not impossible to install a new head unit and speakers and leave the factory amp, it'll be a real bear of an install.
In order to work, the Monsoon amp needs 6v which is provided on the speaker leads. An aftermarket head unit will not provide that. Best to just install a new amp.
You should be able to use the wiring, including the speaker wiring, with no problems.
Check out www.bestkits.com for the appropriate adapters and wiring harness for Monsoon equipped vehicles. Just enter your vehicle info and it should bring up the required adapters and harnesses to make everything work properly.
There are three ways to connect more than one speaker to a single channel: 1) Parallel - both speaker +'s and -'s wired together - load impedance will be halved (2 4-ohm speakers in parallel equal a 2-ohm load). 2) Series - The + of one speaker wired to the - on the other speaker and the remaining + and - going to the channel output - load impedance will be doubled (2 4-ohm speakers wired in series equal an 8-ohm load). 3) Using a crossover - connect the bass speaker (woofer) and the input of a high-pass filter directly to the channel output and the treble (tweeter) speaker to the output side of the filter. In any of these connections, you want to make sure that the load (ohms) your amp "sees" is not less than it is rated for. Most amps will work into a 4-ohm or a 2-ohm load with no problems. Going below 2-ohms is bad, because it will cause the amp to overheat and possible fail. Going above 4-ohms is no problem for the amp, but it won't produce as much power (watts) at the higher impedance and your speakers will not be as loud as they could be.
Hope this helps. If it does, please rate as "FixYa:. Thanks!
Apr 21, 2009 | Car Audio & Video
2000 VW passat maf
I would trust them but make sure it is just not in need of some kind of cleaning.
Nov 19, 2008 | 2000 Volkswagen Passat 4Motion
Car Audio & Video Logo
681 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
