Question about Gaggia Titanium Espresso Machine
Gaggia titanium no steam
No steam for frothing
ginko
  • 19396 Answers
SOURCE: Gaggia Titanium: stuck on 'rinse'.
Try first unplugging power cable for five minutes, see if this reset machine.
Posted on Aug 20, 2008
  • 109 Answers
SOURCE: titanium ventilate issues
Remove the milk frother,checked to see if it is blocked.
This can cause the machine not to ventilate correctly.
They tend to block with old hard milk.
Posted on Aug 26, 2008
EsWorld
  • 1618 Answers
SOURCE: Gaggia Titanium, makes hot water but no steam
Push in on the steam knob, if that works, then the steam valve assembly needs to be replaced, tell the Tech where you bought the machine that you need to get the new stainless steel valve.
Posted on Jun 19, 2009
SOURCE: gaggia titanium is leaking water
Mine had the same problem. Take out the dreg drawer and brew unit. Then you will see a plastic cover roughly in the middle of the machine (behind where the brew unit was) that is held in place by two philips screws. Unscrew the screws and take out that small cover. It is probably filled with coffee grounds that prevent water from dripping out through a dripping hole. Clean out the grounds and you should be all set.
Gerwin Schalk Albany, NY
Posted on Aug 14, 2009
EsWorld
  • 1618 Answers
SOURCE: my Gaggia Titanium machine says ventilate
Run about an ounce of hot water from the wand.
Posted on Nov 12, 2009
Gaggia titanium
A nice coffee maker. So, please could you tell us what is your question?
Maybe some operating instruccions?
Check support library:
Or do you want to repair something?
Gaggia TITANIUM Espresso Machine Operating Instructions Manual
GAGGIA
Gaggia Titanium Super Automatic Espresso Machine
Cleaning Gaggia Titanium Espresso Machine Gaggia Titanium Steam Valve Replacement
Aug 03, 2015 | Gaggia Titanium Espresso Machine
My Gaggia classic has suddenly stopped frothing
Hi There,
You are not getting enough steam, to produce the froth and there no blockage. I suggest you replace the thermostats. Takes 10 min max.. Gaggia thermostat set
Sep 28, 2017 | Gaggia Classic Espresso Machine
Hi My gaggia titanium is not frothing milk correctly. I've descents but that has still not solved the problem It's sounds like it's spitting Thanks
Try this remove the parnello wand and open the valve if you get a nice burst of steam then the problem is in the parnello wand, if you get the same spitting, then there is something in the valve or the steam boiler that is preventing the proper flow of steam.
Jan 02, 2011 | Gaggia Titanium Espresso Machine
The steam wand is bubbling the milk, not frothing
THere is a little black tube inside - make sure its pushed out enough - about 1/16 an inch from the bottom. And you may have to clean it out. Happens to us too and after I do the above it works
Feb 13, 2010 | Gaggia Titanium Espresso Machine
Hot water doesn't have enough pressure to froth the milk. descaled but still no froth! Thank you
If you have no steam then it is possible that the steam booster boiler is damaged, or the thermostat tripped.
Jan 11, 2010 | Gaggia Titanium Espresso Machine
Gaggia titanium machine, is Ventilate problem connected to leak??
the steam valve is most likly plugged with sacale or such have you decaled the machine latly may want to start there
Dec 17, 2009 | Gaggia Titanium Espresso Machine
Jun 18, 2009 | Gaggia Titanium Espresso Machine
Losing steam
Try to descale the machine to see if will be better.
Aug 13, 2008 | Gaggia Classic Espresso Machine
Gaggia Coffee
Hello, I have been experienceing the same problem since I bought this thing. I used to have the classic Gaggia until it died after 15 years. however, when I went to this one it just didn't function the same.I was having water leaks come from the group assy so I replaced the group valve assy which I saw a diffrence and it functioned properly for a few days, then It was acting up again. No steam to froth and water bypassing the group assy... I then removed the valve assy again and saw it was somewhat clogged of mineral deposits.I cleaned it and after a few days once again it wasn't frothing as it should. Yesterday I completely tore this thing apart but couldn't figure out how to remove the steam valve assy. Does anyone have any ideas?? I removed the 2 screws and it won't move. OH BEFORE I FORGET!!! It was working fine the other day and while I was in the middle of frothing, it suddenly went to half pressure.... ANY IDEAS?? Thank you in advance....
Apr 09, 2007 | Gaggia Coffee In White, White MDF...
Open Questions:
See all Gaggia Titanium Espresso Machine Questions
Gaggia Titanium Espresso Machine Logo
24 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
