Question about Garden
John Deere m series clutch change,pressure plate,throwing bearing,how to split tractor apart
Have a bad clutch and pressure plate on a john Deere m series tractor.need a schematic on this and how to split tractor
  • 11 Answers
SOURCE: john deere 2010 tractor. pto grinds and wont engage
The PTO usually has a clutch that has to be engaged so that you can select the PTO rotation setting. I had a problem like that on my tractor and all it needed was a little adjustment on the PTO clutch lever, so it could disengage the PTO gearbox properly.
Posted on Mar 11, 2009
blueextc3221
  • 15935 Answers
SOURCE: system creeps down even when tractor is operating.
There are 2 potential problems -
1. Leaking spool on the control valve - rebuild the vale.
2. Cylinder blow-by. Disassemble piston and replace the seals.
To test if its the cylinder - retract the cylinders all the way... remove the hoses on the blind end (non rod end) of each cylinder, and again pull the valve to the retract position.
If fluid continues to pour out of the cylinder - the piston seal is damaged, and the affected cylinder must be repaired.
To test if the valve spool is faulty - disconnect the a and b ports just after the valve. Turn on the system and check for seepage from the disconnected lines (without moving the lever).
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on Apr 19, 2009
SOURCE: gas tamk removal john deere 115
I had the same thing happen. I got the tank out, but it wasn't easy. Take out the bolts out that hold the rear end on. Take off the two springs that support the seat. Take out the battery and the battery tray. Take out the 6 bolts that hold the black cowling and the front of the green platform to the frame. This will allow you to lift the seat platform far enough off the rear end to allow the tank to be pulled out through the side. You also have to remove the metal bracket which holds the front of the tank and has caused the tank to leak in the first place. New tank is $56.00 not installed. I used a soldering gun and melted the plastic back together. I think it will hold quit a while. I know this is a little sketchy, but It worked for me.
Posted on Jun 02, 2009
  • 548 Answers
SOURCE: can't get front wheel off my john deere lawn tractor
remove the cap on wheel then there is a ring or cotter pin to remove then pull wheel off
Posted on Aug 22, 2009
SOURCE: Belt change on a hydrostatic 265 John Deere
Instructions for changing main drive belt on John Deere model 265
HELP !!!!!!!!!!!!!!!!!!
Posted on Aug 28, 2009
Engine runs, tractor won't move
Pressure plate and throw out bearing bad. Get a matching connector for the alternator and splice it in. The engine is going to need to be removed. I would also check the input shaft to the transmission. Tractors a god at breaking shafts.
Feb 08, 2014 | John Deere Starter Tractor Lx188 Kawasaki...
John deere 2010 gear shifter hung up in neutral
Check clutch linkage to see of anything is binding up. If there is a bad bushing it could throw the alignment out.
Oct 10, 2013 | John Deere Garden
I have an '04 john Deere 737 ztrak mower and when
check for a spindle seizing from rust and failed bearings.
Jun 15, 2013 | Garden
John deere 240 brand new electric clutch. went I throw the swtich it clicks but doesn't engage....
Adjust the clearance between the plates,9/16 wrench and turn the three nuts on the clutch one at a time about 1/4 turn each,retry the clutch,repeat until it works normally.
Jan 08, 2010 | Oregon Scientific Electric PTO Clutch for...
What makes my 1992 525i pop out of gear?
you crank is broke and you mite of grinded the gear
Jan 05, 2010 | 1992 BMW 5 Series
My 870 john deere clutch will not disengage. The
This is common for the 70 series.Clutch dics are stuck together,just short of splitting tractor you have to hit a pile of dirt with loader bucket to see if you can break it loose.
Sep 25, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Farmal C won't go in gear while running, grinds
I have one that has the same problem,I split tractor to repace rear main clutch an preasure plate,my throw out bearing was bad and the shaft was rusted and would not let the throw bearing go all the way in to the preasure plate
Jun 24, 2009 | Farmall Tractor C ,super Av, Complete...
John deere 2010 tractor. pto grinds and wont engage
Mar 11, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
15 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
