Question about Exercise & Fitness
Treadmill error code
What does E0 means
ercupa190
  • 12223 Answers
SOURCE: Treadmill GK1305FI showing E0 error on startup
Dear Sir:
This is probably a faulty speed sensor or the speed sensor is not plugged in properly. Its also possibly a faulty motor control board or lower board. The error codes will differ between makes and models but could be e1.
Use too the calibration software see under The Hood Motor instructions or use the user manuals.
sincerey. God bless you.
ernesto cuadra
managua, nicaragua. c.a.
Posted on Feb 15, 2012
ercupa190
  • 12223 Answers
SOURCE: maxpro vibelife V815 treadmill error
go for free download: www. fitness.manualsonline. com or www. iconservice. com.
Test every connector and tight very well, see the fuse inside, see the diagram attached for reed swithc and speed sensor, clean and tight the connector very well.
run the software calibration for diagnose and troubleshooting.
Posted on May 03, 2012
ercupa190
  • 12223 Answers
SOURCE: TS1305FI showing E0 error
Dear Sir:
This error can be fixed. 1) Adjust the speed sensor, clean, and tight the wire connector, very well, see the diagram attache.
2) Test the input voltage motor, if there are voltage the motor need repair.
3) Test the output voltage from motor board, if there are NOT, the board is faulty.
However RUN the software calibration for diagnose, and troubleshooting, and fix it.
sincerely. God bless you.
Posted on May 06, 2012
stevebuck453
  • 4 Answers
SOURCE: I have a Tunturi j770 treadmill with error code E1...
Buckmanservices.com solved the E1 code issue only $30 fixed it from online told me what to do
Posted on Jun 13, 2012
ercupa190
  • 12223 Answers
SOURCE: what does an E3 error code mean on my vitesse endurance xt treadmill
"E03': No sensor signal. Sensor wire is faulty, replace the sensor wire. Magnetic sensor wire is not working replace see the diagram attached.However clean it. and tight the connector very well.God bless you
Posted on Apr 04, 2013
Error code message
What Does Your Treadmill's Error Code Mean? - LifeSpan
www.lifespanfitness.com/.../what-does-your-treadmills-error-code-mean
Free
May 21, 2015 - If the running belt stops after 6 seconds of starting the treadmill, this may indicate that either the ... If there is no belt movement, or you notice a burning smell coming from the motor area, this ... An E6 or E7 error code is an incline error code. ... This will cause the incline motor to raise the running deck up.
[PDF]ERROR CODES: ADDITIONAL ERROR CODES:
www.gympart.com/TSB/.../Treadmills/.../Sportsart%20Error%20Codes.p...
ERROR 6: INCLINE ERROR - CHECK INCLINE OPERATION AND CALIBRATION. ERROR ... ERROR 1-1: AC SERVO ERROR - AC SERVO MOTOR ENCODER HAS FAILED ... error codes listed by category: treadmills, bikes, elliptical trainers. ...ERR1 Condition 1: Press speed key; walk belt doesn't move; ERR1 appears.
[PDF]Error Code Troubleshooting Guide
Jan 19, 2016 | Exercise & Fitness
What does the trouble code 70 h95 mean
What does the trouble code 70 h95 mean - Fixya
www.fixya.com/support/t25932829-trouble_code_70_h95_mean
28 mins ago - what does the trouble code 70 h95 mean - Bowflex Treadmills question.
Free
May 21, 2015 - Please refer to the following table if your LifeSpan treadmill is displaying an error code. If after trying the suggested solutions your treadmill is .
Oct 30, 2015 | Bowflex Exercise & Fitness
Error E0 motorized treadmill ts5202fi
Usually this means a problem with the safety key area.
Dec 03, 2013 | Exercise & Fitness
Error code E0
1) adjust the speed sensor see the diagram attached. tight the cable, and clean it.
2)test the input voltage motor, if there are the motor need repair.
3)test the output voltage from the motor controller, for input voltage motor if there are NOT the motor controller need replace.
God bless you
Nov 08, 2012 | Sportcraft Tx2.5 Tx 2.5 Treadmill Motor...
Dear Sir:
May 06, 2012 | Exercise & Fitness
Maxpro vibelife V815 treadmill error
Apr 29, 2012 | Exercise & Fitness
Dear Sir:
ernesto cuadra
Feb 13, 2012 | Exercise & Fitness
Just got error code "fe02"
The F2-E0 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F2-E0 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced . GENE
Sep 18, 2011 | KitchenAid Ovens
My RBS275 oven has E0 F2 error code
F2-E0 - Shorted Touch Pad (Keypad) - Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
Select the 'cancel' function and wait 60 seconds.
If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!#!#
Aug 16, 2009 | Whirlpool RBS275PD Electric Single Oven
Exercise & Fitness Logo
79 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
