Question about Sony Handycam DCR-DVD7 DVD Camcorder
No picture on screen
My screen is black when recording cannot see a pitcure
Sony dcr-hc17E display not working
I have a sony dcr-hc17E camcorder and my display is gone black... All of the funkcions on touch screen work,but there is no pitcure,no video,no nothing...
Nov 25, 2009 | Sony Cameras
I cant take pictures
on the top of camera it should have a mode for pitcures or video or viewing..click untill you see pitcure point and click
Apr 26, 2009 | Cameras
My power shot A60 has a white screen and wont take pitcures.
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Jan 21, 2009 | Canon PowerShot A530 Digital Camera
Canon SD 550-- sensor problem? Bought 3/2006 and have had no problems. Suddenly, LED screen went black--shows nothing and cannot take a picture altho will flash and record black picture. Shooting...
The shutter of the camera is not opening that is why every picture taken is recorded black. It is a mechanical problem and probably has nothing to do with the sensor. Not very expensive
Aug 30, 2008 | Canon Cameras
LOST PITCURES
The pictures may be in a subfolder, but they should still show up while you are in playback mode.
If the images are erased, don't take anymore with the camera and download free software recovery program from www.Z-A-recovery.com I hear that it works well.
You will need a card reader to try to recover your images...assuming they are lost. Even if they are not lost, a card reader may help them show up for you.
May 29, 2008 | Canon PowerShot A530 Digital Camera
43H70 picture wobbling
possibly leaky cap in power supply,look for a 1000mfd/16v cap in on near the b+ supply and also cold solder connections.
Aug 06, 2007 | Toshiba 43H70 43" Rear Projection...
No pitcure
It sounds like your shutter has become stuck closed. Normally the shutter stays open while you compose the pictures and then closes when you hit the button to take the picture allowing the image sensor to record what it saw at that moment. If it stays closed you will not see any image at all, but the normal icons and text on your camera's display will still show. The same symptoms can also be caused by a failed image sensor, although this is less common. Freeing a stuck shutter requires disassembly of the camera and lens assembly. Check with your manufacturer for recalls and/or warranty support. If they cannot help you for free there are repair providers online who can work on your camera. David Millier Advance Camera Repair
Mar 20, 2007 | Canon PowerShot S2 IS Digital Camera
Black bars in the picture
For Models: CC4352, CC4362, CC4393. Your camcorder has a wide format recording mode that lets you make recordings compatible with the 16x9 format. When 16x9 is activated, the camcorder records black bars at the top and bottom of the picture to produce the wide-screen (movie) effect. This is also known as "letterbox" recording. Do not use this mode unless you have a compatible 16x9 TV. When played on a regular TV, black bars appear on the screen. If the 16x9 feature is activated on your camcorder and you want to turn it off, press REC/PAUSE to pause recording, and repeatedly press DIGITAL EFFECTS until no digital effects display appears.
Sep 06, 2005 | RCA CC-432 Camcorder
Sony Handycam DCR-DVD7 DVD Camcorder Logo
71 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
