Question about Bernina Artista 180
Bernina artista it is skipping stitches on the straight stitch
    Novelist:
  • 268 Answers
Probably needs a new needle, a bigger needle, a needle right way around and fully up in the clamp. Or the bobbin is in wrong way around. Way, way down on the index of suspicion is a machine that's out of time.
Posted on May 25, 2014
SOURCE: stitch is not straight
When was the last time your machine had a routine cleaning and adjustment? It sounds as though you've got "play" in the mechanism that needs to be tightened by a sewing machine mechanic.
Posted on Jun 07, 2009
RickE1
  • 202 Answers
SOURCE: BSR skips stitches
Hi, I am a Bernina tech and can tell you what the problem is. The problem is that the spring on your BSR is weak. Bernina has an upgrade to adding a heavier spring that solves this problem. The older lighter springs on the BSR is shiny. The newer heavier updated spring is dark. Ask your dealer/tech to change this spring to a new one or give you a newer updated BSR. Also be sure they updated the BSR to the latest firmware.
Rick
Posted on Oct 08, 2009
Testimonial: "Thanks, this was very helpful!"
  • 980 Answers
SOURCE: My Bernina 830 Sewing Machine is not sewing the
If you are selecting patterns but only getting a straight stitch after making sure you have set the width, there may be a chance that the pattern camstack has split and the selector finger is stuck in the split, more common than people think,
take the top off the machine and check
Posted on Oct 24, 2009
SOURCE: my bernina 717 intermittently skips stitches - how
I had the same problem : the seller told be to change the needle. When the needle has been used too long, stitches are "skipped".
Good luck
Posted on Nov 13, 2009
SOURCE: bernina 1130 feed dogs won't feed fabric
On a Bernina 1130 the power on-off knob and the feed dog raise and lower knob look similar and are next to each other on the end of the machine, making it easy to lower the dog assembly entirely, without realizing it. Make sure you didn't accidentally lower the entire feed dog assembly by turning the feed dog knob: you can tell as you turn it if the dogs are up or down. On the Bernina 1130 the knob, like the power should be in the horizontal position to be working both feed and power.
Posted on Aug 11, 2012
Bernina artista 200, how do i control the feed dogs?
Not sure what you are asking. The stitch length will determine how far the feed dogs travel (thus pulling the fabric) to create each stitch. There is also the foot (or knee) control that determines the speed that the machine runs.
The page 21 of the manual has that information:
https://www.bernina.com/en-US/Support-US/Machines/BERNINA-artista/BERNINA-artista-200
Apr 18, 2017 | Bernina Sewing Machines
Why is the bernina artista skipping stitches on the straight stitch
could be for varied reasons, 1). top tension too tight. 2). needle not ruined. 3). crochet ruined, or out of timeing.- check tension, check that needle is good, and see if the timeing is out.
Jan 01, 2014 | Sewing Machines
Bottom stitching is loose
try adjusting the top thread tension one number or letter at a time
forwards till the stitch look normal
here is 2 link for a manual
http://www.sewingpartsonline.com/instruction-manual-bernina-artista-170-and-180.aspx
http://www.sewingpartsonline.com/manuals/Bernina/170,%20180%20(Artista).pdf
Aug 22, 2012 | Bernina Artista 180
My bernina sewing machine won't do zig zag stitch on one side. when i sew only one half of the sitch works.
Sounds like its skipping stitches. The very first thing to do is put in a new needle. A dull needle will cause this for sure.
After that it may take a tech to make some adjustments.
1) The hook is slightly out of time. On this type mechanism, there is
a slight difference in timing for the different needle positions.
2) The needle bar is slightly too high.
3) The hook and needle are too far apart, and then the skipping would
be more apt to show up on light weight fabrics.
Apr 16, 2008 | Bernina Artista 180
Sewing Machines Logo
60 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
