Question about Dualit Vario 2 Slices Toaster
Dualit 20293 uneven toasting
I am not sure of the new Dualit toaster I recently purchased is working properly. The outside heating elements would toast at a much faster rate than the center heating element, resulting in a toast that is MUCH darker on one side than the other. I have preheated the toaster as instructed and it has not improved the performance. In fact, I purchased an entire loaf of bread to "season" the toaster and it still produces half toasted bread.
Is this normal? Will this situation improve with use?
1978 ge toaster
Their website claims that the ProHeat elements fit toasters made in the last 50 years...
I would say take the thing to a good electrician, and she can inspect one of the ones that still works, compare it to the one that burnt out, and come up with some sort of fix...
Nov 19, 2013 | Dualit Kitchen Appliances - Others
RH end element was not heating to same temperature as middle element. Bought and fitted new end element but still same problem ie this new element still not heating to correct temperature high causing...
the new version has a plastic cover over element wires its best just to change all elements to solve this if you have had this toaster a wile the old elements dont have it,,,make sure its correct ones fitted as they are all different watts ..
Feb 23, 2011 | Dualit Vario Combi 2+1 65-Slice Toaster
The timer stops, the toaster keeps toasting, burning the toast.
The timer is also a electrical contact switch. When the timer goes to zero an internal spring force the electrical contact to open so the heating elements to stop heating.
So either the spring stuck so it can not open the contacts anymore or the electrical contacts have been stuck together by elctrical sparking during the on and off.
In any case you must replace the timer switch with a new one since they does not worth to anything else with it.
The operation does not need any profetional skills since it can be remove easyly by removing the bottom panel and be carefull to remove the wires conected to it with clips make some notes so you will put the wires in the same position of the new timer switch.
If you don't fill comfortable with above then let an electrician do it for you.
Good Luck
Apr 01, 2010 | Dualit Vario 20293 2-Slice Toaster
The toast gets done on one side and not the other
No way to replace it your Dualit toaster is a toaster for life you just need to replace some element plates and this is normal every some years. My Dualit toaster is 18 years old I have replace a couple of times the element but is always working perfect and with st. steel finish look perfectly new and impresive.
Inside your toaster there are eight heating element plates six in the center and one in left end and one in right end.
Just switch on the toaster without any bread at maximum time and visualy inspect to see which side is becoming red and which not. Then you need to replace the element plates you see that they don't become red.
Remember that the two in center are the same called "CENTER" and the other two on ends are the same called "END"
They can easily be removed if you remove the bottom panel.
Good Luck
Jul 12, 2009 | Dualit CTS4E 4-Slice Toaster
The heating element doesn't work in two of the slots.
If its a Dualit model then you should be able to get it repaired. Generally replacing parts on a Dualit is not easy but spares are usually available thanks to the fact that its one of the most well known commercial toasters on the market. Google and see if there's a repairer in your area.
Apr 05, 2009 | Dualit CTS4E 4-Slice Toaster
Dualit Toaster won't heat on either side.
You may have awire that has burned off or the control switch is bad. You can get to their site by typing in "dualit" under google and you will get a lot of information and the web site.
Feb 06, 2009 | Dualit 20247 2-Slice Toaster
Problems with Dualit 20247 2-Slice Toaster one of the elements is out. Both sides of one toast is good, the other heats up only one side, as the element on the right is dead. Where can i send this, as i...
It is probably not under warranty. I would advise getting a new one. By the time you send it off and pay the repair and get it back, you will have a repaired toaster will a question mark on when it will go down again. Get a new one same brand.
Dec 30, 2008 | Dualit 20247 2-Slice Toaster
Need replacement dualit 2 slice toaster elements
You can get any part you need at the Dualit Repair Center:
Electra-Craft
41 Woodbine St
Bergenfield NJ 07621
phone 201-439-1700
fax 201-439-1701
info@electra-craft.com
www.electra-craft.com
Jan 22, 2008 | Dualit 20247 2-Slice Toaster
Dualit Vario 2 Slices Toaster Logo
95 people viewed this question
Top Dualit Kitchen Appliances - Others Experts
Herve Boissonnault
Herve Boissonnault
Mack Baxter
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Dualit Kitchen Appliances - Other Expert? Answer questions, earn points and help others
