Question about Microwave Ovens
Defrost instructions I have an 11 lb. ham to thaw - how is the quickest way to defrost?
Why does the auto defrost turn on and off intermittently
Cycling automatic defrost makes thawing a gradual process that prevents pre-cooking.
Jan 20, 2015 | Microwave Ovens
How do i deforst chicken breast
Put in ziplock bag. Submerge in cold water for about 1hour.
Dec 03, 2012 | Microwave Ovens
Freezer temp flux's, items thaw and ice melts. I replaced the defrost heater and the thermostat. Now the freezed cools to 16 deg and now it is up to 29 deg. What should I look at next?
The defrost circuit is made up of the defrost heater, defrost thermostat and the timer. If the timer is keeping it on for too long then it could duplicate your symptoms.
BUT also make sure that the condenser grill (underneath your unit) is clean and air flow is good from front to back of the unit.
Jul 20, 2011 | Microwave Ovens
On our new microwave there is 2 buttons for defrost. what is the difference? it does not mention defrost in the booklet we got with the unit.the mdl.# is GMH5205XVB
Using the Auto Defrost feature on my microwave oven
How do I use the Auto Defrost feature on my microwave oven?
To use the Auto Defrost feature on your microwave oven, please do the following:
  1. Unwrap food, place on the turntable, and close the door.
  2. Touch Defrost.
  3. Select food by entering 1 for Meat, 2 for Poultry or 3 for Fish, or touch Defrost repeatedly to scroll through the food selections.
  4. Enter the weight in pounds:
    Meats and Poultry can be set from 0.2 to 6.6 lb (90 g to 3 kg).
    Fish can be set from 0.2 to 4.4 lb (90 g to 2 kg).
    Doneness may be adjusted at this time by touching Cook Time.
  5. Touch Start. The display will count down the defrost time. When the cycle ends, "End" will appear in the display, and the end-of-cycle tones will sound, followed by reminder tones.
  6. Touch Cancel Off or open the door to clear the display and/or stop reminder tones.
The Defrost system has 3 categories: Meat, Poultry and Fish. It should not be used for food left outside the freezer more than 20 minutes and frozen ready-made food. Use the following chart as a guide.
Here is your owners manual:
http://www.whirlpool.com/assets/pdfs/product/ZUSECARE/GMH5205XVQ_Use%20and%20Care_EN.pdf
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 05, 2011 | Whirlpool Microwave Ovens
How to defrost frozen ground beef with sharp carrossel microvawe oven?
The defrost instructions for ground beef are listed on page 15 of the owner's manual under the "Defrost Center" heading. If you do not have an owner's manual, here is a direct link to one that you can download or print for FREE:
http://www.managemylife.com/mmh/owner_manuals/71305/Sharp-Microwave-Oven-mic_man_R510H?brand_name_search=R-510
Remember to remove any thawed pieces of beef with each stage of defrosting for the best results. If you have any questions, please post back and let me know. I hope this helps you.
May 05, 2011 | Sharp R-510HW Microwave Oven
How do you use auto defrost
Auto defrost is rather clever. There is a sensor that detects moisture evaporating from the defrosting food. I won't go into the equasions used to work out the optimum point at which the food is defrosting, it suffices to say that when the moisture content in the exhaust air reaches a predetermined point, it is thawed out. If it reaches a higher point, for baked potatoes for instance, they in turn will be cooked.
Hope this helps.
Feb 07, 2011 | Microwave Ovens
How do you defrost rfa52 polar white fridge freezer?
Switch off the power and place all the contents in a thick bage inside a large cardboard box, to keep it cold. Place a tray to catch the thawed ice in the apropriate place and wait.
When defrosted, wipe the surfaces down with an antibacterial liquid/spray of food grade quality and switch the power back on. Replace the frozen food, after checking the date codes, in the freezer
Jan 04, 2011 | Hotpoint Microwave Ovens
Does not cook even . put 2 items in cooker one well done other one half,
were both items the same density? Was one maybe thawed more that the other? A microwave cooks by rapidly heating the water molecules within the product that you are heating. If you heat two of the same product, it should cook them both evenly, however say you put in a frozen hamburger and a thawed hamburger, the frozen one will only begin to defrost while the thawed one will actually cook
Feb 11, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
MMV1153BA brand new, less than 2 weeks
The magnatron may need replaced..(this is what makes it cook)
Dec 10, 2008 | Maytag MMV1153A Microwave Oven
I lost my book
Keep it in low power for about 10-15mins. When you take it out, if it is still not properly defrosted, then add an extra 5-7 mins.
That should do the trick.
May 01, 2008 | Emerson MW8107WA Microwave Oven
Microwave Ovens Logo
395 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
