Question about Apex Digital AT2708 27" TV
Cable hook up
Is there any way I can hook up my t.v to my hard drive,is there any cable for it
  • 30 Answers
No. Even if you could, it doesn't have any way to process what is on the Hard Drive.
Posted on May 21, 2009
I want to remove the hard drive from an HP Pavilion 705w. Can you give me a description and tell me how to remove it?
The hard drive replacement procedure begins on page 11 of the parts replacement manual found here:
http://h10032.www1.hp.com/ctg/Manual/c00225826.pdf
Mar 05, 2011 | HP Pavilion a705w PC Desktop
How do you connect two hard drives to a computer?
1. For SATA, you just need a second SATA cable to plug it in and a power cable from the power supply.
2. For IDE, you will need a second IDE cable to plug the second hard drive, AND you will have to set both hard drives jumpers either to cable select or one Master and the other one Slave, based on which one you have the operating system.
Nov 12, 2010 | Maxtor Hard Drive
I need to hook my external hardrive up to my Mac and seem to have misplaced my manual. I need specifics on which cables I need to hook up, etc. Is there information online and/or a picture of this so I can...
In general, external disk-drives have one USB cable, running from the unit to any USB port on your computer. The smaller external enclosures have a "laptop" disk-drive inside, which draws electrical power through the USB cable. The larger external enclosures have a "desktop" disk-drive inside, and requires an external AC 110V adapter, which connects to a power-jack on the enclosure.
Nov 01, 2010 | Maxtor BASICS Personal Storage 3200...
I was installing a dvd drive, unhooked main power supply in computer, now when I turn on computer it says it needs a systems reboot disc can you help
The computer can't see the hard drive. IF the hard drive is on the same IDE ribbon as the DVD then you have a jumper problem. You need to look at the old cdrom if there was one and jumper new one the same as old one. (Master, slave or cable select) Also while you were digging around inside your computer did you pull the IDE ribbon to hard drive loose from the drive or the motherboard? Are the power connectors still hooked up? Every hard drive ribbon can have one slave and one master drive. Your hard drive should be the master and the cdrom the slave. Some systems are now set to "cable select" that means that the hard drive ribbon has a master connector and a slave connector and that the device (hard drive or cdrom) becomes a master if connected to one connector or a slave if hooked to the other one. If you go into your bios setup when you turn on the computer you should be able to look an see which of the drives or cdroms is hooked up as master or slave. Some will display this information during bootup posting.
Oct 04, 2009 | Computers & Internet
I OWN A DELL OPTIPLEX GX110 THAT WAS MADE IN 2000 I REMOVED THE HARD DRIVE TO SEE IF IT WOULD WORK ON A NOTHER BUT THE HOOK UPS WHERE DIFFERENT IT WAS NEVER HOOKED UP TO ANOTHER I WENT TO HOOK IT UP AND IT...
Make sure you hooked it to the same ribbon cable it was b4 you unhooked, check to make sure the power and ribbon cables are pushed in all the way on the hard drive and cd/dvd rom's, Check to see if the ribbon cable got pulled out from the main board side, Also try a different power cable there should one or two that are not being used with black caps on then.
Sep 11, 2009 | Dell OptiPlex GX110 PC Desktop
How do I connect laptop hard drive to hard drive enclosure?
open up the hard drive enclosure and hook the cables up the only way they will hook up. close the enclosure up and connect to computer.
Jun 17, 2009 | Ultra -Slim USB2.0 Hard Drive Ext....
Hard Drive hook up
usually on the Dimensions, it's a blue or grey SATA cable that goes from the drives to the motherboard. Dell has those as accessories, amongst others online
Apr 24, 2008 | Dell Dimension 2400 PC Desktop
How to install second internal hard drive
Yes, you can use, Please see label attached to the harddrive for a jumper setting to become primary harddrive.
in the DVD rom there's also a label on it. but the most common setting is slave is in the center.
C S M -
c-cable select
s-Slave
M- Master
the jumper is set to center to become a slave.
the hard drive is should be a master
connecting to the other end of the IDE cable.
HDD-should be a master
DVD rom-Should be a slave
Hope this help.
Feb 19, 2008 | Acer Aspire™ T180 PC Desktop
Apex Digital AT2708 27" TV Logo
74 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
robert landry
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
