Connecting dvd to tv - Televison & Video
How hook up dvd player to tv. what channel put tv on to see dvd pitcure
You should be connecting your DVD player to either an HD input or a composite video connection. Most modern TV SHOW will have at least 2 HD connections. On your TV setup menu there should be an HD connection to choose (probably HD-2) You will need to switch your input selection on your TV menu between HD/TV for TV and HD2 for DVD. It's hard to give specific directions without knowing the TV and DVD models.
Oct 27, 2016 | Televison & Video
Need to hook up sayo sound bar to my elment tv and my dvd player together
Help me connect my soundbar to TV, DVD, and Cable ...
www.tomsguide.com/answers/id.../connecting-soundbar-dvd-cable.html
Jan 2, 2015 - I want to connect my soundbar to give sound from my dvd player and cable box. ... More about : connecting soundbar dvd cable ... SolvedHow do I connectmy Element ELEFW392 TV to my Insignia NS-SB314 soundbar.
How do I connect my sound bar to the TV, BluRay, DVD, and ...
www.tomsguide.com/answers/.../connect-sound-bar-bluray-dvd-dish.htm...
Dec 30, 2014 - Then connected Panasonic Blu Ray DVD player: Panasonic HDMI to TV... pretty hook them up and it works' followed by 'why did you buy a sound bar?' Do Ihave to connect sound bar to TV AND Dish receiver? and not to DVD? ... tv bluraysound bar and a DVR cable box together Forum; Solvedconnecting ...
Soundbar to tv [Solved] - TV - Streaming Video & TVs
www.tomsguide.com/answers/id-2198401/soundbar.html
Jan 11, 2016 | Televison & Video
No to hook sound bar to element TV and my DVD player at the same time
Jan 2, 2015 - I want to connect my soundbar to give sound from my dvd player and... The soundbar has an optical cable option, but my tv does not support that cable. ...SolvedHow do I connect my Element ELEFW392 TV to my Insignia ...
Dec 30, 2014 - Then connected Panasonic Blu Ray DVD player: Panasonic HDMI to TV... first time, that paired the sound bar to the subwoofer but still no sound. ... Do I have to connect sound bar to TV AND Dish receiver? and not to DVD?
Jan 11, 2016 | Sanyo Televison & Video
Sanyo TV connect to cable box connect DVD player
If your DVD/VCR combo player has three RCA connectors (yellow, red, and white), you can connect them to the corresponding inputs on the front of your TV.
Dec 29, 2012 | Sanyo Televison & Video
How to connect austar and a blue ray DVD player to tv
your connection is wrong. Get a RCA wire. Yellow is video and white & red are audio.
Connect the wires to Output from the DVD. Video out and audio out. All that will be connected to the DVD will be output. The DVD is feeding out to the TV, so it is giving.
Now the all connections to the TV will be input. Because the TV is receiving from the DVD. Connect from the DVD to TV respectively.
Turn on the TV and DVD, then press Souce/AV on the TV. Now you should see a display and hear sound from the DVD through the TV.
I hope the above is clear. If not, please let me know.
Good luck.
Jan 04, 2012 | Televison & Video
How to connect a dvd player to a tv set
Connect the incoming antenna to the DVD player (look for connections on the back of the DVD player for Antenna In). Then connect the Dvd player to the Tv. Use the "out" connections on the back of the DVD player and the "in" connections on the back of the tv. You can use RCA jacks to connect the DVD to the tv, or any other type of connection available. Once the DVD player is connected to the tv, you need to set the incoming source on the television. Click on the source button until you find the one that has a clear picture. Dvd connections are usually listed as "aux 1 or 2" on the tv source choices. You will know when you choose the right one because the picture will come in on the tv.
Hope this helps?
Sep 12, 2011 | Televison & Video
We're not getting any sound from the dvd's. I have two cables (green/blue/red) and (red/white). but I'm at a loss how to connect from DVD to TV. Help please!
If your TV has the green, blue, red inputs then connect these 3 cables for the picture. DVD to TV, green to green, blue to blue and red to red. If your TV only has a yellow input, then connect the green cable only from the DVD yellow to the TV yellow. Now for the sound. Connect the DVD white to the TV white. Connect the DVD red to the TV red with the red cable. The white and red inputs will be next to the yellow and the green, blue, red inputs on the TV. Next select the TV input using your TV remote. Select the input for the DVD connection.
Sep 04, 2010 | Sony DVP-NS400D DVD Player
How to connect to tv using converter boxs
DVD does not need to go through converter box.
The converter is only to receive the digital TV through the antenna. DVD might have to switch to another connection on the TV, and if it doesn't have enough connections, you have a problem.
Dec 29, 2009 | Cyberhome CH-DVD 300 DVD Player
Now have verizon Fios and cannot get DVD player to play
Check the connection cable. If the Verizon box and the DVD player are connecting to the same TV input, ensure that the Verizon fios box is connecting to DVD input, and DVD output is connecting to TV.
If you connect DVD out to Verizon box input, and then TV , you will have to turn off the receiver box to see DVD.
If you use only one TV Input connect Verizon output to DVD input and DVD out to TV.
If instead you use separate inputs on TV, then try using the source/select input button on TV remote, and try different cables.
Regards.
Jul 25, 2009 | Sharp DVMX1U DVD Player
I want to add a DVD recorder into my TV set up
If I'm right On the DVD recorder there should be an aerial input and an output. Connect external aerial to the output then run a second from the output to the TV. Then use the HDMI to connect the DVD. This will then give you the option of recording one channel on the DVD whilst watching another thru the receiver thats built into the TV. You will then get the best poss picture when viewing DVD
Nov 25, 2008 | Televison & Video
Televison & Video Logo
154 people viewed this question
Top Televison & Video Experts
Electro Med Services...
