Question about LG LFC25770TT Bottom Freezer French Door Refrigerator
How to replace lg ice maker lfc25770tt - LG LFC25770TT Bottom Freezer French Door Refrigerator
3 Suggested Answers
co7196
  • 3433 Answers
SOURCE: LG LFC23760ST ice maker barely making ice
The making of ice may speed up a bit after the whole unit interior and insulation is cooled down.
Posted on Jan 28, 2010
  • 5370 Answers
SOURCE: Our two year old LG
Its defrost problem.Its starting the cooling cycle and ice gets collected, but while defrost cycle its not defrosting so ice gets collected instead of defrosting. --------------- The defrost is not working.The evaporator coil in the inner section of freezer is got blocked by ice . Try manual defrost reset procedure: ---- First unplug the unit from main power outlet. Then empty whole unit completely. Then keep both the doors open. Wait for 24 hours. All the ice collected on the coils and in the freezer section will get melted. Clean the water from the sections. Then Connect the power cord of the unit to main power outlet after 24 hours/.Then set the temperature to normal in both fridge and freezer section. It will take near to 4 hours to get run in its proper cooling cycle. Then check, if the problem returns again. If the same problem occurs then it's defrost problem. The defrost board and the defrost thermostat/heater is not functioning properly and it has to be checked and replaced. ------- The procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. In your case , It's starting the cooling procedure, and then while defrosting, it's not working. The defrost assembly consists of three main parts. The defrost thermostat, the defrost heater and defrost board. Any of the one is not functioning. When thermostat sense the maximum cooling, it triggers the defrost heater to start heating and this defrosts the ice collected on the coils and the system works. Both thermostat and heater are controlled by defrost board. First the thermostat and defrost heater to be checked, if both check ok by meter and visually, then its defrost board causing the problem. You can get required parts from online sites like: --- www.repairclinic.com or from searspartsdirect online site.--------- This should help.Thanks.Helpmech.
Posted on May 30, 2011
Trouble shooting LG french door ice dispenser
LG French Door Refrigerator - In Door Ice Maker Troubleshoot
? 4:41
https://www.youtube.com/watch?v=rA1DhfTwuwM
Feb 4, 2013 - Uploaded by ExperienceLG
Ice makers are great, but not if it means you can't fit all of your food in the fridge. The Slim SpacePlus Ice ...
LG fridge ice maker troubleshoot/ repair. How to fix ice ...
? 8:06
https://www.youtube.com/watch?v=arJpFgMnvPY
May 19, 2013 - Uploaded by spartacus1234567890
The ice maker quit working in my LG refrigerator so I decided to take it apart ... LG French Door Refrigerator - In Door Ice Maker Troubleshoot ...
LG Refrigerator Ice Maker Not Working - Model LFX25960ST
www.repairclinic.com/RepairHelp/...Fix...-/LG-Refrigerator-ice-maker-n...
LG Refrigerator Ice Maker Not Working. LFX25960ST. The part(s) or condition(s) listed below for the symptom Refrigerator ice maker not working are ordered ...
Jan 05, 2016 | LG LMX28988ST Refrigeration : Refrigerator...
How do you replace the ice cube tray in an LG Lsc26905tt ice maker
  1. LG LSC26905TT - YouTube
    ? 0:08
    www.youtube.com/watch?v=7dm-D7PtOOc
    May 22, 2011 - Uploaded by theholytoast
    Icemaker Ice-maker malfunction. ... LG LSC26905TT ... FridgeIce Level Arm Replacement - LG Refrigerator Repair (Part #4510JA3003D) ...
Jul 23, 2015 | LG Refrigerators
Water does not come to ice maker
Is this the reason you replaced the solenoids and ice maker? If so please see suggestions below.
Is the replacement ice maker an exact replacement? Non exact replacements may not work.
Ice maker may not be cycling to call for water, ice maker fill tube may be frozen, bad connection from ice maker (at the ice maker connector) to solenoid, or open wire from ice maker connector to solenoid. Ask for details for the above possibilities.
Aug 16, 2014 | LG Refrigerators
Lfx25978st ice tray stuck
This sounds like a thermostat in the ice maker has failed. Unfortunately, LG provides no replacement parts for the ice maker. They say to just replace the assembly, so there is no alternative other than ice maker replacement. Here is the ice maker to order.
Nov 27, 2012 | LG LFX25978ST 24.9 Cu. Ft. French Door...
I purchased my fridge about 4 months ago. lately, my freezer is crystalizing everything. its way too cold. everything is covered in ice chunks or crystals. i had followed the directions needed to be done...
It seems that nobody cares about us that have purchased LG products that seem to be made very cheaply and they do not want to help us fix them, but are ready to take our money
Jan 07, 2011 | LG LFC25770TT Bottom Freezer French Door...
Ice maker won't work
my mum use the same kind of freezer, when it had the problem on the ice maker, we both took it to a lg service center to renew the ice maker engine
May 31, 2010 | LG LRSC-26922 Side by Side Refrigerator
The ice maker will not shut off on the LG refrigerator.
the internal switch that is supposed to shut the ice maker production off when the bucket is full has failed. Replace your ice maker
May 07, 2010 | LG 22.4 Cu. Ft. Bottom-Mount Refrigerator...
Ice maker does produce much ice.
Change your water line with a new plastic line kit. Before you hook it up, get a bucket and turn it on and see if you have enough pressure. It should squirt very hard.
Jan 07, 2010 | LG LFC25770TT Bottom Freezer French Door...
LG refrigerator model lfx25950tt ice maker not working
I had the same problem and replacing the filter solved the problem for me.
Mar 16, 2009 | LG Refrigerators
LG Ice maker
You may have a broken ice maker and it needs to be replaced. You will need to have a qualified LG technician assist you.
Apr 20, 2008 | LG LRSC-26930 Side by Side Refrigerator
LG LFC25770TT Bottom Freezer French Door Refrigerator Logo
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
