Question about Toshiba Tecra M10 Notebook
Need to see display on both laptop and projector
I want to display a presentation on BOTH my Toshiba M10 laptop as well as through the projector. FN F5 toggles between projector and laptop screen
  • David Weaver
    David Weaver May 11, 2010
    I have some info for you, however I need the complete model number. Such as....Tecra M10-S1001, S1003 or something like that....usually this is found on bottom of the notebook.
    I shall check back soon.
  • Toshiba Master
  • 32,281 Answers
On most laptops pressing the Fn key plus the F5 key (in your model laptop) several times will cause the video to switch to different options
In the various laptops I've used with data projectors it is the same.
If you plug in the data projector and power it up then the laptop then the Windows image will be on the data projector (provided the laptop's screen resolution matches the data projector).
To toggle between the data projector only, the LCD screen, then LCD screen plus data projector, and or back through this sequence, just press the Fn key and the F5 key to get the displays you want .
Posted on May 21, 2009
Toshiba Satallite Pro M10 PS630E-G206C-EN on a new HD, clean install of XP Pro but system drivers all missing and cant find the disc. Suggestions on a complete driver download location please? Cant get the...
As you have access to another machine (as you have posted here!), go to the Toshiba site, and find the drivers for your laptop.
(There are three M10 laptops showing, this is one of them: Driver for Toshiba Satellite Pro M10-S405, or you could choose from: THIS PAGE, where you can choose the exact model).
Download them to a USB stick, or write them to a DVD/CD and keep them safe in case you need them again in the future.
Hope this helps.
Jul 31, 2011 | Toshiba Satellite Pro M10 Notebook
Toshiba Satelite Pro M10 doesnt boot
dvd drive you can remove from the backsdie opening the cover but display problem is becoause of faulty ram and the battery .remove the battery and try to on and clean the ram and fix it.
Jan 20, 2010 | Toshiba Satellite Pro M10 Notebook
Presentation mode is off in laptop
use the remote control or the menu button on the projector - navigate the menu system of the projector and one of the options should be able to alter the presentation mode from off to on.
If you post back with the model of the projector can either post a link back with a pdf manual for it or if you read the manual it should show in there how to enable the presentation mode.
Also ensure that you have the projector and laptop connected via the relevant cable ie vga or dvi before you switch the laptop on.
Also ensure if its got an intel graphics card to use the intel or graphics card utility to enable dual display or clone display mode and that the projector is switched on before you turn your laptop on.
right click in free area on your desktop --> properties --> display --> and configure it under the advanced section with regards to getting your laptop to display on the projector
configuring your graphics card for the projector will vary from graphics card to graphics card as the drivers are different between manufacturers and they place things in different places.
If you also post back with what make and model of graphics card you have on your laptop I can try and assist you further with how to ensure your laptop is outputting to the projector.
Also if it displays funny then lower the resolution on your laptop as well as the display frequency / refresh rate as the output from the graphics card on your laptop has to match what the projector supports ( this will be in the manual of the projector in terms of what display modes it supports )
Apr 10, 2009 | Panasonic PT LC75U Multimedia Projector
My toshiba tlp 261 won't project the image
hi try using the function key to toggle the display output form the laptop.every laptop when connected to an external display like projector works in the multiple diplay mode.in this mode the laptop vga output can be seen in 3 modes------ only laptop screen, only external deipaly(projector) & both laptop & projector.check this & this should work fine
any further help contact shyam +919867355202
Feb 07, 2009 | Toshiba TLP 261 Multimedia Projector
Can't project desktop
1.Open display Properties
2.Click properties
3.You are presented with Monitor 1 - Desktop & Monitor 2 - Projector
4.Click on monitor 2
5.Un check extend desktop to monitor
6.Click on monitor 1 and apply
If you apply at stage 5 above you deactivate the monitor 2
Dec 15, 2008 | Computers & Internet
Can't open Hardware setup
Hi Sam,
Is the correct Graphics driver installed onto the unit?
x-b-m
Mar 04, 2008 | Toshiba Satellite A60 Notebook
Presentation mode is off...
I'm going to guess that you have a wide screen Dell laptop with a 16:10 aspect ratio and a default resolution of 1280X800. The wide screen is great BUT most presentation grade projectors do not have a native (pixel for pixel) 16:10 mode. Instead they still prefer a display input with a 4:3 aspect ratio like your old square CRT or standard definition TV. Why do they prefer a 4:3 input? Mainly because Powerpoint prefers to display a slideshow in a 4:3 mode. Because of this Dell, in their infinite wisdom, created the 'presentation mode' utility in an attempt to automatically convert the VGA output of your laptop from 16:10 to 4:3 on the fly. In my experience this is an annoyance at best and at worst can seriously impact the size and quality of the projected image.
The best thing you can do when you connect to a projector is ignore the presentation mode alert and manually set your laptop's resolution to 1024X768 for an XGA rated projector or 800X600 for an SVGA rated projector. This will cause your desktop to look stretched on your laptop but will give you by far the best projection image.
Jan 16, 2008 | Panasonic PT LC75U Multimedia Projector
Toshiba portege m600 cannot connect to projector ACER PD525
you can extend the display to the projector through desktop settings
Dec 07, 2007 | Acer PD525 Multimedia Projector
Toshiba laptop won't work with new optoma projector
-toggle the laptop display using the FN keys and F5 I believe. -lower laptop resolution to 800 x 600 -look in laptop display properties for lcd or external display settings, see if it (external crt) has to be enabled on the laptop first.
Aug 26, 2007 | Optoma Projector Multimedia Projector
Toshiba Tecra M10 Notebook Logo
949 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
