Question about Royal 1030z All Metal Commercial Upright Vacuum Cleaner
Royal vacuum roller brush bar is tight and won't spin
Replaced belt and it just comes off immediately when vacuum is turned on
Engine cranks very slow on starting and will not start
refill the battery with electrolyt and charge it fully, then try to start the vehicle
If it cranks/turns over no faster have the starter motor checked.
Ensure that the timing belt is intact before you do anything, and that it is in the correct position.
Ensure that the oil is clear of water and is clean and is topped up to the top mark on the dipstick
Assuming you have checked the above and the belt and oil/coolant is all as they should be, and you have a fully charged battery and the starter is ok .......attempt to start the vehicle. Turn it over/ crank it over a few times if it does not start immediately.
Should it not start perform a compression check to find out the
engine's state of health.
Then come back with the results and we can go feom there.
Add the detail of your work and the make and model of the vehicle, along with the engine option, and repost the query
Jul 18, 2015 | Spectre 2003 Dodge Stratus - 2.4L 4-cyl....
Beater bar on electrolux el8602
Usually you have to replace the belt or if it is burning up belt take beater bar out and check the ends to see if they turn. Sometimes they get thread up in them from carpet and get stuck from turning and then they will burn belt up. Rich
Dec 21, 2014 | Electrolux El8502a Versatility Bagless...
How do you get the rollers out oy the electrolux nimbke
This is very easy, all you need to do is remove two quarter turn locks on the bottom plate and then you remove the plate and can assess the Electrolux Nimble Brush Roller 16136 1
Aug 23, 2014 | Electrolux EL8602A Nimble Upright Bagless...
How do i clean the roller
Look to see if the belt broke or belt slip off most of the time is something wrong with the belt. If you change the belt of fix the belt that is the time you clean the brush.
Jul 16, 2014 | Panasonic MC-UL815 MC-UL815
Why won't my Hoover Platinum turn on?
Check and see if there is a reset button for the vacuum head this trips sometime to protect the head motor. Also if the roller heads bind they can snap the belt if it is belt driven. If it is direct drive then I would look for the trip or reset button.
May 14, 2014 | Hoover Platinum Lightweight Upright Vacuum...
My panasonic canister vacuum agitator brush does not spin when on
Possible that you did not get the belt on properly and came off right away.
Apr 13, 2014 | Panasonic MC-CG917 Canister Vacuum Cleaner
Brush wheel not spinning
it can be belt or clutch failed. put the vac on its side and on the bottom there will be either two push clips or 2 screws remove them or push them and pull the bottom off. then when this is off you will see were the belt is for the spinning brush. if the belt is still on then the clutch has gone in the motor if the belt has gone take out the broken part and get a new belt, fitting new belt you need to remove the spinning brush it is either clipped in or slotted in , clipped is push the clips out to the side and lift the brush out, slotted it will just pull out. clean out the brush before putting back in also check the brushes bearing to make sure it moves easy as a failed bearing do to carpet string etc can burn the belt, any belt that has been burnt in this way should be removed and changed as it will damage the hover if still used after this part has been cleaned replace all parts and then turn on dont and it pluged in mains while you are doing this and dont use until it has all been fitted back..
Mar 26, 2014 | Kenmore Intuition Upright Bagged Vacuum...
Bearing on brush is hard to turn and smells like it's burning
bearing hard to move will put strain on the belt and burn it. the bearing is easily removable pull it off, sometimes its just a good clean it will need, if will not come off tape it off. remove the muck build up and give the bearing a good soak in some wd40 or oil and wipe off and check for good movement then replace the belt. as it will snap more easy now it has been heated up.
Mar 15, 2014 | Eureka The Boss Upright Vacuum Cleaner
Uh70600
Take the filters out and turn the vacuum on, if it will stay running without the filters in it you need to replace the filters. Filters should be replaced every few months. Clogged filters still pick up some dirt but miss a lot plus it causes the motor to run hot which will cause damage to the motor reducing it's life.
Nov 20, 2013 | Hoover UH70600 WindTunnel MAX Bagless...
Royal 1030z All Metal Commercial Upright Vacuum Cleaner Logo
43 people viewed this question
Top Royal Air Purifiers Experts
Are you a Royal Air Purifier Expert? Answer questions, earn points and help others
