Question about Frigidaire 14 Cycle Tumble Action Washer
Frigidaire tumble action frontload washer loud knocking noises
My washer has been making loud knocking noise during spin cycle and yesterday was the loudest. I took the front panel off and found what looked like two cement bricks on the bottom . I can see from where they came from. It looks like they broke off. I just want to know if this is economically fixable. If so where can I get the part and what is it called. Thanks
  • 90 Answers
These are the stabilising blocks. They are there to stop the knocking and noise. You should be able to buy them. Try the manufacturer or go on Yahoo or Google search for wash machine spares. Hope this helps.
Posted on May 20, 2009
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Frigidaire front loading washer has loud spin cycle, Why?
That's a great question, Roth!
Based off the information you have provided your Frigidaire washer is making a loud noise during the spin cycle. This could be an issue with your bel, motor, or tub. In order to find the cause of your noise you may need to disassemble your washer. This is not a simple DIY job and I would recommend contacting a technician to come out. This will help prevent any future issues or personal injuries. -Matt
Mar 11, 2015 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire washer makes a very loud humming noise on spin cycle.
Good Morning Larry Looney, thank you for your post!
I understand that your Frigidaire frontload washer is making a humming noise while in spin cycle. This could be a potential problem with your motor or drum bearing. In order to find the proper cause of the humming noise I would highly recommend having a professional technician come out to your home for diagnosis and repair. This will help to avoid any unnecessary part purchases as well as any future issues. -Matt
Nov 14, 2014 | Frigidaire ATF6000ES Front Load Washer
Very noisy and loud vibrations on spin cycle of Frigidaire FTF2140FS front load washing machine
Is it just during the spin cycle that it machine is noisy or the noise is less during the wash cycle? Also is the noise a thumping type of noise or is it more of a whining or steady noise? If is a whining noise, it probally means that water has seeped past the seal and corroded the bearing of the washer. The noise is the failing bearing.
Jun 30, 2010 | Frigidaire GLTF2940ES Front Load Washer
Loud noises during spin cycles
Hello, If the noise is a squealing or grinding sound, you are likely looking at a bad seal and bearing.
If the noise is a knocking sound, it's more likely a suspension or out of balance condition.
Thanks
Jun 12, 2010 | Maytag Neptune MAH5500B Front Load Washer
Loud noise in final spin
Verify that the inner drum isn't broken. Sopin by hand it should trun smoothly and staight.
Aug 30, 2009 | Frigidaire ATF6000ES Front Load Washer
My model #gltr1670aso makes loud noises during spin cycle
Usually this is due to either the drum support breaking or the back bearing being bad-neither easy to fix- or worth it. Try lifting the drum up and down, if it moves up and down they are bad. I see this a lot, and the price of repair isn't worth it. Craig
Aug 02, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire was tub makes loud thump noise during spin cycle....
Need more information to make an accurate diagnosis, try removing the front panel (two screws at bottom) and visually check first the belt (all the way around) and then the springs that hold the tub suspended.
I would bet on the belt.
Quentin
Jul 22, 2009 | Frigidaire FEX831CS Top Load Stacked...
Fridgidaire Washer has a loud knocking noise during spin cycle.
You need to replace your washer, the Inner tub Spider broke.. I repaired mine, With me doing the labour, $285 just for the part alone. plus about 3 to 4 hours labour.
Mar 14, 2009 | Frigidaire FWTBB30DS Front Load Washer
Frigidaire top-load washer Loud noise during spin
its either the upper spin bearing or lower spin bearing. the upper can be replaced by itself but the lower requires the transmission the be replaced
Nov 20, 2007 | Frigidaire FWS833A Top Load Washer
Frigidaire 14 Cycle Tumble Action Washer Logo
541 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
