Question about Vizio VA26LHDTV10T 26" 720p LCD HDTV
Vertical streaks on screen
My mom's tv has vertical streaks down the middle of the screen. is this repairable? If so what part do I need and is it something I can do. I have some experience soldering /swapping parts on tv's.
  • 87 Answers
SOURCE: vertical black line on screen
Your set has either a bad driver board or more likely a bad plasma panel.
Posted on Oct 19, 2007
SOURCE: LCD TV - Vertical Blue line
use menu and h/v then change then move to higher level and it will take it away.
Posted on Aug 24, 2008
  • 15 Answers
SOURCE: big black bar in the middle of the screen vertical
You will need to replace the Main board and I would also replace the LVDS cable that connects the main board to the LCD panel. Very easy to do, but might take about 2 hours depending on your comfort level.
You will need:
Screw Driver
LVDS cable – Part # 0500-0505-0540
Main board – Part # 3632-0652-0395
Those part numbers will work if you have a model number VOJ320F1A.
If you post the model number I will try to find the part number for you.
thanks
Posted on Aug 14, 2009
  • 10 Answers
SOURCE: I have a vertical black line on the middle of the
You have A buffer board out if the line goes up and down then its the long board going left from right look were the line is and see what board the line lines up on the screen and replace that one
these boards are the closet to the edge of the tv
same process if the line goes across the screen
look for the part number on the board and search with google or go to shopjimmys.com and seach there or call them
Posted on Oct 19, 2009
toolkits
  • 1099 Answers
SOURCE: Vertical blue lines appeared on the screen with no sound.
All plasma an LCD TV have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables. If one of these boards fails all together, has a failed chip, a bad connection, or a bad ground somewhere it will result in a black line in the area of that board. A bad ribbon cable connection on the bottom will result in a vertical black bar though the screen. Many times resetting the connection will fix it, if the ribbon cable has been nicked there could be a severed connection. They an sometimes be fixed, but it is a pain. An yes I have done it, but the bar is gone. The same will happen if the chip that outputs to that area opens. The connectors are the first place to look paying close attention to the cable, they are extremely delicate so great care must be taken if you decide to tinker with em, the usually have lift locks that release them, but it is very easy to wreck em. Good luck.
Posted on Jun 07, 2010
LG vertical green line
LG plasma vertical line repair - YouTube
? 2:33
https://www.youtube.com/watch?v=24FkcQoeGPg
Feb 10, 2013 - Uploaded by Matt Mayer
I have an LG plasma, my vertical line is in the middle, as if one would have ... Panasonic Plasma TV TC-P50X5 Vertical GreenBar Line Fix ...
EASY HOW TO FIX LG plasma TV - color bars - YouTube
? 4:45
https://www.youtube.com/watch?v=QyaBiSkc1l8
Dec 16, 2010 - Uploaded by Tampatec
diy HDTV Plasma tv repair tv reparar the red green blue color stripe line vertical bars T- control t-con ..
Jan 16, 2016 | LG Televison & Video
How to fix Toshiba Regza LCD TV when half the screen with vertical streaks?
hi this fault sounds like a bad tab/ribbon fault, at top of the tv are ribbons connector to the screen, when one is faulty the heat makes them flex causing this fault, you can bond the ribbon down with a bit of rubber to stop it flexing, but this not a permanent repair as it is a screen fault. hope it helps
regards
shaun
Apr 24, 2014 | Toshiba 42HP66 42 in. LCD Television
Canon NP6221 copier makes copies with black streak down middle.
I suggest You Go to Official Canon Printer Page For You Canon Problem On Below Canon Page URL:
Copy Has Vertical Black Streaks In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On : Canon Printer Support
Feb 16, 2014 | Canon NP6221 Fuser Thermofuse
Vertical white line in the middle of rca tv
Check and replace all the electrolytic capacitors at its vertical output section circuit.
Mar 17, 2013 | Televison & Video
When i turn it on it has an horizontal blue line in middle of screen then comes on, when shut down it has the colors in the middle in tight formation then suts off. is it the picture tube
the set having blue scteen when the nosignal condition so blue horizontal line due to failure in vertical deflection section and system control detect the vertical delection failure . so system control farce to set to shut down pls repair the vertical section and system should be ok
Aug 26, 2010 | Samsung SlimFit TX-S3082WH 30" TV
My daughter's LCD TV has color vertical streaks
I believe she had damage the screen TFT (Thin Film Transistors that drive each LCD Red, Blue, Green pixels, there are about a million of them on the screen). The sreen is very delicate. You can ask local repair shop for second opinion.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Jul 01, 2010 | Olevia MN-20LCDTV-SN 20 in. EDTV-Ready...
Old sony tv gets a bright line in the middle of the screen
Well if this is a tube type, it can be attributed to vertical section. Cold solder on vertical IC, the vertical gone bad or some components on the vertical is at fault.
If your not on electronics better to have it check by a repairer.
Hope this helps.
Jan 18, 2010 | RCA F32650 32" TV
Bad picture on Toshiba
this is a malfunction vertical deflection block of your TV-set .please contact the nearest repair shop.do not turn it on until then,please.
Apr 17, 2008 | Toshiba 36A40 36" TV
2-inch picture stripe in middle of screen.
deight, your set is going into total vertical collapse, either the vertical IC is failing or some support component to the vertical circuit is failing, should not be an expensive repair, hope this helps, BMW Rider
Dec 12, 2007 | Sylvania 6419TA 19" TV
Television fails to start
Hello vjob,
This problem means that the TV has lost vertical drive. This could be a problem with the vertical signal coupling capacitor, the vertical output stage, or the vertical driver stage of your TV.
If you are not experienced at electronics, I would suggest taking the TV to a qualified TV repair shop. It should not cost much to repair this problem if the deflection yoke is not involved with this problem.
Thank you,
Shuttle83
Nov 25, 2007 | Televison & Video
Vizio VA26LHDTV10T 26" 720p LCD HDTV Logo
22 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
