Question about Baumatic Refrigerators
Stopped running just keeps clicking twice but motor will not cut in
Car cutting while driving and idling just keep going up and down
Check your RPM, check if it is rushing when you turn it on. Set the RPM needle to exactly 1.
Try this first.
or.......................
When slow down and stop the car engine shuts off Inspection Service Cost...
R33 GTS RPM Gauge Cluster Fix FIJI
Aug 23, 2016 | Chevrolet Cars & Trucks
Pressure washer keeps cutting out
HI Earl I need a little more info do you mean the motor stops or the pump stops pumping ( with the motor running)???
Nov 24, 2015 | Garden
My series 90 will only Run if i holding the Starter but ton
I would start by checking the centrifugal switch on the motor.
When you push the start button, the motor starts turning, then the centrifugal switch on the motor clicks in and keeps the motor running until the timer or the door switch cuts power to it. If the centrifugal switch isn't working, the motor won't stay running.
Good luck
Oct 27, 2014 | Kenmore Dryers
Freezer cuts on every 3-4 minutes. stays on 8-10 seconds. some thawing occuring
If I understand you correctly the compressor is short cycling. The more it does this the worse it gets by causing the compressor to overheat. Sometimes the problem is because the condenser fan or evaporator fan being defective. Pull away from wall and remove cover over compressor unplug and feel top of compressor and if too hot to keep hand there keep unplugged but do examine the evaporator and condenser fan to eliminate them as a reason. The most likely reason is start relay and or start/run capacitor and sometimes a worn out compressor.
Overload relay click here=> 67002527
Run capacitor click here=> 65889-4
Location Click Here=> MBB1952GR Compressor Components
Parts in that photo are marked as 10 overload/relay, 11 is the run capacitor and 3 being condenser fan motor. Condenser and evaporator fan motors do not always stop completely when bad so make sure both run while compressor is running. If this has been helpful please rate if you have more questions please let me know, Thanks Sea Breeze
Dec 10, 2010 | Maytag MBB1952GR Bottom Freezer...
Dryer won't stay on
The motor centrifugal switch is not switching from the start winding to the run winding. The switch should stay in the run winding when the motor picks up speed unless power to the motor is interrupted or cut off. The switch is replaceable on most dryer models but sometimes it is an integral or built-in part of the dryer motor and failure of the switch requires the replacement of the motor. Indicate the exact model number of the dryer for more accurate troubleshooting and repair advice.
May 24, 2010 | Kenmore 63932 Electric Dryer
Antannae
theres wires leading to the motor cut the ground wire and the motor will stop
Mar 24, 2010 | 1999 Hyundai Sonata
Modle 80 washer.
If in spin the water drains ok then your coupler is faulted, If not the motor is faulted.
Aug 16, 2008 | Kenmore 22422 Top Load Washer
Dryer runs for minutes then stops timer keeps going and going and .....
remove the vent on the dryer that goes to the outside start the dryer if it continues to ru n and not cut off you have a venting problem of the house
if it cuts off after 5 mins with the vent off you have a motor that is going bad
Jun 11, 2008 | GE DBXR463EBWW Electric Dryer
Robot Coupe clicks, runs 5 seconds, stops for 30 seconds, clicks, runs 5 seconds...
The clicking noise is an internal circuit breaker or motor protector. These things are not made to be bogged down or overfed. The motor is heating up & tripping the overload, after cooloing it resets. Time to buy a new one or get the motor replaced ($600-$800)
Oct 29, 2007 | Robot Coupe R100 10 Cups Food Processor
Refrigerators Logo
110 people viewed this question
Top Baumatic Refrigerators Experts
Sal DeAngelo
Colin Stickland
Colin Stickland
Electric Dime
Electric Dime
Are you a Baumatic Refrigerator Expert? Answer questions, earn points and help others
