Question about Motorola MH230R Two Way Radio
Problem with ptt, i put it to speak but then they start over like when you turn it on
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 90 Answers
Reset when transmitting is a sure sign of weak batteries
Posted on Sep 14, 2014
How to replace the ptt button on a motorola rdu4100
If you are referring to the external button on the radio, the entire front housing assembly must be replaced. If you are speaking of the internal PTT button on the component board you may want to send the radio for repair (approx. $79). Or if you are equipped with a soldering station, you can replace this component yourself by removing the defective part and soldering on the new switch.
May 08, 2014 | Motorola AXU4100 (10 Channels) 2-Way Radio
We recently purchased the MS350 radios and are trying to use them handfree with the headsets. We plugged in the headsets, turned on the radios, but are unable to communicated back and forth using the VOX...
The three things which come to mind are:
1) Is the headset the VOX headset intended for the radio model? Sometimes the rings on the plug do not match the internal points of contact if it is not the intended headset. Not all headsets are VOX capable.
2) Is the headset plugged in all the way. (You mentioned plugging in and then turning on. This is good. You must always have the radio turned off when plugging or unplugging an audio device.)
3) Try pressing the PTT on the headset cord one time before switching the dip switch to VOX. (Assuming you have a headset with the small box in the line.)
Check your VOX/ iVOX settings. You will need VOX for using an audio device.
Lastly, if you continue to have difficulties, contact Motorola at the 800# provided in the user guide. They should be able to assist you.
Best regards.
Sep 23, 2013 | Motorola Hands-free Headset,for 2-Way...
How do i change the frequency on a mototrola sp21 from 12.5khz to 25khz?
The SP21 is PTT programmable.
1) Hold in the PTT while turning on the radio. Let go when the female voice begins to speak. It will announce the frequency number. You can use the PTT to walk through the 35 to 40 frequencies available. Then when you have reached your desired frequency. Press the MONITOR button to lock it in. (small button on the PTT).
2) Then your radio will announce the PL code. Using the same method of pressing the PTT you can walk yourself through the 38 possible PL codes. Press the MONITOR button to lock in your preferred code.
To answer your question concerning 12.5k to 25k selection. You should at this point in time be changing to 12.5k (narrowband). All VHF and UHF users are required to move to narrowband by Jan. 2013.
In the VHF SP21 frequencies 1-16 are 25k, and 17-37 are 12.5k.
In the UHF SP21 frequencies 1-16 are 25k, and 17-40 are 12.5k.
Best regards.
Jul 24, 2012 | Motorola Radius Vhf Sp21 2 Way Radio...
Change language setting motorola mv22
Hold in the PTT button while turning on the radio. First it will announce the frequency, then press the monitor button once, then it will announce the code, press the monitor button one time again, then if it is equipped with a language choice, you will get to select your language by using the PTT button to walk through the choices, lock in your choice by pressing the monitor button one time. Shut the radio off, then back on without holding in any buttons... you are ready to use the radio.
Best regards.
Apr 23, 2012 | Motorola MV22CVS VHF (2 Channels) 2-Way...
Walkie talkies model gmr325-2 ic;513C-UT914 HOW DO I GET THESE TO TRANSMIT, MY HUSBAND HAS CANCER AND WE NEED THEM IN OUR BEDROOMS AND WHEN I AM OUTSIDE, TK U, TK U
In order to get the most out of your new radio, read this reference guide completely before attempting to operate the radio.
Turning the Radio On and Adjusting the Volume
1) Press and hold the key to turn the radio ON.
2) To change the volume level press the volume/monitor up or down key to increase or decrease the volume level.
3) Press and hold the key to turn the radio OFF.
Adjusting the Sound (Key Beeps)
Your radio emits a beep each time one of the keys (except for the PTT button and call key) is pressed.
The sound of the Key Beep will increase or decrease depending on the volume level setting.
To turn OFF this beep:
Press and hold the call key while turning ON the radio.
To turn ON this beep:
Turn the radio OFF and ON again.
Choosing a Channel
Your GMR325-2 radio has 22 channels you can use to talk to others. In order to speak to someone,
each of you must be set to the same channel.
To choose a channel:
Press the channel/scan up or down key to increase or decrease the channel number displayed.
Channel Scan Feature
Your GMR325-2 radio has a channel Scan feature that allows you to easily Scan all 22 channels. When an active channel is detected, the unit will pause on that channel until the channel is clear. Then after a 2 second delay, the unit will continue scanning.
Pressing PTT button while the Scan is paused on a channel will allow you to transmit on that channel.
To turn ON channel scanning:
Press and hold either the channel/scan up or down key. The channel number on the display
will rapidly cycle through the channels.
To turn OFF channel scanning:
Press either the channel/scan up or down key.
Talking on Your Radio
To talk to others using the radio:
1) Press and hold the PTT button and speak in a clear, normal voice about 2-3 inches away from the microphone.
While you are transmitting the tx icon is displayed. To avoid cutting off the first part of your transmission, pause slightly after pressing the PTT button before you start talking.
2) When you are finished speaking, release the PTT button.You can now receive incoming calls. While receiving, the rx icon is displayed.
Transmitting a Call Alert Tone
Your GMR325-2 radio is equipped with a call tone that will be transmitted when the call key is pressed.
To transmit the call alert tone, press the call key.
The tone will automatically be transmitted for a fixed length of time.
Auto Squelch Feature
The GMR325-2 is equipped with an automatic squelch system which shuts off weak transmissions
and unwanted noise due to terrain conditions or if you have reached your range limit.
Monitor Mode Feature
Your GMR325-2 radio allows you to listen for weak signals on the current channel at the press of a key.
To turn ON monitor mode:
Press and hold the volume/monitor up or down key. The rx icon will blink.
To turn OFF monitor mode:
Press the volume/monitor up or down key. The rx icon will stop blinking.
Automatic Power Save Feature
Your GMR325-2 has a unique circuit designed to dramatically extend the life of the batteries. If there is neither transmission nor an incoming call within 2 seconds, your radio switches to the Power Save mode. The radio is still able to receive transmissions in this mode.
KEYLOCK ON/OFF
Press and hold the call key until the "L" appears. After 1 second, the LCD will return to the channel display.
To exit Keylock on mode, press and hold call again.
Note: While in keylock on mode, it will still receive transmissions.
ROGER BEEP
Roger Beep is a BEEP that is sent to notify the end of transmission.
Roger Beep can be heard through the speaker when Key Beep is on.
Roger Beep is transmitted even if key beep is turned off. However Roger Beep will not be heard from the speaker.
To turn OFF Roger Beep: Press and hold the channel/scan up Key while turning on the radio.
Jun 21, 2011 | Motorola Walkie Talkies 2-Way Radio
How do i put my new cls1110 on prog 1 frequency 4
The CLS1110 is a one channel radio. However the one channel can be changed to another frequency and/or PL code. With the radio turned OFF, hold in the PTT and the MON, while turning the radio on. Continue to hold the PTT and MON until the radio stops making noise. You are then in programming mode and can use the menu button to walk through the stages of programming. Use the PTT to change the settings, and the MENU to lock it in.
Best regards.
Nov 16, 2010 | Motorola CLS 1110 (1 Channel) 2-Way Radio
I got these walkie talkies audiovox
try to work the ptt switch on and off rapidly a few times see if that works.
Apr 11, 2009 | Audiovox GMRS602PK 6-MILE GMRS 2-WAY RADIO...
Hands free
You do not mention what type of radio you are using. However, it is possible
1) you are plugging in the audio device with the radio turned on. If so, the result will be as you describe. Simply turn off the radio and replug the device with the radio turned off. In most cases this will solve the problem. Or a simple press of the PTT while it is locked in transmit, will return the radio to Push-to-Talk mode.
2) You are using an audio device which is not designed for the radio. OR
3) Your radio is stuck in Transmit.
If all else fails, shut off the VOX capability of the radio.
Oct 21, 2008 | Motorola Walkie Talkie 2-Way Radio
Talk about frequency change
To change channel & code press talk and monitor while turning radio on. Radio will speak current channel. Release both talk and monitor. Press talk to change to next channel or press monitor to keep current channel. Press monitor when desired channel is selected, radio will speak current code. Press talk to change to next code or press monitor to keep current code. Press talk to change code as desired then press monitor when done. Will speak channel and code selected. Set all units in same manner to communicate.
Oct 15, 2008 | Motorola Talkabout T5800 (22 Channels)...
One way comm only
swap batteries if does not work this unit should need repair or replace, display blinking can be produced for power failure ( battery, contacts, circuits) or can be a controller issue.
Feb 07, 2008 | Motorola Talkabout T5500 (7 Channels)...
Motorola MH230R  Two Way Radio Logo
315 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
bill tarkulich
Level 1 Expert
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
