Question about Sony Ericsson W300 Cellular Phone
Text Messaging Hello, Please can you tell me how to remove the predictive text option as I prefer to use the other input method. Thank You
  • 425 Answers
Hi
try setting your phone to its factory settings.  you can access to that menu at the setting part of your phone.
or you can go to your write message menu then option then scroll down and find any menu regarding input methods...
hope you find it... thanks...
Posted on Oct 19, 2007
HOW DO I STOP MY PHONE PREDICTING WORDS WHEN TEXTING
There is a setting that turns this on or off. For that phone it may be called t9 or predictive. to turn it off you go the text entry screen press ABC (bottom left corner, push upper left button)....Scroll to any other option beside T-9 or Itap (that's the predictive text) then press okay.
From another forum:
You may choose the 'input method' between 'Moto Input Method' and 'Multi-touch Keyboard'. Please visit 'settings' followed by 'Language and Keyboard Settings' and choose the one which makes it easy for you.
Sep 27, 2014 | Motorola Mobility FOR MOTOROLA RAZR RAZOR...
Turn off predictive text motorola gleam
go to messaging icon / write message / press option button ( which is above green button) / go to input method options / set T9 (aka predictive texting) / then press off.
Here we come hassle free texting :-)
Feb 07, 2012 | Cell Phones
Text Mode show on display nokia1600 handset
You can enter text in two different ways: the traditional text
input indicated by , or predictive text input (built-in
dictionary) indicated by .
To use traditional text input, press the key marked with the
letter that you want repeatedly until the letter appears.
To turn on predictive text input when writing text, select
Options > Dictionary and the desired language; to turn it off,
select Options > Dictionary off.
To use predictive text input, do the following:
1. To enter the word you want, press each key once for a
single letter.
2. If the displayed word is the one you want, press 0, and
start writing the next word.
To change the word, press * repeatedly until the word you
want appears.
W r i t e t e x t
24
If ? is displayed after the word, the word is not in the
dictionary. To add the word to the dictionary, select Spell,
enter the word (using traditional text input), and select OK.
Tips for writing text with traditional and predictive text input:
• To add a space, press 0.
• To quickly change the text input method when writing
text, press # repeatedly and check the indicator at the top
of the display.
• To add a number, press and hold the desired number key.
• To get a list of special characters when using traditional
text input, press *; when using predictive text input, press
and hold *.
or check this link
http://nds1.nokia.com/phones/files/guides/Nokia_1600_UG_en.pdf
Nov 14, 2011 | Nokia 1600 Cellular Phone
How do i set predictive text on samsung m8800
Follow the below mentioned method, also see the advantages of T9 dictionary :
1.
Check your manual to learn more about text messaging
Check your cell phone's user manual to see if your cell phone has the T9 function. While most new phones contain this function, if you have an older phone, you'll want to check to be certain. Look under the Text Messaging section in the manual.
2.
Enable T9 for easy texting
Enable the T9 setting on your cell phone. Some phone require that you enable this function. Check under your cell phone's Options menu and also under the text messaging options. Depending on your cell phone, you may be able to set T9 as the default method of text input or you may have to toggle the text input functions to choose T9 for every text message. Generally, the toggle key will be your asterisk key. Again, check your cell phone's manual for more information.
3.
Choose your language and other preferences for T9 texting
Pick your T9 preferences. Your T9 function may allow you to set several preferences. The most typical preference is language, and you also may able to set whether you want your cell phone to use T9 for word completion only or to predict which word you will type next. You may also be able to set the "delay" - the amount of time before your T9 function changes the letters you are typing to what it thinks they should be. Again, try your Options or Preferences menus in the text messaging module of your cell phone or consult your cell phone's manual. You will want to try different set-ups to determine which works best for you and your style of text messaging.
4.
T9 gives you more then one way to select the right word for your text message
Type your text message, toggling for T9 if your phone requires it. Once the T9 function is enabled or toggled, simply type the word you want. Do not be concerned if the letters do not appear correctly when you first start typing the word - they will correct themselves when you finish typing the word, as long as you spell it correctly. Your phone may offer a drop-down menu with word suggestions as you type. If your word shows up, scroll down and select it if you wish or continue typing your word. If your phone does not offer a drop-down menu, and the word that you type is not the word that you wanted, press the Down arrow key on your cell phone and another word will show up. Keep pressing the Down arrow until your word shows up. When you have the word you want, use the space function to continue typing.
5.
Add your own text expressions to T9
Add your own words to the T9 function. The T9 function comes with an extensive dictionary, but you can add your own words or abbreviations, too. Again, you may have to dig around the Options or Preferences section in the text messaging module of your phone. Once you find it, simply type and add your own special words or expressions to have them at your fingertip when you text.
Use T9 to express yourself in your own unique way!
Jun 12, 2011 | Samsung M8800 Pixon - Unlocked QuadBand...
How to remove predictive text using LG GM360 phone
while the text messaging screen is up press the icon that looks like this bendjmiller.pngthen select input method and choose keyboard. Touch T9 to turn predictive text on or off. Hope this helps
Mar 12, 2011 | Cell Phones
When I start to type a words automatic words come up
I assume you mean when you are writing a text that this happens?
This is predictive text (t9),where the phone automatically tries to predict the word which it thinks you intend to type,
It has its advantages in that it can make typing a text faster but it does take a while to get used to and some people just prefer to text by the method they are already used to,
You can disable the predictive text if you wish and use normal text for your letter input,the option will be on your phone in the settings,if you are unable to locate the option reply back with your make/model of handset and I will tell you how to disable it
Sep 07, 2009 | Lands Phones
How to remove predictive text from T303
If you would like to change the input method from predictive text to multitap, press and hold down the *a/A key to change the input method. Note that this is for your Sony Ericsson T303.
Check the photo:
Jun 24, 2009 | Ericsson Cell Phones
I want to turn off Predictive (spell) text - How?
Hello.
Welcome To Fixya Community.
I am glad To help You Sir.
"To activate/deactivate predictive text input, press # twice quickly.
This activates predictive text input for all editors in the
device."*
*Source:
Nokia E51 User Guide.
Thank You For Using Fixya.
Please Give a good Feedback^^
May 31, 2009 | Nokia E51 Cellular Phone
When typing out text message on my SGH-U600 when i get to the 3rd word it freezes and resets with the please wait command, then reboots itself, Im lost :(
hi had same problem, one solution is to take off the predictive text. go to write a text and b4 putting text on page, press options, no 7 input method and take off predictive text (Tab), you then have to text the other way which takes longer but at least can use phone, hope this helps
Dec 30, 2008 | Samsung SGH-U600 Cellular Phone
Predictive Text
To get predictive text on or off on the LG Shine go to:
>Menu
>Messaging
>New Message
>Text
>Options
>T9 languages
>T9 on/off
Sep 01, 2008 | LG Shine KE970 Cellular Phone
Sony Ericsson W300 Cellular Phone Logo
Top Sony Ericsson Cell Phones Experts
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
