Question about Android Apps
Stock firmware casio commando c811 - Android Apps
4 Suggested Answers
SOURCE: delete apps on my casio commando phone
If they are the crapware apps installed by your service provider, you would have to "root" your phone. However, rooting may void your warranty.
Posted on Dec 12, 2011
SOURCE: need to change digitizer on casio commando
For those of you that need tear down instructions for the Casio G'zone Commando:
We figured these out through trial and error. Hopefully, they will keep someone else from making the same mistakes we did.
Before you start, you will need a tri-wing screw driver. You can make due with a tiny straight way, but it will mess up the screw heads and make the process a little more difficult.
First, power off the phone and remove the back cover and battery.
Next, take out the four screws on the front of the phone. The black trim will snap off in two sections. Turn the phone over and repeat the process on the back.
Next, remove the gray trim on the sides of the phone. It is glued on and will pull off without too much effort. By doing this you will also have to remove all of the buttons and covers. I would suggest keeping each side separate to make reassembly easier. It is not necessary to remove the trim on the ends of the phone.
Next, remove the four screws (two on each side) found under the side trim. This will allow you to unsnap the front section of the phone. This does take some effort and will also remove the waterproof seal.
Now you are ready to start replacing the digitizer if that is your purpose.
The first step is to remove the existing digitizer. The digitizer should be glued in place. If it is not already broken (mine was), there is a good chance that it will break. Do not remove the glue that is left after taking off the digitizer. You will need it to hold the new one in place. Now you see why the phone has to be disassembled to this level, so that you are able to unplug the old digitizer and plug in the new one. Once that is done you are ready to start reassembling the phone.
This is not an easy process and will take several hours to complete. I believe it took us 3 - 4 hours to complete the process.
We were able to take the phone apart, replace the digitizer and get it put back together. Unfortunately, it was not fully operational once reassembled. For the most part it worked; the top speaker did not, as well as the dialer button and the menu key. The rest of the screen was functional, though. As I said, this process was a lot of trial and error on our part so it is possible that we damaged something.
Posted on Sep 09, 2012
  • 46529 Answers
SOURCE: My Casio gzone commando c811 says it's fully charged so I unplug it and start using it and it all of a sudden dies why?
probably a memory problem in the battery
if they are continuously being recharged when not close to 5% then they develope a memory level and will not charge past that point
the fix is a new battery
Posted on Mar 21, 2016
Mar 21, 2016 | Casio Cell Phones
Need unlock code!!! :(
I believe it's 0000 (four zeroes).
Aug 28, 2013 | Supertooth Casio GzOne Commando 4G LTE...
Unlock codes for casio gzone commando
net banking problems solution
Jul 14, 2013 | Cell Phones
How to replace a CASIO G'zOne COMMANDO Camera lens
its a complete small camera unit an they dont sell parts except what you see on ebay from broken phones
Mar 11, 2013 | Casio G-zone Commando
How do i send a voice text from my casio commando
You can check the setting and instructions in user manual..
Oct 06, 2012 | Casio G-zone Commando
Change font size on casio commando?
How to change font size on commando phone
Feb 12, 2012 | Casio G-zone Commando
Delete apps on my casio commando phone
Nov 22, 2011 | Casio G-zone Commando
Android Apps Logo
63 people viewed this question
Top Apps Experts
Are you an App Expert? Answer questions, earn points and help others
