Question about Compaq Evo Thin Client T30 (311335-001) PC Desktop
How do you connect ethernet so you have both your desktop and thin client connected?
I have a Compaw T30 thin client. I want to use it for my MagicJack phone. How do I connect it to my broadband modem and still have my desktop hooked up when I have only 1 cable?
  • 53 Answers
Purchase a ethernet hub. I have 1 by Linksys. They are relatively inexpensive. Plug your cable modem into the uplink jack and your desktop and anything else to the other ethernet ports.
Char S.
Posted on May 20, 2009
External speakers won't work on HP T5570e Thin Client
Try to use earphones, plug them in to phone audio connector....
try if it works..... if so, disconnect them and plug speakers.... and try again.... if doesn't work, go to audio advanced setup and check if speakers are not muted, or set up voicevolume level is too low. Play with that setup....
Also some computers can turn on or off speakers in Bios.
If problem will not be solved, try to use USB speakers
Jan 13, 2014 | HP T5740 Thin Client Desktop PC
The network support infrastructure required to utilise Network Computers.
All you basically need is an Internet connection, a central connectivity device (a Router), some ethernet cabling and computer with Network Interface Cards.
Jul 25, 2012 | WYSE C10LE Thin Client (90217501L) Network...
Dear Sir, We have one IBM x206 8482 I8S Serer. We have loaded Win XPP to this system and configured as Thin Client Server. The Thin Clients hang during the operation. The Thin client Vendor identifies this...
You have a compatibility issue as per your comments and you have no choice but to use the components and operating system that will work with each other. Without drivers you are in deep doo doo and there is no forcing the issue.
Apr 07, 2017 | IBM eServer xSeries 206
Connecting VGA monitor causes clicking or knocking
try to clean the memory or video card if you have.....
Feb 05, 2010 | Computers & Internet
D-Link DES1008D 8 port fast ethernet desktop switch
By using it, of course you have this items to connect it with internet:
  1. UTP Wire with Connectors at end each PC or Client Workstation.
  2. Make sure every PC or Client Workstation have its own LAN Card.
  3. To connect on the internet is to know what is IP Address, Gateway Address & DNS Server Address settings on your LAN connection.
  4. Lastly, It should have internet provider in your place.
Jul 29, 2009 | D-Link DES-1008D 8-Port Ethernet Switch...
Removing password on T30
YES.... providing that the hard drive was not completely re-formated before the windows OS was installed.
Usually, manufacturers leave a section of the HD for this so in the event that something goes wrong, you would be abke to revert back to the manufacturer's setup.
Simply follow the following instructions... :
1) remove power from the T30.
2) hold or tap the 'G' key on the keyboard
3) apply power back on T30 while maintaining step 2)
4) turn on T30 via power button while maintaining step 2)
5) T30 should eventually boot up and in factory default settings.
If this doesn't work, repeat process or the T30 was configured to disable the 'G' key. In this case you need to reflash the firmware on the T30.
Aug 29, 2008 | Compaq EVO T30 Network Terminal
Wyse S30 thin Client with Ubuntu
You might find an answer for this Ubuntu problem, in the Ubuntu product.
Try posting your question there if there's no existing one.
Good luck.
Nov 27, 2007 | Neoware Systems c50 Thin Client Network...
Upgrade 238622-001, Compaq Evo T30 Thin Client 300Mhz 32MB Flash/64MB/Win CE NET/IE 5.5 w/o
You need to replace the 2mbit bios chip used by the WinCE Evo with the 4mbit one used by the NTe and XPe Evo, then you need an add on flash module, since the onboard flash is too small. After that, just find the OS file and flash away. You can find the OS files and a utility to flash from the HP support site. You'll need a crossover ethernet cable, not a patch cable, to do the flash.
Jun 25, 2007 | Compaq EVO T30 Network Terminal
Compaq Evo Thin Client T30 (311335-001) PC Desktop Logo
210 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
