Sterling unit heater wiring diagram model qvf 60
4 Suggested Answers
  • 2600 Answers
SOURCE: M Sterling Model QVF-45 cuts out when it gets hot.
what does do / not do
Posted on Jan 29, 2010
Therinnaiguy
  • 1420 Answers
SOURCE: I have a Sterling heater
ACE hardware, Tractor Supply, H Depot or Lowez should have what you need. Bring the old one with you. You may have to purchase one a bit longer, just keep the extra coiled up out of the way.
Posted on Mar 02, 2011
  • 4736 Answers
SOURCE: I have a sterling overhead heater QVF-75.Pilot
It's called the blower activation switch. It turns the blower on, when the heater reaches the proper temperature. The Thermocouple has nothing what-so-ever to do with the blower. It's simply a safety device for when the pilot goes out for some reason, it stops the gas from reaching the pilot. In other words, it locks up the gas control valve.
Most of the time, a "Limit Switch" stops the heater form overheating by shutting it down. However , these Sterling Heaters can be a little strange at times and what I would consider a limit switch, could be something different for Sterling. Check you Owners Manual to see what Sterling means by Limit Switch.
Hope this helps you to further troubleshoot the problem.
Posted on Apr 07, 2011
2004 sterling l7501 wiring diagrams
I am sorry but we do not have wiring diagrams, the material is copy protected.
Nov 07, 2012 | Sterling Cars & Trucks
Bought a sterling 75 c garage heater burner lights but then 24 v transformer burns out
I didn't find that model but did see a pretty standard wiring schematic for Sterling garage heaters in one installation manual. I'm sure they didn't change much. I did notice they use a 50va transformer, not 40 which is likely what is getting used now. Don't think that would fix it, just an idea. Put a 5 amp fuse inline on the red side of the secondary side of the transformer. This will protect it. I'm willing to bet the ignitor section on the low voltage common is wired wrong. Remove the tstat wires, buy a resettable fuse and install it first. Then get the fan running first. If there is a g terminal jump red to green. This is fan only, start simple, hope this helps
Jun 18, 2017 | Sterling RF75 Natural Gas Heater (75,000...
Need wiring diagram for a Sterling propane hot air roof unit radiator. Can you tell me where to find one?
Hi, go to the link below and download "Installation operation and maintenance", what you are looking for is on page 9. The downloaded file requires you to have adobe reader, if you don't have it, I'm providing a link for that as well. Hope this will help, and good luck!
http://www.sterlinghvac.com/sterling-gas-product-literature.asp
http://get.adobe.com/reader/
Jan 18, 2012 | Cars & Trucks
I have a sterling overhead heater QVF-75.Pilot fires up and main burners also.Fan does not start.I took fan off and found will run with direct power.I took thermal couple off and tested and it opens and...
Apr 07, 2011 | Heating & Cooling
I have a Sterling heater in my garage - Model QVF 30. The thermocouple has apparently gone out because the pilot will not stay lit. Do you have a replacement thermocouple, or can you tell me who deals...
Mar 02, 2011 | Sterling Heating & Cooling
YESTERDAY I BOUGHT A THERMOCOUPLER FOR MY QVF 45 STERLING HEATER. FIRED IT UP, NOTHING. BEFORE BUYING, I HAD PROBLEMS. I WENT TO THE WAREHOUSE THAT SELLS THE PARTS FOR MY HEATER AND EXPLAINED MY...
Loosen the thermocouple nut where it goes in the control valve. Re-tighten it only finger tight and with the appropriate wrench, turn it ONLY a 1/4 turn more.
If you have it to tight, it will not heat up and open the gas valve. Make sure not to cross thread it.
FYI: Gas control valves on this type of heater rarely go bad. Unless, the control knob is forced in an inappropriate way.
Jan 21, 2011 | Sterling RF45 Propane Gas Heater (45,000...
Noisy heater...flashing green LED light...Is there a problem?
with sterling , the flash could mean all is ok or the count of the flash could mean an issue,,,,,
without knowing your exact model i will send you here
http://www.sterlinghvac.com/html/literaturelibrary.asp
look for your model or design
and read the maint. section
this is what i use for all my sterling service calls
Oct 22, 2009 | Sterling RF30 Natural Gas Garage Heater
Sterling rf30 unit heater fan motro cycles on but unit wont fire.
Hi check out the pressure switch jump this out seeif itn lights check flame senser blow heatout with air line hope this helps
Mar 28, 2009 | Sterling RF30 Natural Gas Garage Heater
Heating & Cooling Logo
109 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
