Question about Microwave Ovens
How to replace door handle for kenmore 72185063010
Counter saver plus 62702 kenmore
If you repair a door assy. you are required per DHHS rules to perform a leak test on and around the door after such repair.
Oct 07, 2013 | Hotpoint RVM1435 Microwave Oven
I have a Kenmore microwave, model 721.62649200. The Handle to the door just broke off. I can find places online to buy a new handle, but I can't for the life of me figure out how to take the door...
I have a similar unit and I removed the outside of the door by loosening two flat head screws on the narrow where the handle is located. There are several screws yet holding the outside plastic housing too. Once these are removed the plastic door will come off. Then the handle will be accessible.
The same issue started with my oven too and I replaced the original handle with larger screws and using a high quality plastic glue.
This held for a while. The plastic door cover seemed to have changed dimensions during its life and warped. I ordered a new door and it lasted a short while. I then asked for a new door under warranty.
Bottom line they wouldn't sent a new cover but they returned my money. Apparently the doors all had crappy plastic issues. Currently we are using the microwave with out the door front. It still works like new after 10 years though.
Nov 12, 2012 | Kenmore 62622 Microwave Oven
How to change a handle
The door has to be split to replace the handle. The problem is that the door and seal are treated to prevent radiation leakage from the oven. Threat the inside of the door with extreme care because microwave rays are harmful.
Mar 04, 2011 | Kenmore Microwave Ovens
Door handle came off
To replace the handle the door needs to be split. Carefully remove the screws that hold it together and then prise the parts apart to gain access to the screws for the handle. Take care. The insides of the door are treated with anti radiation material and this should not be damaged. The door seal must also be treated with care for the same reason. You did not mention the model of your unit, so I take it that this is the correct procedure for your specific machine.
Feb 18, 2011 | Kenmore Microwave Ovens
Hadle from microwave broke
You will need to remove the handle from the door, remove the inner lining from within the door. now the handle can be taken out and replaced or mended with a super glue if broken( if part is difficult to obtain).
Once the handle is put in place make sure that the inner lining is put back in the correct order.
If the handle comes with the lock then the spring settings also should be reset.
Dec 30, 2010 | Kenmore Microwave Ovens
I have a Kenmore model #721.89940490 The door handle broke off and need to replace it, I do not see any screws. how do I access the mounting screws.
You will probably need to take the MW down and remove the outer case to access the hinge for the door.
just received a new door assembly for my Kenmore microwave and spent about an hour searching for help with installation to no avail. , but managed to replace it by prying the small pin out with a flat head screwdriver and removing the door. I reused the pin (after straightening it), and it works great.
The door handle is secured with the two screws from inside of the door. In order to access them you have to remove the inner door frame. You can find how to remove it in the video clip from one of our previous posts.
Aug 03, 2009 | Kenmore 62702 Microwave Oven
How to change the handle
To access the door handle mounting screws, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to simply pry the plastic up and work your way gradually around the perimiter of the glass. Most microwave ovens have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Simply remove the broken handle and install the new one. Re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
If you have questions, please let me know. I hope you find this information helpful.
May 14, 2009 | Kenmore 62702 Microwave Oven
Kenmore mirowave # 72162643200 handle is broken
I have the exact same problem and the cost for a tech to replace the door is $80 less than buying a new one. They have to remove the unit from the cabinets and pull off the exterior box to unscrew the door hinge. Mine is only 3 years old. I also bought a new oven range. Never really use it. Decided it was time to use the self cleaning. It did not work. $280 to put a new board in. 4 months later I went to clean it and again it did not work. The f*^ing thing only cost $500. Decided Easy off will have to do. Kenmore s*&ks
As for the door... I very CAREFULLY used super glue/ gel and it did the job!
Mar 27, 2009 | Kenmore 62643 Microwave Oven
Microwave Ovens Logo
54 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
