Question about Canon PIXMA iP1800 InkJet Photo Printer
Keep saying ink holders have not been inserted correctly
I have tried everything, even buying new ink holders and inserting them, but still the printer says they are not inserted correctly. Problem arose out of nothing.
  • tgravgaard May 20, 2009
    Yes, I have been using refilled cartridges, but this has worked without problems for a couple of months?
  • Don  Farrell
    Don Farrell May 11, 2010
    Are you using refilled cartridges or Canon factory new cartridges?
    Genius:
  • 1,018 Answers
Try using Canon factory new cartridges.
Canon does not support or allow the use of OEM cartridges on their products.
On the real bad side, you may just have voided any type of warranty claim from Canon.
Go back to the place you bought the cartridges and tell them their product damaged your printer and they need to fix it.
Posted on May 20, 2009
Why does my older version nokia keep saying insert sim
The SIM is the little card inside the phone. Do you have one and is it inserted correctly?
Aug 02, 2014 | Nokia Cell Phones
I have a C4240 All-In-One HP printer. I just put in a new black cartridge. The alignment page prints, however, when I scan it according to the direction, it fails. This has not happened before. I would...
This may be a long shot, however,have you tried to replace the old cartridge and see what happens?
Given that one may be out of ink, the printer may not accept "a call to print" as my hp printer, but I am thinking that either you may have a defective cartridge or otherwise somehow did not install the cartridge through the correct install method - meaning that if you manually slid the cartridge holder over to insert the new one, it may need to me manually moved back (typically hp has a button to depress to "call" the cartridge holder over towards the center to insert a new one...)
FINALLY -- if it is color - check the ink levels to be sure they have ink - my HP gets real finicky when the color cartridges are nearing empty...
Best Regards
Ck
Jan 05, 2011 | Office Equipment & Supplies
Canon MX700 printer ink lamp fast blinking
1) Insert both ink cartridges and then check the ink levels that way it will tell you if there is something wrong with them.
2) Make sure you buy 1 colour ink and the other black and insert them into the correct slots.
3) Contact your printers manufacturer by going on there website. They may have a live chat.
4) Try this link: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=15651
Nov 03, 2009 | Canon MX700 Office All-In-One InkJet...
Lid won't close. I started to put in a new bag but accidentally took out the plastic insert section the bag should attach to--so when I closed the lid over that, I must have pushed a little too hard. Now...
Your supposed to take out the plastic part that holds the bag but the way this unit is designed the lid will not close unless everything is inthere correctly so just make sure evverything in inserted correctly and keep trying! DO you still have your bag holder?
Jul 18, 2009 | Electrolux Harmony Canister Vacuum -...
Shows black ink empty after new cartridge inserted
Replacing the cartridge should resolve this problem: Follow these steps to replace the cartridge:
Installing / Replacing the BJ Cartridge Follow this procedure to replace the BJ cartridge:
1. Make sure the MultiPASS is plugged in.
2. Open the document tray.
3. Lift the document guides to open the ADF (Automatic Document Feeder).
If the ADF (Automatic Document Feeder) does not open easily, slide the document guides outward and then open the ADF (Automatic Document Feeder).
Or slide the Document Feed Lever to either the automatic or manual setting.
4. Pressthingtopress.gif. If installing the BJ Cartridge for the first time, skip to step 6.
Caution: Do not try to manually move or stop the cartridge holder since this may damage the unit. Do not touch the components shown or any metal parts since this may adversely affect operation of the unit and/or affect print quality.
The MultiPASS has an automatic protection feature that helps keep it from overheating. If the cartridge holder does not move, unplug the MultiPASS and let it cool for several minutes. Then plug it in again.
Press thingtopress.gifto move the cartridge holder.
5. Raise the blue cartridge lock lever on the cartridge holder and remove the BJ cartridge.
Caution: Discard the old BJ cartridge immediately according to the local laws and regulations for disposal of consumables.You may want to place it in a plastic bag to keep any residual ink from spilling. Spilled ink can stain any surface; protect yourself and your work area. If removing a BJ cartridge to use one of the optional BJ cartridges, be sure to store the BJ cartridge in the container provided with your MultiPASS. Otherwise the ink will dry and affect print quality.
container.gif 6. Remove the new BJ cartridge from its package, then remove the orange protective cap (1) and tape (2).
Caution: Discard the cap and tape. Never attempt to reattach them to the BJ cartridge print head. Install the BJ cartridge immediately after removing the cap and tape. Spilled ink can stain any surface; protect yourself and your work area.
7. With the label facing outward, insert the BJ cartridge into the cartridge holder. Lower the blue cartridge lock lever until it locks into position.
lockinpos.gif 8. Press thingtopress.gif.
The cartridge holder moves to its home position on the right side of the unit and begins cleaning the BJ cartridge print head. This process takes about 55 seconds.
9. Close the ADF (Automatic Document Feeder).
10. Close the document tray.
Note: If you need to unplug the MultiPASS, wait until the unit is in standby mode (date and receive mode displayed in the LCD). Otherwise the cartridge holder may not be in its home position causing the BJ cartridge to remain uncapped and dry out.
Apr 11, 2009 | Canon MultiPASS C530 InkJet Printer
The printer doesn't recognize the new original HP color cartridge
There is a small spring that holds the ink cartridge in the ink holder. You will see it stick out from the right hand side of the ink holder where the ink cartridge slides in. If that spring isn't being held to the ink holder by two plastic tabs, (I.E. the plastic tabs are broken) the printer will never recognize the cartridge. If the printer is still under warranty I would contact HP or an authorized repair center for HP. Both the black and color ink holder has this spring. I know of no way to repair this kind of breakage.
Jan 08, 2009 | HP OfficeJet 7310 All-In-One InkJet...
I need to change the ink cartridges on epson stylus sx200 but i need help as instruction book doesntreally tellyou how-thanks
buy an ink cartridge made specifically for your printer. Turn on your printer and raise the lid or press the cartridge changing button. 3 Wait for the cartridge carrier to slide out. with an Epson printer, lift the cartridge holder lid, and the cartridge will pop up for removal. Carefully remove the tape from the ink opening on the bottom of new cartridge. Insert the new cartridge into the cartridge carrier. Make sure the new cartridge is oriented the same way that the old cartridge had been. 7 Feel and hear the cartridge click into position. On some models, arrows will indicate the cartridge is correctly positioned. with an Epson printer close the cartridge holder lid and press the cleaning button to charge the cartridge. Close printer cover.
Dec 09, 2008 | Epson Stylus Multifunction Inkjet Printer/...
Just bought new ink for my printer; Canon MP510 it says it cannot recognize magenta....it is the correct one CLI-8m, it lights up, then I close the cover , it says processing, then it says the following...
Hi, please try reseating the print head.
*Confirm that the printer is powered on.
*Open the paper output tray and top cover.
Note: Gently open the paper output tray while holding it.
*After confirming that the print head holder has moved to the center, open the inner cover.
*Remove all ink tanks.
*Raise the print head lock lever and remove the print head.
*Re-seat the print head into the print head holder and lower the print head lock lever until a click is heard.
*Insert the appropriate ink tank into the slot at the right end and push down on the PUSH mark on top of the ink tank until a click is heard. Install the other ink tanks in the same manner.
*Close the inner cover and top cover.
Note: Check that each ink tank is installed in the correct position.
If issue still present call your printer manufacturer for service.
Tirzo
Jun 12, 2008 | Office Equipment & Supplies
Hp 2610xi not recognizing HP 97 color cartridge
If you look in the 96 (Black) cartridge loading area you might see that the retention spring has poked a hole in the circut board. I am now either trying to replace the ink cartridge holder or purchace a new printer. I have about $70.00 in new ink that I can't use now. The 2610xi worked great until the spring popped out of its holder.
Jun 10, 2008 | HP Photosmart 2610xi All-In-One InkJet...
Canon PIXMA  iP1800 InkJet Photo Printer Logo
76 people viewed this question
old marine
old marine
