Question about Compaq Presario Notebook
Toshiba Satellite A135-S2376, black screen problem
I was running my Toshiba Satellite A135-S2376 when the screen completely froze. The cursor wouldn't move, and I could not restart the computer with control-alt-delete. I held the power button until it turned off, but when I tried to turn it back on, the green power light would come on, as would the orange light in the CD/DVD drive, but the screen was entirely black, as if the computer weren't active. I tried running the battery out and recharging it, but the same problem continues. I didn't detect any unusual heat or smell before the screen froze. I'm still under warranty if all else fails, but I'd like to resolve this on my own.
  • 12 more comments
  • kiki101 Nov 20, 2007
    Yes! I'm having the same problem too. Its happened two times now in a matter of a week and i thought that my satellite laptop had just frozen, but the same thing happen to my computer. I would have to wait up to a full 24 hours to start the computer again.
  • cyborg 2
    cyborg 2 Dec 15, 2007
    I was working with my satelite A135 and slept off just to awake and behold a black screen. clt+Alt+del couldn't solve the problem so i powered it down with the power button. On trying to reboot, the green power ligth came on but The black screen was there to stay. up till date my labtop won't boot. Even shorting Jopen 1 couldn't solve the problem. Any other solution. please help
    Cyborg...
  • Anonymous Jan 05, 2008
    i have a toshiba satellite m35x-s149,when i power it on, no display, it beeps severally and stops.the eventually stops to run.
  • Anonymous Mar 26, 2008
    yes
  • Anonymous May 27, 2008
    Since the blank screen, frozen power light & Dvd driver light problem, My toshiba won't even come on for me to do the power management adjustment thing. Do I have to power the Labtop and leave it for 24hrs before the screen will come on?
  • Anonymous Jul 02, 2008
    i hade the same problen i turned it off then on and it stayed black plz help me
  • shaggboyz Jul 11, 2008
    Hi, all my is Sebit. I bought a TOSHIBA LAPTOP yesterday. However, I tried to turn the computer on but I could barely see the screen all I see was black black screen. This is weird!
  • willwiegman Jul 29, 2008
    Same problem on 2805-s301, turn on Toshiba screen, F2 screen, black screen with cursor nothing else but black.
  • willwiegman Sep 03, 2008
    I've since read that it could be a problem with the grounding tape they use to ground the screen to the frame, it is just sticky aluminum tape and comes loose.
    I'm going to try the '24 hour on'' thing since I'm hoping it might not be the ground wire. Will get back.
  • Anonymous Jan 01, 2009
    Same problem here too. My screen is black, my computer has a light that shows when its on, the lights on but the screen is still black. I tried turning it off and recharging it but the screen is still black...
  • jmkirk05 Jan 01, 2009
    My computernis on, but the screen is black. Like its frozen but the screen is black...
  • QuixtarJ Mar 01, 2009
    Toshiba laptop (L25-S1216) wont start in any mode including safe mode. When you turn it on it goes to the "black choice of starting screen" and then just turns black and thats it.
  • Anonymous Mar 14, 2009
    I HAD THE EXACT SAME THING HAPPEN BUT THE SCREEN STAYS BLACK EVEN WHEN I HOOK IT UP TO AN EXTERNAL MONITOR AS I THOUGHT THAT MAYBE IT BLOW THE INVERTER BOARD IN THE LCD ANY SERGESTIONS WOULD BE HELPFUL AS IM NOT UNDER WARENTEE .
  • Kei Kurooka
    Kei Kurooka Jan 13, 2014
    I had that too and all i did was plugging unplugging A/C adapter. then press the 0 while at the same time press the power on button. did that as many as i can then suddenly the screen light up first with colors running wild. then press the pwoer button off then again press the 0 and at the same time switch the power on while holding down the 0 button..
Just bought a Satellite & had same problem. Toshiba Support confirmed the 'Processor Power Management' fix. Within both the Min AND Max Processor State options you should set BOTH the Battery and Power Adapter options to 100%
Posted on Dec 04, 2007
Powered down, placed in freezer for less than five minutes, took it out, powered up, good to go.
Posted on Apr 03, 2011
  • jameshepenst
    jameshepenst Dec 09, 2012
    did that really work?
I have this same problem no screen at all at bootup. This occurred after the external monitor was disconnected and the laptop screen will not come back on It's a Tosh PSPA3E about 2 years old no bios at startup but everything else appears normal hard drive light power light keyboard fine. Its not the inverter because the screen does blink at start up but remains black. Disconnected battery BIOS still no difference, all connectors are fine
Posted on Aug 01, 2009
Doubt if this problem really has a solution.
The Power management thing may be of little help but What am sure of is, if your Toshiba freezes, Just power it down and don't touch it for the next 2 days. Then after, boot it (don't press any other botton or it may hang) and if the blank screen still appears just leave it there for the next one hour and Your Computer back.
If it still doesn't come on @1hr, power is down again for another 2 days and repeat same.
This problem is as a result of heat and data collision in the processor. Low memory too will contribute to the problem.
Posted on May 08, 2009
On a Toshiba Satellite A 100, I as well had the black screen problem. I used the power management change instructions listed further up and it seems to work.
Posted on Feb 24, 2008
I have same problem. Found this helpful discussion:
http://groups.google.com/group/microsoft.public.windows.vista.hardware_devices/browse_thread/thread/4e69bd243ac1c804/bf6c6be8d54f4611
Bottom line they are saying try:
If you are running VISTA, try going to the Power Options, advanced options, processor power management, and change the value of the minimum processor state to 100%.
I just tried this myself so not sure if works or not but others had good results.
Posted on Nov 26, 2007
  • 1 more comment
  • Tho Huynh
    Tho Huynh Mar 11, 2013
    How can you go Power options? BLACK SCREEN? SEE ONLY BLACK SCREEN!!!!
  • westnewyorkg
    westnewyorkg Apr 09, 2013
    Exactly! I keep seeing this everywhere and wondering how I'm supposed to do that when I have no screen.
  • westnewyorkg
    Exactly! I keep seeing this and the safe mode thing everywhere and I don't know how we're supposed to do that when we don't even have screens.
    Scholar:
  • 41 Answers
Just an fyi for others having the screen blank problem with their toshiba satellite; i was about to throw mine in the dumpster...had tried everything, then I realized that it might be something else.
I wear a magnetic bracelet for golf; I realized that this problem only happens when I am wearing the bracelet. Just a strange little coincidence that others might want to know about.
It has not happened since I took the bracelet off.
Posted on Nov 19, 2007
  • Compaq Master
  • 1,996 Answers
Most problems black screens are caused by blocket airiation
dust in fans wrong use (no flat underground) and direct sunlight direct on the laptop
Posted on Aug 25, 2016
    Master:
  • Compaq Master
  • 420 Answers
The most common problem causing that is an unreadable section in your ram,
swap the ram and try again, if multiple cards run on one then on the other, one may be bad
Posted on Mar 24, 2015
    New Friend:
Www.igoods.co.in
Posted on Mar 07, 2015
    Problem Solver:
  • 10 Answers
Friends,
Compaq Presario PC Notebook's main problem's are Audio Driver, Software Installation etc..
For these problems you can visit a link by just Click Here .
For any other problems with this Notebook you can Click Here .
Posted on Jul 22, 2010
**** Toshiba, it makes me frustrated all the time. My Satellite A135 turns black when I watch full screen videos
Posted on Sep 07, 2008
I also have a toshiba satellite notebook, love the computer but after a while it just would shut off in the middle of serfing the web or just using the computer. I noticed it was running hot. If you turn over your computer you will notice two small fans on the underside, when you place your computer on a flat surface the fans cannot cool of the computer properly, thus it overheats and shut off. I simply went to my local HOME DEPOT and picked up a package SHEPHERD SURFACE GRIPS 1-1/2 inches or 38mm. They are caled anti skid pads, I placed them under the four pads/legs that was built into my computer. it raised the computer about a inch, no longer overheats and dosent shut off...problem fixed
Posted on Jul 04, 2008
I have the same problem with toshiba satellite A110-ST1111. i cannot find this:
" STEP9: Under BALANCED click on CHANGE PLAN SETTINGS
STEP10: click CHANGE ADVANCED POWER SETTINGS
STEP 11: Scroll down and double click PROCESSOR POWER MANAGEMENT
STEP12: Under MINIMUM PROCESSOR STATE change both the on battery and plugged in percentages from 5% to 100%.
STEP13: click APPLY the OK"
pls i need help. thank you
Posted on Jun 06, 2008
Shoot a ******
Posted on Mar 29, 2008
No video but blue light on problem found on m35x-s161...
it has loose connection on pcb ...on solder someware
if u push down with right side next to the video connector on pcb and turn on will power up with video...but if u let go it will cut off video ..it is not a inverter proble....
Posted on Mar 07, 2008
Worked like a charm...ty ty ty a 1,000 ty's!
Posted on Feb 21, 2008
Yes I was in your position once with a brand new Toshiba satellite that went black every so often. This is a process to fix it as described by a Toshiba technition. If you don’t believe me or if you think this is fishy call them yourself.
STEP1: shut down laptop.
STEP2: unplug charger if plugged in.
STEP3:remove battery. (use switches labeled 1 and 2)
STEP4: Hook up acadapter (charger)
STEP5:turn on computer with no battery, only using ac adapter.
STEP6:Go to control panel
STEP:7 On left click classic view
STEP8: Click POWER OPTIONS
STEP14 shut down
STEP15:unplug ac adapter and put in battery.
STEP16: Plug in ac adapter
STEP17:REBOOT and PROBLEM FIXED!!!!!!!!!!!!!!!!!!!!
Congratulations, you will no longer have a annoying black screen popping up and pissing you off at the most random momments. Finally ...you can enjoy your laptop!
Posted on Dec 31, 2007
  • 2 more comments
  • Osama2812 Feb 05, 2011
    Solution 4 worked out perfect. Thank you!!!
  • fia2012 Jul 26, 2011
    This totally worked for my friend! I walked her through it on the phone. I have a Toshiba Satellite too! I printed this out for safekeeping! Thanks so much for making her night!
  • Carver Nordman Nov 13, 2011
    How do you go to control panel if the screen is black?
  • westnewyorkg
    Same thing. Can't go to the Control Panel when you've got a black screen.
    Novelist:
    Champion:
  • 256 Answers
The main cause for the Black Screen of Death error on your Toshiba Satellite A500 Series laptop might be the errors with the video adapter used on your laptop. You can fix the issue by rebooting the laptop in the Safe Mode. This will run the laptop without using the damaged driver and show the problems with it. If the laptop works properly in the Safe Mode, you can uninstall the video driver on your laptop to get away from the issues. You can use 'Device Manager' of the laptop for this purpose, as it brings up a list of all the currently available drivers as well as devices on your laptop.
Posted on Jul 29, 2011
Toshiba's latest bios v1.90 address this issue.
Posted on Mar 27, 2008
4 Suggested Answers
  • 8 Answers
SOURCE: Toshiba Satellite A135-S2376, black screen problem
first instinct u cooked sumthing
second try unpluging and removing both batterys ur nicad and the internal lithium 1
this shuld force bios 2 reset
if u cannot locate the internal battery un plug power and batt
w8 aprox 3days the internal clock will drain it 4 u
Posted on Apr 06, 2008
this is a known problem with this laptop,
it`s vga card have some kind of a major problem . so u cant do it on your own , go and make them give u a new borad -any yea u should go get dell in the first place :P-
Posted on Nov 07, 2008
  • 16 Answers
SOURCE: I was running my Toshiba
I've heard a lot about freezing problems on toshiba as well as others like this. Most common issues are one of two things. One is a damaged RAM module. The second is one of the video card chip sets have fried or are slightly overheating causing the laptop to shut down. Most common with Nvidea and ATI Radeon series graphics cards.
Posted on Jan 05, 2011
It ask me for a built in hdd1 user password.
if you cant remember the hdd password then you only have two options, contact toshiba (who will charge about £60 GBP) or buy a new hard drive and then reinstall windows on it
Apr 25, 2011 | Toshiba Satellite A135-S2376 Notebook PC
I was running my Toshiba Satellite A135-S2376 when the screen completely froze. The cursor wouldn't move, and I could not restart the computer with control-alt-delete. I held the power button until it...
Jan 05, 2011 | Compaq Presario Notebook
It sounds like they had something with that last entry; if you've used it a while it's common for the wires connecting the screen to the machine to fail, resulting in about what you described. Of course you've tried the monitor hotkey (for switching simultaneous/separate display with connected monitors) already as well as closing/opening the thing to see if the display reconnects for the moment....
Otherwise it's pretty vague what might be wrong; it could be a PC CARD cellular interface came out a bit or caught EMI, knocking out the system board (permanently or not) or any number of screen (and connection) related issues. Try running with an external monitor, looking for junk in your laptop's ports, and certainly swapping out your hard drive with one you don't mind sending for warranty service (or at least completing some sort of backup on another machine.)
Jan 05, 2011 | Computers & Internet
Labtop no screen
make sure that the battery is charged. Take out the battery, wait for 15 sec and insert is back. Now try again.
Apr 02, 2009 | Toshiba Satellite A135-S2376 Notebook PC
A135-s2276 wont switch on
Try contacting Toshiba, as it may be some sort of a harware issue with the touch pad or currupted driver, as you said it worked for two years running XP.
Good Luck.
Mar 24, 2009 | Toshiba Satellite A135-S2276 Notebook
Toshiba A135-S2376 is suddenly asking for password after power on ..... whats the solution
Well good news and bad news.
This is a problem that toshiba has knowledge of.
You cannot do anything to reset the password.
But you can contact toshiba and they will give you an address of a authorized dealer and they should repair it at no cost.
What it is the bios needs to be updated to version 1.40
It fixes that bug.
Happy Holidays
Dec 24, 2008 | Toshiba Satellite A135-S2246 Notebook
have u tried to power up with external monitor? reply back.
Oct 26, 2008 | Toshiba Satellite A135-S2386 Notebook
Toshibba laptop a135-s2276 ,my mother bords smd chip does not work so display of screen does not appear
The problem is well known witht this model Toshiba - the problem is the fan stops working and then hence shuts down to prevent overheating - it does not take long once the laptop is hot. Without replacing the fan just reboot the laptop until you hear the fan start again on reboot.
Oct 15, 2008 | Intel Motherboard
Frozen Cursor
Have you tried pressing <FN><F9>
May 30, 2008 | Toshiba Satellite A135-S4527 Notebook
Apr 05, 2008 | Acer Aspire 5100 Notebook
Compaq Presario Notebook Logo
43,862 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
