Question about Craftsman Saws
How to close blade on craftsman 10 in 1 lighted multi tool ? #39045
I have one. It is a locking style blade. There is a lock that you need to push to release it. The lock looks like another tool next to the hinge of the blade. Push it against the base of the blade.
Posted on Dec 29, 2014
3 Suggested Answers
  • 80 Answers
SOURCE: How to change blade on 10" Craftsman table saw?
you need to grab the blade with something.maybe some pliers(if you are not going to refurbish blade) and loosen the nut in the center of the blade. i think it is a left hand thread(cw to loosen) because of the rotation of the blade. if the nut is on the left when looking from the front it is probably left handed. make sure it's unplugged and wear leather gloves so you don't get cut. install in reverse...
Posted on Jan 20, 2009
woobie dog
  • 1273 Answers
SOURCE: How do I change the blade on a Craftsman 10"
Hi Tom, W/D here.
There are usually three different ways that blades are installed and/or removed. All require that the power be removed from the saw first (pull the plug, please).
1. The most common method involves a shaft lock, so look for this first. It will appear as a button on the motor, near the blade. When you depress the button, you'll need to rotate the shaft/blade by hand until the lock sets in place in the shaft. Then, while still holding the shaft lock button down, use a wrench to loosen the blade. (Look at the threads to make sure that you are turning in the right direction, as this may be reverse threaded).
2. Less common is a shaft that has an allen socket in the end of it. Place the loosening wrench on the not, then place the allen wrench in the end of the shaft.
3. If all else fails, you can, VERY carefully, wedge the blade down into a piece of soft wood such as pine, then loosening the blade with a wrench. Make very sure that you keep all of your bodily parts out of the line of fire when using this method, as the blade can turn suddenly, and you don't want to have anything caught up and cut by the blade.
Hope this helps, Best regards, --W/D--
Posted on Nov 05, 2011
How do I replace the tool-less blade clamp in a craftsman 8 amp reciprocating saw
Craftsman Reciprocating Saw replace the tool-less blade clamp
Jun 10, 2015 | Craftsman Saws
Craftsman saw mod # 113-298051
The blade is able to be set to different angles by the handle under the front edge of the table. There is a lock handle to keep the angle set correctly. Loosen the lock handle, press a square (90 degree tool) against the flat of the blade - not the teeth - then lock the blade in place.
Craftsman 113 298051 Owner Manual rr
Jun 17, 2014 | Craftsman 10" Table Saw
Does the bolt turn R or L also does it take a special tool. I have had this saw for 28 years and my guys changed the blades I fear they lost the tool. Also will a 10" blde work it has a 71/4 now
The bolt on your saw blade turns right. Hold a block of wood against the blade so the bolt can turn. You can use a adjustable wrench if it will fit. Otherwise see if an open end wrench will fit. The 10" blade will only work if the saw was designed for a 10" blade and there is enough clearance.
Mar 14, 2011 | Craftsman Saws
Sabre saw- craftsman - 17256 - change blades
This saw uses a tool-free blade change. 1. Unplug the jigsaw 2. Place your finger on the lower edge of the see through blade guard, and pull it forward until it locks up in place 3. Lift the tool-free blade change holder (bright yellow piece above the blade), and insert the blade into the slot of the tool-free blade change holder. 4. Release the tool-free blade change holder to lock the blade in place. 5. Pull down on the blade to verify that the blade is securely locked in place. The teeth of the blade should be pointing forward and down. 5. Put the blade guard back down.
You can use with both 'T' & 'U' shanked blades.
Feel free to ask me any other questions about this saw.
Jan 06, 2011 | Craftsman Evolv 45 amp Jig Saw 17434
How to change a blade in a sears 10" compound miter saw
there should be a spindle lock on this tool, lower the blade guard without removing and hold the spindle lock and the screw is usually left hand thread.
Aug 31, 2010 | Craftsman Saws
Replacement blade
Use a 10" blade. As for the number of teeth...the more teeth the finer the cut will be. The only drawback is a a finer toothed blade will cut slow. For your purposes I'd suggest a fine toothed blade.
Mar 07, 2010 | Craftsman 10" Table Saw
Saw stopped working mid-cut as if power loss. Blade turns freely, was no unusual odor. Reset button no help. No problems prior to that event. This is a Craftsman 10" table saw.
Could be the motor burned out. That shouln't happen and if it did craftsman is really good at replacing damaged tools. I'd return it for a replacement.
Mar 04, 2010 | Craftsman 10" Table Saw
Have a 10'' miter saw from craftsman. Motor runs but blade doesn't turn. Is it fixable or do I need to just get another one?
I have tried that number in numerous sites and nothing comes up. Can you recheck and I will try again, but in the meantime, make sure the blade is tight (unplug tool) try turning the blade by hand and do you feel resistance. Is this a belt drive and if so what is the condition of the belt and tension. Let me know and I will do what I can
Mar 20, 2009 | Craftsman Saws
Jan 20, 2009 | Craftsman 10" Table Saw
Replacing the blades on a craftsman dyt 4000
Not a hard job, but you will need a couple of tools. First, you will need a wrench that fits the nut that is holding the blade on. I prefer a closed end wrench, but an open end will do. Second, you will need a blade changing tool. The brand name is called a Blade Hog. It attaches to the deck and holds the blade in place so you can turn the nut. Raise the deck as high as it will go, attach the Blade Hog, and then loosen and remove the nut. Be sure and pay attention to which side is up on the old blade and put the new one on in the same manner.
hope this helps,
c
Sep 21, 2008 | Craftsman Garden
Saws Logo
61 people viewed this question
Top Craftsman Saws Experts
Mike
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
