Nakamichi zx9 During play speed slows down half way the cassette.
5 Suggested Answers
robotek
  • 1512 Answers
SOURCE: NAKAMICHI CASSETTE DECK 1 NOT PLAYING?
it has probably thrown the capstan belt and will require a new belt fitted. the transport relies on capstan rotation to engage play. a separate reel motor operates ff/rew and takeup funtions
Posted on Dec 09, 2007
  • 319 Answers
SOURCE: Connecting Nakamichi 600 cassette deck to speakers
You must have an amplifier or receiver to connect between deck and speakers. The deck has no power amp
Posted on Aug 03, 2008
Grubhead
  • 5190 Answers
SOURCE: Some of my old cassett tapes slow down & speed
The only thing you can do is take the tape out of the cassette and place it in a modern cassette case. Just buy new blank tapes and discard the new tape inside. If that doesn't work and it's not your player causing the problem then it's due to the tape itself.
Posted on Apr 05, 2009
skywavebe
  • 1258 Answers
SOURCE: the motor tape deck nakamichi speed up after a while in operating
Your capstan motor may be so badly worn that it is time for a new motor. Motors that are old and worn usually do speed up until the brushes break inside and the motor just stops. You do not state the model but there are guys that still work on them.
Posted on Dec 06, 2012
My sony cfs-w360boombox plays tape at high speed upon play, normal or high speed poition
there may be 2 possibles
1, the pinch roller is not going down and staying in the fixed when during playback, easy way to check power down the unit, press play and see if it looks firm, it will push back, if working right
if its loose, it may well have come off a little sping, and may well be an easy ish fix, by someone who know about cassette decks,
2, the speed adjustment has failed, there will be an internal speed control, which keeps the playback at a correct speed, if this has failed it may be fixable, but only by someone who can take it to bits and remove and solder a new one in, and they are very small and Sony items i have had have failed on speed control! too for me its a junker box
good luck
Sep 24, 2013 | Sony Boom Box With CD Player & Cassette...
Nakamichi DR 10 does not eject. I loaded a cassette, pressed 'Play' the cassette played 10 seconds and stopped. The display showed 'ERR'. I removed the cover, nothing immediately obvious. The cassette...
The DR1o might have a Sankyo transport and they have sense fingers that become tarnished. This needs to be serviced to make the deck work. It is possible that the deck is still in play mode which blocks the eject from taking place. Unplug the unit and open it up and rotate the worm gear with a finger and the door will eventually open up but do not force things as understand the size of motor in the unit that normally turns the worm gear.
Sep 19, 2013 | Nakamichi Audio Players & Recorders
My sony walkman WM EX-190 is playing at low speed than normal. I changed the belt. bot still it is not playing at normal speed.
its maybe a failed speed ajustment or its slipped there is normally a tine whole on the back under the belt clip, press play and insert a small screw driver and turn u should find it speed up or slows down, if not its failed, but please be careful they are delicate anyhow
Jul 31, 2013 | Sony Audio Players & Recorders
Nakamichi BX 300 tape deck runs slow in play,belts and idler have been replaced
There is an adjustment in the motor that sets the speed however you need to have a frequency counter and speed alignment tape to adjust the speed correctly. There was also suppose to be oiling of the mechansm at the time the belts were put on.
Jan 05, 2013 | Audio Players & Recorders
Recording Speed
the tascam 414 is a 4 track recording studio which uses standard cassette tapes- meaning they only play in one direction, because the tape is full. The 414 records at double speed so that recording fidelity is increased. When you have made a recording you want to mix you then dub your recording though the outputs into another standard tape recorder or whatever you have available, be it a cd recorder or your PC. So, when you listened to your recording on a standard tape player, you were not only hearing it at half speed but you were only listening to 2 of the 4 tracks. The other tracks would only be heard if you flipped the tape over, and they would be heard running backward. I would have though the 414 had a swich to allow it to also record at standard speed to but I guest it does not.
Jan 10, 2009 | Tascam Starter Pack for 4-Track Cassette...
Nakamichi BX2 will not take-up tape and play
This may be a reel sensor problem, or the rotation of one of the reels is stopping for some reason. Most of the time, these faults are mechanical. There can be worn belts, or drive wheels, or gears, and etc. Sometimes there are faults in the electronics where a sensor is not being read properly.
The unit should be properly checked to evaluate the fault.
Jerry G.
Apr 06, 2008 | Nakamichi AV-10 Receiver
Dec 06, 2007 | Audio Players & Recorders
Motor plays at a very slow speed
capstan belt may be failing. check this by removing lid and touch the capstan flywheel when running. if it is easily stalled/slow to come up to speed and or the belt slipping badly then belt will require replacement.
Oct 14, 2007 | Sony TC WE435 Stereo Dual Cassette Deck...
54 people viewed this question
 Grubhead
Grubhead
