Question about Other Sports Afield Executive Gun Safe Vault SA6033 60x33x20 Black
I cannot locate the serial number on my Sports Afield SA6033 gun safe.
If there is a power failure will my Sports Afield safe still open?
don't know try putting in the model and numbers so we can help do a search for you
Oct 10, 2017 | Power Home Security
I have a bicentennial Remington 760 30-06 gold inlay serial number A7148148
https://gundigest.com/rifles
Tip be cautious of posting serial numbers online
The prices are a bit high but they list serial numbers and dates Good Luck Stay Safe
Apr 02, 2017 | The Optics
How do I search for a gun using the serial number
Follow these five steps:
    • 1 Locate the serial number for the gun you want to check. If you are purchasing a gun or checking one that is already in your possession, you can check the documentation that came with the gun. In many cases, the serial number will be noted in the owner's manual. If you don't have the owner's manual you will need to locate the serial number on the body of the gun. The serial number is usually located on the handle or inside the gun, but this does vary from manufacturer to manufacturer.
    • 2 Contact a reputable gun dealer in your area and ask them to run a serial number search for you if you're looking to buy a gun from a private party. In most cases, the dealer will charge you a small fee for this service. However, this is often the fastest, simplest method. Many gun dealers will be able to give you basic records about where and when the gun was registered.
    • 3 Check your local department of law enforcement's website to see if you can run an online gun serial number search. Some states do not maintain a database that individuals can access, so this method may not work in all areas. If you can't find the database, contact a law enforcement representative and ask if an online gun serial number search can be performed in your state.
    • 4 Contact your local police department or sheriff's office to run a gun serial number search if you are looking to purchase a pre-owned gun from a dealer. Police records will indicate whether the gun has been used in a crime or has been reported lost or stolen. Checking the serial number with the police department or sheriff's office is beneficial if you're considering buying a gun from a dealer because they can quickly check whether a gun was used for a crime or reported stolen in all states using the national ATF database.
    • 5 Check the Gun Verify database if you are purchasing a pre-owned firearm from a dealer or individual to make sure that it is not stolen. Gun Verify is a user-based database, meaning gun owners input their own information if their gun is lost or stolen.
Mar 05, 2015 | Marlin Model 60 .22 Long Rifle 19 Inch...
Sports afield 6040 executive vault how to reset combination
Spot Afield safes default code is 1,2,3,4,5,6. Open the safe door, with door open lock the handle. This will let you have assess to your things if you have trouble while setting the codes. To change the code, press the * 6 times. You should hear a single beep and one flash from the LED, then enter the default code 1,2,3,4,5,6. Again you should hear one beep and see one flash. Enter the new code you would like to use ...lets say 6,5,4,3,2,1. You should hear one beep and see one flash. Enter the new code again 6,5,4,3,2,1. The code should now be set to 6,5,4,3,2,1. Try the new code and see if it unlocks the door. Also try the old code to make sure it no longer works.. If at any time during the process you hear 3 beeps and flashes something went wrong. You will need to start over.
Good Luck!!
Jun 30, 2014 | Other Sports Afield Executive Gun Safe...
Where can I find the serial number on this item?
The serial number may be inside the heat gun
Jun 19, 2013 | Tools & Hardware - Others
How old is my remington double barrel shotgun-serial number-18000
Dear Armstrong.
GO to the NRA serialization document's offered in the following link. It offers a variety of weapons manufacturers with detailed coding in a chart line item method. Here is the link. http://www.nramuseum.org/media/940941/serialization-date%20of%20manufacture.pdf .
Along with that is offered a sample of the stamping of information on the barrel for your convenience.
http://www.remingtonsociety.com/questions/BarrelCodes.jpg
Remington Dates of Manufacture
Blue book of gun values at this link.
Blue Book of Gun Values REMINGTON ARMS COMPANY INC HANDGUNS 1857 1945...
Fare. Well.
Jan 06, 2013 | Remington Sports Remington 12 Ga...
Battery flat lost keys how do i open safe gx b0709
Most of these safes come with a default setting. Try entering 0000.
otherwise you will need to locate the serial number and contact the manufacturer.
Jul 25, 2010 | Safe International Digital Electronic Safe...
Digital Electronic Safe Lockbox Gun Jewelry Lock Box Tool: lost key: Sentry 1100 strong box....
To order replacement keys, for small chests and files, you will need to know the key numbers which can be found right around where the key goes in. It should be a stamped number, letters, or both located around the keyhole. For Personal, Home and Home/Office Safes, you will need the model number and serial number. I think that the most economical place to buy keys is from www.SentrySafeShop.com. You can do a search for "lost keys" and it will give you a screen where you can enter your model number and key number. (It is a very easy screen to use. They just need 1.)Model # and 2.)Serial or Key #.)
In Summary:
For Small Chests or Files: A lock reference number is required. It will be a letter, a number, a letter and number, or "blank" (no letter or number), engraved/located on the silver cylinder of the lock. These are model numbers 0500, 1100, 1170, etc...
For Personal, Home and Home/Office Safes: (model numbers will begin with: S0, S3, S4, S5; I0, I3, I4, I5; A3, A4, A5; J3, J4, J5; L0, L3, ,CS,CSW,DA,DS,KS,KSW,MS,MSW,OA,OS,and SC): Indicate your model number and the safe serial number found on the front right-hand side of the door, between the hinges.
Here is the direct link to the key replacement screen: http://www.sentrysafeshop.com/Keys-Sentry-Safe-Replacement-Keys-p/keys.htm
May 18, 2010 | Safe International Digital Electronic Safe...
Where can i find the serial number for a gun
Serial number postings on firearms vary by manufacturer. Check makers website for locations. Older or antique guns may not have one. Of course
there is always a chance someone may have eliminated it but there should be some evidence of that. A respectable gun dealer shouldn't charge you to take a look at it.
Feb 27, 2010 | Sport & Outdoor - Others
Other Sports Afield Executive Gun Safe Vault SA6033 60x33x20 Black Logo
131 people viewed this question
Top Other Home Security Experts
Lawrence Oravetz
Are you an Other Home Security Expert? Answer questions, earn points and help others
