Question about Toshiba Satellite A300-0CF035 Notebook
Switched off at random twice yesterday and is running way slower
1/ the screen flickers alot now - so back light connection? 2/yesterday first time it happened- the laptop just switched off at random 3/thank you
  • 2 more comments
  • bajbansal May 20, 2009
    the cpu shut down out of the blue
    i had a black dos screen come up with the usual safe mode options or start normally
    after that it loads only it appears to be running slower (memory?)
    the flickering occurs more frequently now but after the cpus been on a while (could it be the connections?)
    i am using norton and have spybot done the scans haven't found anything so its all quiet on that front
    seems to be working ok atm
    (fingers crossed eh?!)
    thanks for helping us out
  • Art Ellison
    Art Ellison May 11, 2010
    If the screen is flickering a lot, it could be the backlight--does it have a manual brightness switch (like a slider switch)?
    It also could be the video card, but I'm inclined to think it's the flourescent backlight.
    You say it turned off by itself? Did the monitor just go black or did the computer actually shut down?
  • Art Ellison
    Yes, it could be the connection to the LCD, but one thing I would try is to blow the dirt out of all the spaces in the computer that might affect cooling.
    Have you tried, also, to run disk checking for errors (scandisk)?
    Another question (maybe silly, but...) are you running a good anti-virus product? Have you been scanning for viruses. You might want to try one of the online scanners just in case. You can use Trend (www.trendmicro.com) or Panda (www.pandasoftware.com)
  • 2,229 Answers
NP--Whenever I find that type of problem, I first suspect malware, then power or heat, and then maybe programs that just shouldn't be running.
Try running MSCONFIG. Shut down programs or utilities that you don't recognize.
Posted on May 20, 2009
We just received a camera clock and we cant get it connected to WFI. We have been working on thisfor hours, the only time we can work on this is evenings.
WIFI connection method:
1. Switch the power button to turn on, then long press the play key until the blue light on(30 seconds later, blue indicator light start flickering, then the clock camera is turned on , and then red indicator light will flickering, which means the clock camera WIFI signal is opened)
2. turn on the WIFI on your smart phone . Run APP software that you have downloaded and installed
Dec 12, 2017 | Car Audio & Video
Engine is running badly, struggling to start, 2 cylinder exhaust tube is red hot, the engine has no power, everything is good between the sensors. someone something like that happened, the timing chain...
1) Adjust the ignition timing according the specification manufacturer.
2) Readjust the GAP for spark plug, with the s. manufacturer.
3) See for loose , break, or burn wires, corrosion, dust, dirty, vibration, solenoid defective, relais, starter, alternator, battery system. Look for diagrams for troubleshooting. GOD Bless you.
5_25_2012_10_33_50_am.gif5_25_2012_10_34_10_am.gif5_25_2012_10_34_29_am.jpg5_25_2012_10_34_52_am.jpg5_25_2012_10_35_13_am.jpg5_25_2012_10_35_56_am.gifYou can connect remote start switch, side +to the battery, and the other side to the terminal solenoid, must be RUN,and isolate and fix it according your logic.
May 24, 2012 | 1996 Toyota Previa
What is causing my interior light to flicker when driving on rough roads/streets? This just started yesterday
There are micro switches in the doors called DOOR AJAR switches. These switches go bad alot . The car thinge the door is not closed and often makes the door chime ring
Mar 27, 2012 | 2002 Chevrolet TrailBlazer
Flashing dome light, broken horn, and slow windshield wipers... what can it be?
if your hearing a clicking sound when pushing the horn button then it sounds like you need to replace the horn the diaphram is probably no good.if it was a bad connection you wouldn`t hear a clicking noise.the slow wipers sounds like it could be a poor ground on the wiper motor.you can run a separate ground wire to the wiper body and if the wipers work at a normal speed then that is all you have to do.if not then the power wire needs to be checked for battery voltage if its good then the problem is likely the wiper motor itself.the flickering interior light may be the light switch maybe moving just enough to make contact to allow power to the light.make sure the switch is into the off position and see what happens.
Jan 10, 2012 | 2004 Pontiac Sunfire
I have an HP compaq presario cq71-230sa. Laptop worked fine a few hours before, and then when I lifted the lid, the screen was black with 2 lines of white dots running down the left hand side, and the...
Can you check the function buttons and make sure the primary display is set to show the output on the laptop. Try repairing your OS. If not then re-install the os. As you are saying till the time windows gets loaded, all works fine so it seems the issue isn't really the hardware.
Jul 18, 2011 | Compaq Presario 700 470024-192 Notebook
Cannot set time @ date for Ohsen watch...AD0721...thanks
(A=LIGHT,B=MODE,C=START,D=RESET)
1.How to use the luminescence Any time indication,Press A the Luminescence will last for 3 seconds.
2.How to view date? Standar time indication, press C "month/ date" indication.
3.How to switch 12/24 hour systems In the normal mode, press B twice and press D twice ,then hold C until 24 hour system is actuated, then press B for recovering.
4.How to check alarm ring and alarm time? Standard time indication,press D alarm time indication.
5.How to set alarm time? Standard time indication,Press B twice. The hour area flickers,press C to set the hour. After setting hour ,press D,the minute area flickers, press C to set the minute. Last press B for recovering.
6.How to set alarm ring? In standard time indication mode ,Hold D then Press C this will toggle alarm symbol on & Off.
7.How to set Hourly Chime? In standard time indicationmode, Hold D then Press B DAY OF WEEK area toggle on and off.
8.How to use stopwatch(1/100 seconds) Press B,then Oress C for 1 timing; Press D for multiple timings. Press D once more to continue operation after multiple timing. Press D for 1 timing; press C once and press Dtwice for multiple timing. (1)Max range of the stopwatch is 23 hours 59 minutes 59 seconds. (2)When timing within 30 minutes, the watch indicates: minute/second/1/100 second (3)When timing beyond 30 minutes, the watch indicates:hour/minute/second
9.How to adjust time, date,day of week (1)Standard time indication,press B twice ,the second area flickers, pressC to adjust second. (2)Then press D the Minute area flickers,Press C to adjust minute. (3)Press D the hour flickers, press C to adjust hour. (4)Press D the Date flickers, press C to adjust date. (5)Press D the month area flickers, press C for adjustment. (6)Press D the Day of Week area flickers, press C for adjustment. Then press B for recovering.
Nov 30, 2010 | Watches
Panasonic plasma tv doesn't turn on, red light flickers twice
hi look for any swollen capacitors, also plasma's do suffer from poor solder joints on the power board, so check for any rings around the solder pads, test the voltages on the white connectors with a meter the voltages will be written along the connector,thanks
shaun
Mar 01, 2017 | Panasonic Viera TH-50PZ85U Plasma TV
Shuts off randomly.
do red lights show up? if so look up red light errors ten ask about a fix for that specific error.
Nov 28, 2009 | Microsoft Xbox 360 Console
Dell Inspirion Laptop Screen Randomly Flickers, Then Blacks Out
not to get to concerned just yet, a few tips, when you press on the top of the laptop case by the screen area in the back of the laptop do you notice the screen flickering off? and when you let go dose it come back on? if so this can be a faulty wire or bad inverter, they are actually both very simple to fix and relatively cheap fixes.
Aug 20, 2009 | Dell Inspiron 1100 Notebook
Panasonic PS/NS-GS200 - Some enquiries!
1. try changing your screen refresh rate. 2. yes, it is called EIS. you can switch it on from the menus. The EIS does not work well in low light. a tripod is your best bet for a steady camera. 3. the backlight feature back lights the LCD screen only. to shoot in low light switch the camera mode to manual and change the menu setting to low light. the magic pix mode will help you shoot in the dark but any movement will become blurred. Again, best to use a tripod in this situation. Detailed information for items two and three should be in your manual.
Sep 06, 2005 | Panasonic AG-185 Camcorder
Toshiba Satellite A300-0CF035 Notebook Logo
127 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
