Question about Craftsman 25cc Gas Line Trimmer
The starter line on my trimmer will not pull at all.
Troy-Bilt model tb525cs gas trimmer. Has been working fine recently.
I took it out to work and the starter pull line will not pull enough to start it.
Remove spark plug to see if problem is in engine or drive unit
Posted on May 22, 2009
Runs great, blower and trimmer heads will not turn/work. Tried using the blower attachment and the fan turned very slow
Contact the consumer desk.
TB22 EC Curved Shaft String Trimmer by Troy-Bilt
www.troybilt.com/.../troybilt/TB22EC-trimmer
Troy?Bilt Products
Rating: 3.7 - ‎232 votes - ‎$99.99 - ‎In stock
25cc, 2-Cycle Gas Trimmer / Attachment-Capable Design ... The TB22 EC gas string trimmer is both JumpStart™ and TrimmerPlus® attachment capable, making ...
Gas Trimmer ' TB635 4-Cycle Curved Shaft ... - Troy-Bilt
www.troybilt.com/.../troybilt/tb35-ec-curve-shaft-gas-...
Troy?Bilt Products
Rating: 3.3 - ‎32 votes - ‎$179.99 - ‎In stock
The TB635 EC curved shaft gas trimmer with SpringAssist™ technology features the new Click N Trim™ bump head, making line replacement easier than ever. ..... next one they put on - will only run for about 4 seconds. they've had for about 2 ... Both String Trimmer and Edger work great, easy to start and very low vibration.
Dec 09, 2015 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
My troy bilt trimmer tb20sc rope is hard to pull. It all of a sudden stopped working. Took it all apart. Pull on rope off of trimmer,it still works fine. Took off spark plug, piston is moving up and down....
Jard you need to check that the bottom head is clean and there are no obstructions. Then check that the coil is in tight and the nuts are not loose. Finally have you been using the correct fuel mix? Clean the fly wheel with some lubricant spray and sand paper and re assemble.
Aug 31, 2013 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Troy-Bilt TB70SS will not start
Hi. Go to any auto parts store and get a can of starter fluid. Have a helper squirt a little into the air cleaner while u start it up. Then continue to squirt the starter fluid to keep it running until the engine sounds good again. J.
Jul 07, 2010 | Troy Bilt Tb70ss Gas Trimmer
How to change trimmer ine in tb525cs - troy built 4 cycle trimmer
You need to unscrew the black bumper button. I believe it is counter-clockwise. Mine was very tight and took a pair of channel lock pliers to loosen.
Jun 21, 2010 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
What is the fuel line size for Troy Bilt TB525CS Trimmer?
Yes, something special to know. If the new fuel line is going into the gas tank, be sure to cut a steep angle on the end of the line going into the gas tank. This will allow enough of the line to get into the tank where you will be able to grab it thru the gas fill opening with needle nose pliers and pull it thru.
Apr 14, 2010 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
What size string do i need it is a tb525cs
Probably .065 to 080 line will probably do the trick .A line with 3 or 4 edges works great on everything
Oct 21, 2009 | Troy Bilt Tb70ss Gas Trimmer
Troy-Bilt TB525CS Line Keeps Being Sucked into Housing
You may have wound the line in the wrong direction. Check it out. We all do it at least once...Lee
Sep 09, 2009 | Garden
Pull Cord won't pull on model TB525CS
Hi try this web site its called pats small engines shows exploded view
Jun 02, 2009 | Troy Bilt Tb70ss Gas Trimmer
TROY BILT TRIMMER MODEL TB70SS. HOW DO I REPLACE
Is the pull rope in the front or rear of engine.Thinking that the string is in the front,you must throttle housing and shaft from engine. remove starter housing. There sould be a screw holding the string and spring in place.
May 07, 2009 | Troy -Bilt String Trimmer/Blower...
Craftsman 25cc Gas Line Trimmer Logo
292 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
