My car continues to stalls at stop lights and when idleing still and or low. Recently I have changed both fuel filters in the gas tank and engine, installed new spark plugs and wires, bought a new battery, used gas/fuel treatment solution, changed the oxygen air sensor and manifold, and purchased and installed a rebuilt engine and tranny. My cars problem with consistent "stalling" continues to exist without any hope of resolution.
PLEASE ASSIST!
Try this procedure and let me know if it cures the problem.
Here is the common cause of surges, stalls at stops, slow idle speed, erratic idle speed, rough idle and engine hesitation (and other problems), it is in most cases the idle speed control air-bypass valve and or throttle valve and upper intake, these area's get full of gunk and combustion residue over the miles and cause idle issues (stalls, low idle) like yours, Get a can of intake cleaner from any local parts store, not carb spray, intake cleaner, it is made by a company called CRC, remove the air intake hose to the engine, hold the idle high so the engine won't stall, then spray the can of cleaner into the intake while keeping the engine running, use at least 1/2 the can, shut down the engine and disconnect the battery for 5 minutes, then restart and complete a number of mixed driving cycles, town, freeway, stop and go etc., after a few days the problem will go away as the system will relearn to the clean intake.
It
can be low fuel pressure issue or clogged fuel pump. Or its engine related
issues,---------------
Check
the help link mentioned below to troubleshoot the problem: ------
Engine stalls when gas is given?
http://technoanswers.blogspot.in/2012/01/engine-stalls-when-gas-is-given.html
Car stalls when MAF sensor is connected?
http://technoanswers.blogspot.in/2012/01/car-stalls-when-maf-sensor-is-connected.html
Car Engine Stalls While Driving?
http://schematicsdiagram.blogspot.com/2011/12/car-engine-stalls-while-driving.html
Car stalls and throws white smoke from exhaust?
http://repairhelpcenter.blogspot.com/2012/01/car-stalls-and-throws-white-smoke-from.html
Stalls And Dies At Stop Sign?
http://www.howtobyme.blogspot.com/2012/07/stalls-and-dies-at-stop-sign.html
GMC Sonoma Stalls and idles low
http://technoanswers.blogspot.com/2012/10/gmc-sonoma-stalls-and-idles-low.html
Nissan Pathfinder stalls and bucks on Acceleration?
http://technoanswers.blogspot.in/2012/02/nissan-pathfinder-stalls-and-bucks-on.html
1992 Chevrolet stalls and shutdown?
http://schematicsdiagram.blogspot.in/2012/04/1992-chevrolet-stalls-and-shutdown.html
Stumbling and stalling at idle after engine rebuild?
http://schematicsdiagram.blogspot.in/2012/03/stumbling-and-stalling-at-idle-after.html
1990 mazda 323 stalls and quit running?
http://technoanswers.blogspot.in/2012/02/1990-mazda-323-stalls-and-quit-running.html
2000 Toyota
Camry: Idling and Stalling Problem?
http://whatisbyme.blogspot.in/2012/05/2000-toyota-camry-idling-and-stalling.html
1995 Toyota
Corolla: Stalls, Sputters and Pops Through Intake Manifold?
http://whatisbyme.blogspot.in/2012/05/1995-toyota-corolla-stalls-sputters-and.html
1999 Toyota Camry: Erratic stalling and high engine RPM at
idle?
http://whatisbyme.blogspot.in/2012/05/1999-toyota-camry-erratic-stalling-and.html
Dodge Dakota stalls, stumbles at idle. Has low fuel flow and
runs hot?
http://schematicsdiagram.blogspot.in/2012/03/dodge-dakota-stallsstumbles-at-idlehas.html
1994 Toyota
4Runner: Stalls and Stops While Driving?
http://whatisbyme.blogspot.in/2012/05/1994-toyota-4runner-stalls-and-stops.html
1997 Toyota Camry: Erratic Idle and Intermittent engine
stalling?
http://technoanswers.blogspot.in/2012/04/1997-toyota-camry-erratic-idle-and.html
Ford Maverick: No Idle and Stalling issues?
http://schematicsdiagram.blogspot.in/2012/04/ford-maverick-no-idle-and-stalling.html
These
details will help.
Thanks.
