Question about Insignia NS-LCD37 37 in. LCD TV
Source input stuck on hdmi2
TV stuck on hdmi2 and source input menu flashes nonstop.
2 Suggested Answers
  • 814 Answers
SOURCE: BLINKING SOURCE INPUT MENU ON ALL THE TIME
This unit has component failure on the main board and should be taken to a service center for service.You may need to replace the main board or it may be a simple component failure. If you are out of warranty and need help. Try to find a experienced electronic technician with tools and work space to open you television. Have him check for faulty components on all the boards and check the solder joints for bad connections.You may have to replace the main board.This product may be found sometimes on e-bay by the model of the television and the part number of the board. Insignia customer service number is 1-877-467-4289 and the number for parts is 1-888-237-8289.Hope this helps you with your problem.
Posted on May 09, 2009
What channel do I put my LG TV on to connect my Sony blueray player to watch netflix
channel is not the correct path
you need to be thinking What input source do I need on the tv
atv dtv - THIS IS FOR AN ANTENNA CABLE
hdmi1 hdmi2 hdmi3 av1 av2 these are input sources
look on remote for input or source button .
HDMI 1
Apr 18, 2016 | LG 42LC2D 42 in. LCD HDTV
How can I change source on Goodmansld3266d tv with out remote?,stuck on pal1??? Thank you in advance for any advise
On your TV should be buttons on the bottom or the side. Hit setup menu should have a icon for inputs, cable, hdmi1 hdmi2, selected which input you want.
Mar 04, 2016 | Televison & Video
Problem: TV Menu w Auto & Manual Scan greyed out cannot be selected
Check the input selected. if it is other than tuner, this might happen. Change the input to tuner, and check.
Jan 11, 2016 | Televison & Video
How can I connect my TV to a Dell laptop via HDMI?
if oyur LG tv has multiple HDMI ports, then you might need to choose the correct HDMI port from the 'INPUT' menu. Does the HDMI port on TV (sidepanel / back) has a sticker which denotes the number? if yes, then on tv remote, choose INPUT /SOURCE menu, it will show TV, Component, RGB, HDMI1 , HDMI2, HDM3, etc (depending your tv model, these options might vary) and choose the port number which you plugged the HDMI into. if you do not have a number on the port, then you might need to select each HDMI from "INPUT' menu and wait for a couple of seconds.
Sep 01, 2015 | LG Televison & Video
How do I get the TV to show some sign that it is on
could you possibly maybe changed the input(source) selection to that of an unused device , If so most modern tvs will turn themselves off after a few minutes of receiving no input from a disconnected input , some common source selections that come to mind are ( AV1,AV2 , Hdmi1, hdmi2, DvD , and antenna) your tv might have different names but im sure it's got a source selection
May 07, 2015 | Televison & Video
Can't get input on tv to activate rca wi fi streaming media player
depends on what input port you plugged into. HDMI1 HDMI2 HDMI3
the tv input select source has to match
I have a similar device plugged into HDMI3 so I select on the input source HDMI3 to see it on the TV.
Dec 29, 2013 | RCA DSB778W Wi-Fi Streaming Media Player
Westinghouse tv problems
you have to set the source to the input source. If you plug the receiver to hdmi2, that is what you need to set the source to
Oct 24, 2013 | Televison & Video
I turn on the cable and power button then the TV and poweer on and only balck screen and AV appears in the right hand corner. Can't get my TV to wrok. Yet the one in the living room works
Make sure that the source input is set correctly. You can select the different "source inputs" using your TV remote. For example, if the cables from the cable box going to your TV are going into AV1 port on your TV then you need to select AV1 as the "source input" on your TV settings. This works the same with HDMI1, HDMI2, ect.
Jul 17, 2011 | Televison & Video
Im having problems with my brand new Westinghouse LD4255VX. i bought it tonight, took it home and took it out of the box. at first it turned on fine, then got to about the 3rd step in the setup menu and...
It sounds like the problem is simply the input selection.
SELECTING THE INPUT SOURCE
There are two ways to select the video input source.
Using the Individual Input Keys
TV, PC, Video, YPbPr, HDMI Keys
Press any of the following remote control keys to change the input source: TV, PC, Video1, YPbPr1, HDMI1, or HDMI2.
Let me know if this fixes your problem
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 05, 2011 | Televison & Video
How do you set up the tv for dvd use? Under the menu the setup options for dvd says N/A.
When you connect a device to a newer model flat panel, it assumes a source input witch in your case it may be video1 video2 hdmi1 hdmi2 or component 1 or 2 and so on. Hit the source button on your remote and toggle it until your reach the input source your are plugged into.
May 29, 2011 | RCA Televison & Video
Insignia NS-LCD37 37 in. LCD TV Logo
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
