Question about Zebra 140XiIIIPlus Label Printer
Zebra printer 140Xi, firmware 16.4.1, Labelview software 8.0. Click print a label which works on another computer and zebra printer and nothing happens
We updated Labelview software to 8.0. Zebra printer is 140Xi, firmware 16.4.1. Click print- nothing happens.
  • Jim Reder
    Jim Reder May 11, 2010
    Did this printer work before the upgrade of your software? Does it print with the Zebra driver? What OS are you using (Win98, 2000, XP, etc.)?
    Scholar:
  • 111 Answers
Try and reflash it again.
Posted on Jul 10, 2009
I am using LabelView to create a label that will be imported into an iSeries system. I am using Zebra 140xiIII as the printer in LabelView. When I import this label file into the iSeries system, I am...
iseries uses EBCDIC and the file is probably ASCII when importing from/to the iSeries charset convertions ensues, there must be some char that isn't translating well and thus converting itself in some control code, use DSPF or EDTF to open the file and check with F15 the encoding for more info I need to know what is your system CCSID
Apr 28, 2011 | Zebra 140XiIII Plus Thermal Label Printer
I have a Zebra 140xi and I need to do a print
If you press and hold the PAUSE key while you turn on the printer, then the test pattern used for aligning the printhead and checking for elements not working (prints a black box) will be printed.
Hope that helps !
Jun 07, 2010 | Zebra Printer 140-751-00000
140Xi II Thermal Printer: how can I put my zebra xi-140 printer in self clea...
There is no such thing as self clean mode. get a cotton swab soaked in 90% or stronger isopropyl alchol and wipe the print head. be careful not to scratch.
May 16, 2010 | Zebra 140Xi II Thermal Printer
Running two Zebra's through Easylabel Platinum
When connecting Easylabel to a Zebra through the RS232 port, it's very important that the serial settings match between Easylabel and the printer. Easylabel defaults to 9600 baud, 8 data bits, none parity. The Zebra defaults to 9600 baud, 7 data bits, and even parity. This mismatch causes the data light to flash but no print.
Change the printer setting to 8 data bits and none for parity and the baud rate can be whatever but make sure they match from Easylabel to the printer.
Hope that helps !
Sep 18, 2009 | Zebra 140XiIII Plus Thermal Label Printer
No print /No error message
First, you need to make sure the ribbon and labels are loaded correctly. Follow the diagrams on the inside of the door. Once this is done, check the print speed and darkness from the front panel. If you have a high print speed and a low darkness, depending on the media you are using, it may not show the print. Try either slowing the print speed down or raising the darkness.
Aug 28, 2009 | Zebra Stripe S600 Thermal Label Printer
Hi. I Recently inherited a Zebra 140 XiII(2) and I cannot set the print speed as the option doesn't show on the LCD menu or when I print out the printer config settings. Any help would be appreciated.
Print speeds on the Zebra xiII series printers are set via software. There is no printer menu speed setting on the xiII series. Zebra didn't allow speed adjusts thru the front panel menu until they made the xiIII series printers... The ZPL code command for print speed is "^PR"
Jul 16, 2009 | Zebra 140Xi II Thermal Printer
Zebra Lp 2844-Z printer flashing green and red alternately?
-Install ZDownloader from Zebra's web.- http://www.ups.zebra.com/ctp/upgrade.aspx visit this page and do nothing to use in step 3 part to download for your stable firmware, only find and download it
-Turn off printer and get ready on Zdownloader sofware-You could see easly "Auto Detect Printers" on ZDownloader, press and hold the label feed button and keep your finger in there then click the "Auto Detect Printers", if you are seeing your printer in list now, continue to keep your finger in feed button-Select the firware.prg file, right click with select your printer in list and click "Download to Selected." -you are still keeping your finger in feed button in this time. You will see the feeding will start and your problem fixed.
Sorry for my english, haven't got enough practice.
Dec 30, 2008 | Zebra LP 2844 Thermal Printer
Need Zebra 140xi User Manual
If one is available, you will find it here - LINK
Dec 10, 2008 | Zebra 140Xi II Thermal Printer
Zebra TLP 2742
In www.zebra.com ZebraDesigner can download the software to design and print labels.
Jul 22, 2008 | Zebra Eltron TLP 2742 Thermal Label...
328 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
