Don't know how to connect to amp or power up.
I have recently purchased a used Technics st-5l tuner and Amp but have no idea how to connect to one another. I have the Amp working fine but I do not know how to power up or connect the Tuner to the Amplifier. There is a Power Socket on the back of the Tuner as well as a 2 core cable and an interface that fits the top of the Amp. Does the Tuner need a separte power supply or does the interface provide the power?
  • Anonymous May 20, 2009
    Thank you rggshwb2913 for the response but when the Tuner is stacked onto the Amp i.e. the interface is connected, there is no power to the Tuner; I suppose the Tuner could be duff though. Does anyone know what the 2 core cable is for and what is the Power socket for?
  • 92 Answers
The interface should
Posted on May 20, 2009
Technics SU-X302 Problems
Greetings
Is there any indicator on or its all off?
anyway i will assume that there is none
1.check power fuse if blown.
2.check power transformer if there is any output voltage
3.check internal fuses
more information will give a better idea.
try these steps and hope this helps.
Dec 25, 2013 | Technics Audio Players & Recorders
I have a Technics SL-BD20D turntable and want to connect it to a Technics SA-EH50 amp. Can this be done. Please tell how
Hi, you need a preamp to boost the line level if no dedicated phono input is on amp. Cheers John. Styluscity
Dec 28, 2011 | Technics Audio Players & Recorders
Following a split from my boyfriend I really need some help in how to connect up my hifi system. It's all technics Tuner Receiver ST 610L Equaliser SH GE70 Amp SU V470 CD Changer SL...
the amp should have an in and out for the cassette player also,, so you would go from the Out on the receiver, to the in on the cassette,, and out of the cassette to the in on the receiver, I don't have nor can I locate that EQ , but basically,, you need to come out of the eq and back the same way you would a Cassette player,,
Jun 14, 2011 | Technics SH-GE70 Home Equalizer
I have a technics ST-X933L tuner as part of a separates system and the volume on the amplifier has to be turned up to almost full volume to be heard. All other inputs are playing at the expected volume for...
You can answer the question by jacking the tuner's outputs into any other Line Level input on your amp/receiver. If it's still low, the tuner is at fault.
BTW: NEVER use full volume as a test unless you intend to blow up your speakers.
Mar 05, 2011 | Audio Players & Recorders
We like to change the time in a Tuner/sound
On the right side of the front of the sound processor press the "TIMER/CLOCK" button. The massage "CLOCK" will appear on the display. Then press the"SET" button. And by using the "^&V" (UP&DOWN) buttons the day and then the hour and minute will be set. In the end press the "SET" button. And that's all.
Nov 11, 2009 | Audio Players & Recorders
Having a hard time connecting various audio components
Yes, it is a little tricky...
1) CD Changer (output) -> CD input on Amp
this is tricky... this will allow you to record to your tape deck, and control the sound via the EQ:
2) Tape Deck (tape out / recout) -> TAPE PLAYBACK on EQ
3) Tape RecOut on EQ -> Tape 1 Playback on Amp
4) Amp Tape 1 RecOut -> Tape Deck Playback / Input / RecIn
in essence, your creating a loop starting from the tape deck, going to the eq, then to the amp, then back to the tape deck to record.
Your EQ has another set of LINE IN and LINE OUT - use the second Tape 2 on the amp to create another loop. This will
allow you to control the EQ for any of the other sources.
5) LINE IN on EQ -> Tape 2 RecOut
6) Tape 2 Playback on Amp -> LINE OUT on EQ
5) Radio Tuner (output) -> Tuner input on Amp
6) DVD/VCR Combo Output -> AV/AUX on Amp
7) PC Computer... you don't have room for this. You can either use the PHONO input, and you'll have to purchase a Line Level Phono Converter
or, get a Y cable and split the signal and share with some other source.
Hope this helps.
- OPTiC
www.djproaudio.com
www.repairny.com
Dec 13, 2008 | Technics SH-GE90 Home Equalizer
Sony Stereo System
Your in luck there is a user guide online that has all you need to know.Here is the link
Jul 30, 2008 | Sony TA-N9000ES 5-Channel Amplifier
Technics su-a808 amp & sh-ge70 graphic equaliser.
connect your media source(dvd-cd player)to equalizer in-connect equalizer out to amplifier line in-or aux in-connect amplifier out to your loudspeaker.
Jun 24, 2008 | Audio Players & Recorders
Erratic volume on Technics SU-X911 amplifier (Class A)
its the ic that controls the + and - voltage and there are capacitors that have leaked all the caps on that board need changing could be expensive and time consuming but its the age of it . if i was going to do that job £200 plus\
Aug 24, 2007 | Technics SA-DX940
Technics ST-X302L tuner - Unit not powering on
i have the same unit and a similar problem, after a fall of the tuner on the floor while i was cleaning my room, first times the st-x302l was powering fine but after some minuts it quit alone.. now (i dont know why) it remains on but if there is an interruption of electricity it dont turn on anymore, it turn on only by removing the metal chassis and moving random the electronics.. i think it has some electronic contact or circuit break.. i brought it to a specialist in electronics and he told me the reparation would be too expensive so i prefer to try fix it by myself.
Mar 01, 2007 | Technics ST-GT350 Tuner
 Grubhead
Grubhead
