Question about RCA Thomson Digital Cable Modem (DCM305R)
Need default gateway
Im trying to get into my digital broadband rca by thomson router, and i cant find the default gateway. ipconfig only shows an ipv6 address, i need the ipv4 address
    Genius:
  • 1,605 Answers
Try IPconfig/all
usually the defaut gatway is the router own address. i.e. 192.168.0.1 or 192.168.1.1
Posted on May 20, 2009
How to setup a rca thomson digital broadband to a tm router
You have to reboot your modem anytime you connect a new device to it, this is what is great about routers! They act as the reference device to your modem since the modem can only "pair" with 1 mac address at a time, this allows you to connect and disconnect devices to your internet without having to reboot your modem and to also have multiple device use the same internet service at the same time.
Unplug the power to your modem and just follow the directions that came with your router on how to wire it to your modem and set it up. Once you are done plug your modem back into power and you should be up and running.
Jan 31, 2013 | Thomson Rca / Digital Broadband Modem...
I can't open my thomson gateway
What's the error message?Have you tried to go to the exact modem page?
1. open internet explorer2. type the numbers 192.168.1.254 on the address bar then press enter3. you will be routed to thomson page settings if you received any message stating error like can not display page then you need to check if the cables are properly connected.4. if still can not connect, go to the start menu icon5. select the run icon or search bar6. type cmd then press enter7. you should received a black screen8. from the black screen type ipconfig then press enter9. you should received the info like IP ADDRESS, SUBNET MASK and DEFAULT GATEWAY.10. copy the default gateway and type it in the address bar of your internet explorer then press enter11. if you have not received these information (ip address, subnet mask and default gateway) on the black screen after typing the ipconfig then check the error "media state disconnected" which means that your pc and your thompson is not communicating, here you need to try different network cable to isolate issues for the problem might be the cable, network cable port at the back of your pc or the network cable port at the back of the thomson.
kindly rate rate this post, thanks
Dec 31, 2011 | Computers & Internet
I'm using windows 7 with a wireless rca by thompson dcw725 router. my desktop is wired into it, but i got a laptop that connects wireless, but has no internet access, says limited connectivity. Any ideas...
First of all, you need to check if the laptop is correctly connectedto the router.
try the following steps to see if you are effectively connected to the router :
1. Open the command prompt on your desktop computer (Start -> All Programs -> Accessories -> Command prompt OR Windows Key+R -> type cmd).
2. Type ipconfig /all and then note down the value given for Default Gateway
3. Repeat the first two steps on the laptop and compare the values of Default Gateway.
If the values are different, then it means the laptop is not correctly connected to the router.
You will have to delete the Wireless network configuration (In the Network and Sharing Center, you will find it in "Manage Wireless Networks").Then start the wizard for connecting to a wireless network. Be sure that you enter the network security key correctly.
If the default gateway values are correct, check the firewall/antivirus settings on your laptop. If you cannot or don't know where to look, deactivate them completely and try again.
You may also need to check the parental control settings and your web browser settings (notably if it is in offline mode).
Last but not least, on the laptop, delete all broadband connections and/or dial-up connections that are present (in the Network and Sharing Center, go to "Change adapter settings" to find any broadband or dial-up connections).
May 05, 2011 | RCA Thomson Digital Cable Modem (DCM305R)
Trying to connect my netgear router to my sky broadband need the adsl settings tried 192.168.0.1 but nothing happens
The address you type in the URL (192.168.0.1) has to be whatever your DEFAULT GATEWAY is-- to find out go to START>RUN and type IPCONFIG and then ok- you will see the DEFAULT GATEWAY (this is the routers address)-- If you see nothing (or 0's) it means the router did not get an address from your ISP--- you can try IPCONFIG/RENEW to get an address
Feb 10, 2011 | NetGear Computers & Internet
I cant go into the router i think i changed something on the router setup and now it cant go back in.i can connect to the internet directly from the cable modem but when i plug it in the wirless router it...
Try using the hardware reset button on the Linksys. Every settings / changes you have done will reset.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Jul 07, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
Cant enable wireless on my Bebox
The full set of user guide are here http://www.thomsonbroadbandpartner.com/dsl-modems-gateways/products/product-detail.php?id=161
browse to http://dsldevice.lan or to the IP address of your Thomson Gateway (by default: 192.168.1.254) and click Thomson Gateway on the menu on the left-hand side.
Another option is to reset your Thomson Gateway and reconfigure it all over again. have a look at chapter 7 of this manual http://www.thomsonbroadbandpartner.com/getfile.php?id=5349
Mar 23, 2010 | Dell TrueMobile 1184 Wireless Broadband...
Rca router: need ip address to log in
in run box type " ipconfig "
or start/all programs/accessories/commmand prompt
see default gateway ip
then in your browser http:// and default IP
for manual try thomson and put your model in search
May 09, 2009 | Computers & Internet
Cant open ports in elephant with router thomson TG585v7
You need to log on to the router using the default gateway.
Go to Start menu -> Accessories -> Command Prompt
type ipconfig
Note the default gateway
open your browser, in the address bar type in the default gateway ip address - like 192.168.1.254 --- or whatever the IP is.
That should open your router config pages... if it asks you for a user name and password... default usernames depend on your ISP usually, but try for the username Admin, admin, Administrator, administrator and for the password try the same as the username or leave blank... If you have no luck contact your ISP for logging on details.
A web page will open - go to
Toolbox
Game And Application Sharing
At top right click configure
Make sure UPnP and Extended Security are selected if you have those options
Then at the bottom
Create a New Game or Application
from there you just need to select which protocols you need to work with or select ANY
Enter the port you want opened
and add the same port number to the destination / trigger port.
That should be you. If not you need to telnet into you router
Telnet <default gateway IP>
and type Menu
The follow the previous instructions.
Aug 31, 2008 | Computers & Internet
HELP!
use another computer that is wired to the router.
log into the router and get the wep code.
to get to the router page to login.
open a command windows
start/run/ cmd
type : ipconfig
that gives you the default gateway address.
put this gateway number in your browser address window and login.
Jan 26, 2008 | RCA Thomson Digital Cable Modem (DCM305R)
RCA Thomson Digital Cable Modem (DCM305R) Logo
934 people viewed this question
Top RCA Computers & Internet Experts
Julie Endres
shaun taylor
Are you a RCA Computer and Internet Expert? Answer questions, earn points and help others
