Question about Veridian 09-330 - Temple Touch-Mini Digital Thermometer
How to change it from Celsius to Fahrenheit - Veridian 09-330 - Temple Touch-Mini Digital Thermometer
How to change from Celsius to fehrenheit
On the Celsius scale, the freezing and boiling points of water are exactly 100 degrees apart, thus the unit of the Fahrenheit scale, a degree Fahrenheit, is 5/9 of a degree Celsius. The Fahrenheit scale coincides with the Celsius scale at -40 °F, which is the same temperature as -40 °C.
Sep 11, 2017 | Cars & Trucks
How to change fehrenheit to Celsius
Can you give us the model number and brand name of the thermometer you are trying to change? If you have a calculator you can do the math. To convert temperatures in degrees Fahrenheit to Celsius, subtract 32 and multiply by .5556 (or 5/9). Here are some examples for you:
Example: Convert 26° Celsius (a nice warm day) to Fahrenheit
First: 26° × 9/5 = 234/5 = 46.8
Then: 46.8 + 32 = 78.8° F
Example: Convert 98.6° Fahrenheit (normal body temperature) to Celsius
First: 98.6° ? 32 = 66.6
Then: 66.6 × 5/9 = 333/9 = 37° C
Apr 25, 2016 | Home
How do we change F to Celsius.
How to convert Fahrenheit to Celsius 0 degrees Fahrenheit is equal to -17.77778 degrees Celsius:
0 °F = -17.77778 °C
The temperature T in degrees Celsius (°C) is equal to the temperature T in degrees Fahrenheit (°F) minus 32, times 5/9:
T(°C) = (T(°F) - 32) × 5/9
or
T(°C) = (T(°F) - 32) / (9/5)
or
T(°C) = (T(°F) - 32) / 1.8
Example Convert 68 degrees Fahrenheit to degrees Celsius:
T(°C) = (68°F - 32) × 5/9 = 20 °C
See webpage
http://www.rapidtables.com/convert/temperature/fahrenheit-to-celsius.htm
Sep 23, 2015 | DMI / Briggs Healthcare 15-681-000 -...
Changing the external temperature gauge from Fahrenheit to Celsius
If your temperature reads in climate control reads in degrees Celsius "C" instead of Fahrenheit "F", follow these steps to change to Fahrenheit.
  • Turn the ignition on.
  • With the climate control turned on, push and hold the recirculation button in. While holding the button in, push and hold the off button in for 3 seconds or until you hear a beep.
The display should then change to "F". Follow these same steps to change your read-out to Celsius , if preferred.
Sep 21, 2012 | 2005 Land Rover LR3
How to change celceuis to fahrenheit ?
Convert Fahrenheit to Celsius
Tc = (5/9)*(Tf-32)
Convert Celsius to Fahrenheit
Tf = (9/5)*Tc+32
where Tc is Temp in Celsius and Tf is temp in fahrenheit
Aug 18, 2010 | Hyundai Motor 2004 Sonata
How do you change the tempature reading for the air conditioner from Celsius to Farenheit?
You can switch the temperature mode between Fahrenheit to Celsius as follows:
While depressing the AUTO button, depress the OFF button for 3 seconds or more. The display will change from Fahrenheit to Celsius, or from Celsius to Fahrenheit.
Feb 03, 2010 | 2004 Kia Optima
Change temperature from Celsius to Fahrenheit on a comfort zone h
To change your heater display from Celsius to Fahrenheit: press and hold the "down" button and the "enter" buttons simultaneously for 5 seconds and release. - VS
Nov 11, 2009 | Comfort Zone CZ-800 Heater
Change from celsius to fahrenheit
While depressing the AUTO button, depress the OFF button for 3 seconds or more. The display will change from Fahrenheit to Celsius, or from Celsius to Fahrenheit."
Jun 02, 2009 | 2003 Kia Sorento
Switch from Celsius to Fahrenheit Temperature setting
Press cancel and bake buttons simultaneously for 3-5 seconds until C appears then use up/down buttons to change to Fahrenheit. Hope this helps!
Feb 10, 2008 | Magic Chef 31000 Gas Kitchen Range
Veridian 09-330 - Temple Touch-Mini Digital Thermometer Logo
Top Veridian Computers & Internet Experts
David Payne
David Payne
Are you a Veridian Computer and Internet Expert? Answer questions, earn points and help others
