Question about Dryers
LG DLEC855W Dryer Error Message LE3 - Dryers
I have an LG Dryer and keep getting a error message D90 after running for about 10 minutes
D90 means the dryer thinks the vent duct is 90% blocked. Be sure the vent hose is not kinked behind the dryer. I've even disconnected the hose from the dryer and hooked up my leaf blower to blow out the vent as it develops more air pressure than the dryer does.
Here's a great video describing the error code: https://youtu.be/yL7Oq4lCadw
Good luck. Hope this helps.
John
Mar 22, 2015 | LG Dryers
I have an ventless , or condensation, dryer. This is my second unit in 5 weeks. They both leaked over a cup of water on the floor during the cycle. Also they both stop within the cycle (about 4x) and...
I am not completely familiar with that unit, but if I had already 2 units supposedly fail with the exact same symptoms, I would in a different direction for resolve. Installation? There is not a likely probability that 2 machines are defective with the exact failure. Check instructions on install and make sure the exact instructions are being followed.
Dec 29, 2014 | LG DLEC855W 24" Compact Ventless Electric...
Forgot to put the lint trap back into LG Ventless Dryer DLEC855W. Clothing might have gotten stuck inside. Dryer now making grinding noise and drum is moving slowly. Is it time to call a repairman?
The filter simply allows the dryer air to pass through and trap the lint so it will not collect in the exit tube or on the outer vent parts. If anything, the clothes inside the bin will just spin around and be there when you finish. The noise inside the dryer could be from something that was in the pant or shirt pocket and was floating around.
Mar 01, 2014 | LG Electronics DLEC855W Electric Dryer...
Error code ee3
TE3' error code - Heating Error - High temperature thermistor open circuit. Could be the thermistor, high temp thermostat, etc. It shows an "open" code, which means something from point A to point B is open, and not grounding out. Check wiring, plugs, anything that could be bad or disconnected.
Nov 07, 2013 | LG Electronics DLEC855W Electric Dryer...
Lg wd-3245rhd LE error message
This seems to be a fault in the motor wiring harness, check all the connectors to and from the motor, check the male and female connectors. Also check the sensors to the motor which can cause this motor to show up as overload.
Jan 14, 2013 | LG WD-3243RHD Front Load Washer / Dryer
LG DLE2512W dryer approx 3 years old error message to "check filter". Dryer has stopped working. What is the problem? Do you have a schematic of the dryer I can download?
I just had this problem with my 5 year old today. I unplugged it (after checking the line and the regular filter to make sure that they were clear). since there didn't appear to be a real problem. It works fine now. It wasn't having any problems before the light started flashing and it doesn't appear to be having any now. Hope this helps
Mar 14, 2010 | LG DLE2512W Electric Dryer
Dryer error code
is the dryer getting hot?
if not turn the power off and pull the dryer out and take the back off and push the red button in at the back
Nov 09, 2008 | Dryers
Dryers Logo
132 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
