Question about Denon AVR-2113CI Receiver
Denon avr 2113ci Ethernet Plug not detecting wnce 2001 wireless device. Wnce works with other devices
robotek
  • 1512 Answers
SOURCE: What to use for Audio-out on Denon AVR-2807?
Hi Karmor
Use the Tape Out(rec) connections on the Denon. If that model has a rec out selector, then be sure to select phono as well. All sweet and ready to rip them files!!
regards
Graeme
Posted on Mar 16, 2008
CAYPIANAN
  • 227 Answers
SOURCE: Denon AVR-487 power issue
hello my friend denon receivers are famous for the power problem, check all the connections first and if there is not solution your power supply has a problem
good luck
caypianan@yahoo.com
Posted on Nov 03, 2008
SOURCE: Denon AVR 2800 digital hookup to PS3
If your TV has an HDMI input, hook up the PS3 w/an HDMI cable to the TV. This will give you a high def picture (set up the PS3 to output the max resolution your TV displays). That will take care of the video side.
Next hook up an optical cable from the PS3 to the receiver. In the PS3 menu, you have to change the audio settings to output the sound via the optical cable.
Finally to get sound out of the receiver to the speakers, you have to setup the receiver source input. For example if you setup the PS3 to play thru "VCR" input, then you have to make sure the VCR input is setup to use either optical 1 or optical 2 for sound (whichever one you have the optical cable plugged in from the PS3).
  • I found this solution on a different site... it worked for me. I needed to change the sound settings in my ps3 to optical... then i selected dolby 5.1.... that took care of my sound.
Posted on Dec 24, 2008
  • 163 Answers
SOURCE: Display on Denon AVR-2307 won't work
1. Bad main transformer or
2. bad main fuse/ bad channel.
You need a repair shop.
Posted on Jan 22, 2009
  • 119 Answers
SOURCE: Control other devices connected to Denon AVR-1100
No you can't use this remote to control other devices unless they are Denon devices. This is not a learning remote
Posted on Feb 25, 2009
Denon avr 2113ci signal not coming in from apple tv
If this is a video problem, try different video connections (i.e. HDMI, Component, Composite, S-Video) to isolate the problem
Dec 16, 2014 | Denon AVR2113CI 7.1-Channel 3D Home...
Remote doesn't operate receiver
ok to first check the obvious things. you are using the standard remote that came with the unit i can assume, and you've tried a different fresh set of batteries, and there is nothing blocking the receivers remote sensor or the remotes output sensor. If you have a smart phone there is an app for Denon AVR's that allow you to use your phone to control the unit assuming you also have a home network that the AVR is connected to.
If everything else works with the app you may just have a faulty remote, hard to test without trying it on another persons same model AVR
Mar 17, 2014 | Denon Deonon AVR-2113CI
I have a Denon 2113 which turns on displays for a second switches off and the red light starts to flash. what could be the problem? Kindly assist...
Not sure if your power circuit board is fried. The red light flashing means that your unit is going into protective mode so that it won't damage other components inside the amp. Best to disconnect all cables and just have the power cable plugged in. See if this still happens. If it doesn't, attached each device one at a time to find out which cable is doing this. If you still have the same issue, the amp needs a service.
Dec 09, 2013 | Denon AVR-2113CI
Netgear adaptor won't recognize 2wire 420
If you wish to unlock this Huawei E960 password.... Call +2347035041294... Skype: mickyhandsome2010
Oct 17, 2013 | NetGear WNCE4004 IEEE 802.11n 450 Mbps...
I cannot connect my Denon 2313ci to my home network. I have tried to hard wire the network and connect wirelessly via a netgear Ethernet adapter. Neither seem to recognize that the Ethernet is connected.
Hard wiring is your best solution. I assume you have a working router with a spare port. Once connected, switch off your router, wait 30 secs and re-boot. Log on to your router and look at the connected devices page (assuming you have DHCP enabled so that the Amp is automatically allocated a local address) If your router cannot see the Amp, you may have a faulty ethernet cable. Try plugging the cable into a laptop to see if it is working. If it appears you can reserve the address for the amp.
Sep 28, 2013 | Denon AVR-2313CI
How do I network Denon AVR 2113CI with PC?
They don't specifically mention it but you might have to download a Denon driver/software plugin for your computer if it doesn't auto find it. Most of these instructions are for programming external RS-232 (Crestron, AMX, etc.) control systems but the basic format should be the same for initial network communications.
http://www.audioproducts.com.au/downloadcenter/products/Denon/AVR2113BK/Other/AVR2113CI_AVR1913_PROTOCOL_V8.5.0.pdf
Feb 14, 2013 | Audio Players & Recorders
Denon avr-2113ci hdmi can't change source
Can you update the firmware on the amp as this could also affect the connection between the players.
Jan 15, 2013 | Denon AVR-2113CI
How can I turn a CLX-3185FN into a CLX-3185FW?
Buy a Netgear WNCE 2100 which has one wired ethernet port connected internally to a wifi radio which is a 2.4GHz transceiver with WPA security. Fully compatible with most routers from D-Link, Netgear, Buffalo, etc. The samsung printer has a USB port to which you can connect and power the WNCE2100. This product is called by two different names. Sometimes it is called a Universal Ethernet Adaptor and others it is called a Network Bridge--which is more accurate. The Netgear product is b/g/n compatible. Try to place it not more than one room away from the router because the signal strength drops very fast if it is more than one wall and or 40feet from the wireless router.
Jan 03, 2011 | Samsung CLX-3175FW Multifunction Laser...
Denon AVR-2113CI Receiver Logo
26 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
