Question about Toshiba DKT-2010 Corded Phone
Phone won't ring
So our office has 6 DKT-2010-H Toshiba phones, all of the sudden after  Friday of me being gone, my phone doesn't ring on incoming calls, I have to push whatever line is ringing to pick up the call. Other people can transfer calls to me and I can pick up the handset and the people are there, but only on incoming calls is when that happens. Please help, it is very irritating. Thanks Melissa
  • 131 Answers
Hi Melissa,
The phone system (cpu, Brains, Switch) is set for auto answer on your Ext. Either power was lost, programming changed or something along those lines. It is global, so if a call "rings" @ your phone, (any call) you can just lift the receiver and speak.
It sounds like the associated phone lines ringing in "lost" memory of your extension. Therefore it must be programmed or in the case of a toshiba system it has a software "glitch or bug". usually due to "I don't know". So I usually find a change was done to ringing by the vendor or just power loss to the system.
there are a million variables because it was manufactured in asia usually. I would need some more info. to be sure. I can tell you it is NOT your phone. try to reset the phone by unplugging for a minute , if no luck you will need the vendor to reset your Ext. with a laptop or do it yourself with the codes from the main or switchboard ext. I am sure I can give you the info to do this and make it ring again, but you are best off calling the dealer in case fat fingers get wild . you could do much harm by trying by one wrong entry and it is what I call Jinglish ( Japanese English or bad translation) in the manual. $80 or so is worth it , mostly if someone was out to change stuff while you where gone.
Or jus unplug the phone system and wait 1 minute before plugging it back in,  that will reset the system kind of like rebooting windows and forcing it to re - load the system.
Good luck, let me know.
Bob
Posted on Oct 19, 2007
Toshiba DKT2010-sd calls no longer go to voicemail
go to the website http://www.telecom.toshiba.com/ go to the call forward settings in the book turn off Call forward All and turn on Call Forward NA (No Answer) by default it should go to the VM system. If it does not figure out what you dial in the keypad when you want VM to answer.
Nov 22, 2013 | Toshiba DKT-2010 Corded Phone
How do you program a Toshiba DKT-2010 phone to ring
Ringing is a system program, not done at user level. However not that hard it is done in program 81 and the manual is here.
http://guides.idacomusa.com/
Oct 02, 2009 | Toshiba DKT-2010 Corded Phone
Some phones light up but there is no ringing...
is the ringging assignment setting
means downstair phone been set for incoming ring, so u can see the indicator ligh on and ringging
up stair dint assign a incoming ring so that u only can see the indicator light always blinking w/o ring...
contact yr phone provider to set the ringging assignment
Feb 24, 2009 | Toshiba DKT-2020 Corded Phone
Choosing which lines ring.
If you have a multi line setup, you have a phone router. Have your phone company come in and program it for you.
Feb 17, 2009 | Toshiba DKT-2020 Corded Phone
Toshiba DKT2010-SD won't ring
ask the provider to program the ringging assignment. It wont ring couse dint assign a ringging assignment.
Feb 13, 2009 | Toshiba DKT-2010 Corded Phone
Need to set ringer on phone to ring in my office
is because the ringging assignment only set to ring at receptionist phone.
u may need contact the phone provider to set the ringging assignment to other for other phone which to ring for incoming call
Jan 14, 2009 | Toshiba DKT-2010 Corded Phone
Toshiba DKT-2010 Msg light
intercom # 409 should clear it, if it doesnt, press the message key and if it rings another phone make sure that phone picks up the handset and answers the call.
Nov 05, 2008 | Toshiba DKT-2010 Corded Phone
Display shows "1 new/1 saved" yet mailbox empty.
The message left on your phone was probably left by someone internal, meaning they called your phone and when you did not answer, they hit their message key which turns on your message lamp and display. If you press your message key and it rings someone in the office then they are the one that left the message and they have to answer your call. You can usually cancel the lamp/message on your phone by pressing " Intercom ( your extension button ) " # 4 0 9 and then hang up. You can have up to four ( 4 ) messages on the phone so it may take putting in the code a couple of times to clear the display.
Jul 24, 2008 | Toshiba DKT-2010 Corded Phone
Incoming calls blink red
Your phone is not programmed to ring. call local dealer for programming change.
Jul 07, 2008 | Toshiba DKT-2020 Corded Phone
Toshiba dk40 system ringing
do all of the lines appear on all the extensions? if so, the procedue is fairly complicated, you need to go into the programming on port 05, then go into program 04 and get all of the port numbers for each extension, then in program 81-89 you need to select each when you want the co to ring, in either day 1,2 or 3, and complete for each co line that you want to ring
Feb 09, 2008 | Toshiba DKT-2020 Corded Phone
Toshiba DKT-2010 Corded Phone Logo
338 people viewed this question
Top Toshiba Lands Phones Experts
Oloyede Monsuru
Are you a Toshiba Lands Phone Expert? Answer questions, earn points and help others
