Question about KitchenAid KSRS25IL Side by Side Refrigerator
Kitchenaid superba KSRG22FKSS01 Ice cube switch trouble
The Cube switch on my kitchenaid superba refrigerator will not work.  It works on the crushed switch but not on cubed.  Lite and other functions also work.  The cubed function just quit working all of a sudden!   Do you think it's a bad button/switch?  Any suggestions?
  • arruva Oct 18, 2007
    Thanks for your reply  - but did some experimenting and I happy to say I was successful.   With the freezer door switch held in- everything worked properly with the bin off.  Put  bin back on - cube switch would not dispense.  Emptied bin tried again worked properly.  Filled bin with ice-   cube switch would not dispense.  Took bin off let it warm up - wiped off moisture -returned to freezer  - checked still works - filled with ice and now works fine.   Must have had something froze up inside the bin.   Thanks for your response.
  • 447 Answers
Since its an indoor ice maker its much harder to diagnose. However the motor is supposed to reverse for crushed/cubed so you can hold the freezer door switch and see if it does. If it doesnt reverse it could be the switch, or it could be a mechanical problem inside the blades (check for broken stationary blades)
Posted on Oct 18, 2007
Water and ice cube dispenser working fine, crushed ice not crushing. 26 cuft side by side model MZD266SHES
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid. Crushed ice is the default position and the solenoid is energized to cube ice.
Remove the dispenser cover by gently prying starting at the bottom going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components.
Feb 21, 2011 | Maytag MFI2568A Side by Side French Door...
Ice maker dispenses cruched ice in cube ice mode
With your model number I can find a diagram which may help.
Oct 05, 2009 | Refrigerators
Crushed ice option don't work properly . samsung RS2530B
if it new call sears for service...with crushed ice the augar moter turn the other direction... it must not be turn the other way could be a switch in the control...
let me know for it help if NOT please let me know and I will be glad to do more in depth.
Sep 26, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Dispenses crushed ice instead of cube ice
Aug 31, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Dispenses crushed ice and will not dispense ice cubes
Aug 17, 2009 | Frigidaire FRS23H7CS Side by Side...
Ice Maker GSI-26 dispenses crushed ice and will not dispense cube
Aug 17, 2009 | Refrigerators
ICE MAKER STOPED WORKING
IS THE METAL ARM IN THE DOWN POSITION?
Mar 30, 2009 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid side by side model ksrs25ikss01
CHECK YOU SECOND VALVE IS WORKING IF THATS OK YOU MIGHT NEED YOUR ICE MAKER CHECKED AND SERVICED.GOODLUCK.MOHAMED
Sep 06, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kitchen Aid Ice maker Stopped working
The ice maker has stopped working. The red led light blinks when the freezer door is opened. Any thoughts?
Nov 22, 2007 | KitchenAid Superba Architect KSCS25INSS...
Ice maker only crushes
Check this post out- http://www.fixya.com/support/t117589-ice_maker_cube_selection. Different model but same principal...Catriver..post back
Nov 02, 2006 | KitchenAid Superba 21.6 cu. ft. Top...
KitchenAid KSRS25IL Side by Side Refrigerator Logo
204 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
