Question about Whirlpool Refrigerators
Compressed warranty Compresser warranty
Complete instructions for ac replacement of 2004 trailblazer LT. Found metal shavings in compresser.
Replace the compressor, replace the receiver dryer and use AC flush to flush the rest fo the system with compressed air..
Jun 30, 2017 | AC Cars & Trucks
Some keys on mpk49 do not play unless hit hard
sounds like dust, if you know some one with an air compresser ask them to give it a blow through, if not then it is down to caned compressed air, if that is not enough, you need to open it, and clean the contacts (DVD cleaner is cheap and good)
Aug 29, 2014 | Akai Mpk49 Mpk 49 Midi USB Keyboard With...
Try blowing console out with air compressed..with blow tip.or can of compressed air..but air compresser works best..make sure console fan is working..and clean..try getting the newest Xbox update as well ..
Aug 01, 2014 | Microsoft Xbox 360 Console
2000 ford explorer air in compresser
you have to have a vacuum pulled on the compressor to remove the air. most any shop can do this for you
Jun 16, 2014 | Motor Guard Compressed Air Filters -...
What's best way to clean a bad gum up caborator with old fuel on lawn mower?
go to auto store get a strong carb cleaner let carb soak over night in it they call this boiling the carb and then you need strong compressed from a compresser 300psi blow every hole in the carb no matter how small take small wire punch down the holes and blow them out again carb should be like new
Aug 06, 2013 | Garden
Can't get rear struts off. Wont come loose from tower.
Yes ,and you need a proper spring compresser or your putting your life in danger trying.
Nov 07, 2009 | 2007 Ford Five Hundred Limited Sedan
Air conditionin gunit keeps tripping breaker. A/C is carrier 5 years old compressor?
Sounds like you have a grounded compresser with a direct short.To know for sure you can disconnect the compresser and then flip the breaker and see if it still trips.If it still does check the motor,but this is most likley the compresser sorry.Carrier does have a 5 yr warranty so hurry and call someone it could still be in warranty!
Jul 17, 2009 | Heating & Cooling
Knocking noise when compressor chuts off
this is a problem that has been going on for close to 35 years. back in the day some genius decided to redisgn the compressers made by tecumsah. they made a rotary compressor in other words the compressor inside the housing turns 360 degrees rather than being pumped from a piston that went up and down.this rotary compresser spun around very fast and when it shut off the three springs that held the compresser would sort of bend a little. as time went on this weakening of the springs would cause the compresser to hit the housing, thus creating a knock or ping or whatever else you want to call it. so customers would call up factory service ans say their refrigerator was making noise. so a service tech like me would go out hear the sound and order a new compresser. after a while the replacement compressor may or may not make noise. after a few years tecumsah said that they would no longer credit the service companies for noisy compressor problems and that the noise was the nature of the beast. so depending on variables such as who you talk to when you request service and the tech who shows up at your house you will either get a new compresser or not. i hope that explains your problem to you it's hard to write all this down rather than standing in your kitchen and telling you in 45 seconds good luck. you can take this all the way to the president of whirlpool if you get no satisfaction
Jan 29, 2009 | Whirlpool GS5SHAXN Side by Side...
Strut replacement
Yes - you can buy them at an auto parts store. Ask for "spring compressors". You can use them with a ratchet, but it's very tedious, and is much quicker and easier with air tools. Be absolutely sure you follow the recommendations and cautions on the box - you can get hurt or killed if you use them wrong and they let go when the spring is compressed. There's a LOT of energy pent up in the springs when they're compressed.
Aug 29, 2008 | 2003 Toyota 4Runner
Refrigerators Logo
14 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
