Question about RTO Sole F80 Treadmill
SOLE F80 is making a loud noise in the rear roller
When belt is loose the noise goes away
SOURCE: belt shifting/crooked and frayed on Proform 725 TL
in the back of the manual, it describes the adjustment for this. on the end of the platform (near where your belt is crooked) there is a hex nut. the manual says to turn the machine off before adjusting, i find it is much easier to do while the tread is still moving. turn it about a quarter or half turn one way or the other until the tread is aligned.
Posted on Jun 29, 2009
maxtreadmill
  • 832 Answers
SOURCE: belt wont start on a brand new Sole F80. Motor
It sound like the motor control board is the culprit. Unplug unit then remove shroud then find the 2 leads that connects the motor to the motor control board disconnect them then plug in unit and see if the display blackout after programing the display then hitting start.
Posted on Mar 13, 2010
  • 33 Answers
SOURCE: I have a sole f80
hai , check communication cable, speed sensor
Posted on Dec 10, 2011
ercupa190
  • 12223 Answers
SOURCE: My Sole F80 deck bounces excessivly when not at an incline.
1) Lube the deck belt, this problem is lack of maintenance, maybe the deck belt is worn.
2) You must align the deck belt see the diagram
3) Lube the rollers bearing very well very important too
see the video: God bless you
Posted on May 15, 2012
ercupa190
  • 12223 Answers
SOURCE: my fans on my brand new sole f80 dont come on
1( test the voltage at the terminal of the FAN, if there are the FAN is faulty.
2( test the voltage at the terminal , if there are NOT TEST why NOT coming voltage to the terminal.
3( follow any wires or plug or connector or loose wires, and TIGHT VERY WELL.
4( test FUSE or c. breaker and replace or reset.
5( Try again, and fix it. See the block diagram attached.
However RUN the software caibration for easy diagnostic, troubleshooting, and fix it quickly.
God bless you
Posted on Oct 02, 2012
My Kenmore dryer model #110.9757 is making a loud noise
DRYER MAKES NOISES.
A loose or worn BELT can make funny noises
Or the idler pulley that puts tension on the dryer drum drive belt could be worn out. If the pulley is bad we recommend also replacing the belt.
The glides on drum worn and making metal to metal contact.
The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer makes noise. Replace all of the glides as a set if they are worn out.
CHECK FOR LOOSE BELLOES inside the drum
Sometimes an item can get stuck inbetween the drum and the housing and scrape and grind making funny noises, things like coins, bra wire, nails, hair pins, etc sometimes u can just remove the cabinet and observe by turning the drum by hand or looking for scratch or scrape marks on housing.
The blower:
Clumps of lint, socks, and other small articles of clothing can get past the lint filter and into the blower wheel. If the dryer makes noise, and the noise seems to be at a very fast pace, there might be something caught in the blower wheel. In addition, the blower wheel sleeve might be worn out, allowing the blower wheel to wobble on the motor shaft. If this happens, replace the blower wheel.
The bearings:
The drum bearing supports the rear of the dryer drum. If the dryer makes noise this bearing might be worn out. Replace the bearing if it is worn out. Do not lubricate the bearing, the lubrication will attract lint and dirt and accelerate the wearing process.
The bearings TEST by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The drum rollers or castors:
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers.
Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density LITHIUM BASE gear grease to re oil/grease them.
GOD IS GOOD !!!!
Oct 07, 2014 | Dryers
Tip
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
Your dryer has started making noises. The common noises that can happen are squeaks, grinding, bumping, clicking, or knocking. I will give some of the common reasons why your clothes dryer could be making these noises.
Loud noise from your dryer often is the result of excessive wear of the parts inside of the clothing dryer.
Many dryers use a type of glides or slide for the drum of the dryer to ride on. As the dryer heats then up they wear away. The heat from the inside of the dryer and the friction heat will eventually wear them down. When the glide material is worn away the metal of the drum will start to rub against the metal support behind the glide. Metal on metal will make a very irritating squeaking noise, or grinding noise. If this happens, replace the glides.
Other dryers use a type of wheel or roller to support the rotating drum. These rollers turn on a sort of bearing that in often no more then a pin through a bushing. After a period of time the lubrication will dry up or otherwise go away and the assembly will quickly wear out and start to make a clicking noise, or a knocking noise, or even a grinding noise. In any case these often make a loud noise that can be very annoying. If you have a wheel or roller that is making noises then replace all of them, because the others are soon going to go bad also.
On some dryers there is a rear drum bearing. This center spindle supports the drum instead of rollers, wheels, or glides. This spindle will have a bearing assembly of some type that it spins on. This bearing also may start to squeak, grind, or make a loud noise.
If you have this type of dryer then you can replace this when it goes bad.
Another source of dryer noise is the belt. The belt often will make a different noise that will be more of a knocking or thumping noise. Pieces of the belt may come out of the belt and it still is not broken. As the gaps in the belt run over the idler pulley or the drive pulley the belt will make a thumping or knocking noise.
The idler pulley can also be a source of noise. This also has a bearing in it that will wear out. The noises made from this are similar to the rollers or wheels. If you have these kinds of noises coming from your dryer, you need to figure out what the exact cause of the problem is so that you know you are changing the right parts. Or you can just change all of the rotating parts to make sure that you get the problem fixed. The parts involved are not that expensive to replace.
Finally the blower wheel that moves air through your dryer can become clogged with dirt and lint or just plain wear out. If it is loose or out of balance it will make all kinds of funny noises. Cleaning it may help but replacement is probably the best fix. If it is still noisy after cleaning, then replace it.
This should give you a good overview of the possible causes for noise from your clothes dryer. As you can see there are numerous possibilities or causes for noise. Take your time and eliminate them one by one till the cause is found. Repairing them is not that hard and the parts are not that costly.
http://www.fixya.com/support/r4312805-dryer_maintenance
http://www.fixya.com/support/r3866744-dryer_not_working_dryer_not_drying
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
http://www.fixya.com/support/r4496386-dryer_cord_wiring_dryer_3_wire_or_4_wire
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
on Mar 26, 2010 | Dryers
My 2001 mazda tribute is making a whistle sound, when it's sitting still. Either at a red light, or in park, but wen I'm driving or excelerating it goes away
loose or worn out serpentine belt. just replace and noise should go away. even better buy a can of serpentine belt dressing and spray on belt............noise should be eliminated.
Jun 26, 2014 | Cars & Trucks
How do i replace running belt
basically
Loosen old belt
take out rear roller
undo bolts for deck(both sides is easier to put belt on)
loosen front roller ( opposite side of pulley)
Slide belt on .
Reverse actions and put back together.
Tension belt correctly.
Or call a treadmill repairer
Dec 03, 2013 | RTO Sole F80 Treadmill
Truck has whining noise power steering it goes away once your in 4th gear and cruising
The noise comes from the belt, or from the power steering pump when you move the steering wheel?
If is first option the belt is too loose.
If is the second one, maybe you have low oil in steering pump or the steering pump is faulty.
Please reply.
Nov 23, 2013 | 1998 Dodge Ram 2500 Truck 4WD Front Wheel...
My new sold f80 thumps when it runs, 2 thumps per revolution
Need LUBE or wax, see your owner manual, and Do it right now. use 100% silicones LUBe.
2) Lube the rollers bearint use WD-40 for rollers bearing only.
God bless you
Nov 14, 2012 | RTO Sole F80 Treadmill
My sole treadmil makes noise when changing levels
1) Lube the deck belt, very well, maybe you have WORN deck belt, time to replace, this happen because the lack of maintenance schedule.
2) LUBE the roller bearing TOO.
3) Measure the input voltage motor, if there are voltage , the motor NEED repair.
God bless you
Oct 14, 2012 | RTO Sole F80 Treadmill
May 15, 2012 | RTO Sole F80 Treadmill
It makes a loud knocking noise when running with or without someone on it.
Dear Sir:
I will help you inmediately.
The troubleshooting is Mechanical here is the details:
Treadmill Noise:
1)Front or rear Roller(PULLEY) ASSEMBLY BEARING: Solution: Isolate and replace roller assenbly
2)Drive Belt loosing ......................................................Solution: Adjust tension belt
3)Idler PULLEY.........................................................
Solution: Replace Idler Pulley
4)Belt Seam Need breaking in...................................
Solution:New Belt Replace
Thank you in advance,If you need some extra help reach me, sincerely. blessing.
E.CUADRA
Managua, Nicaragua. C.A.
Sep 13, 2011 | Exercise & Fitness
RTO Sole F80 Treadmill Logo
Top RTO Exercise & Fitness Experts
Jim London
Jim London
Howard
Howard
Jax Planet
Jax Planet
Are you a RTO Exercise and Fitnes Expert? Answer questions, earn points and help others
