Question about Bosch Axxis WFL2090UC
Bosch axxis 2090 motor - Bosch Axxis WFL2090UC
    Sergeant:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 322 Answers
If it's the motor, then you should definitely check the troubleshoter within the manual, you can download it under this article:
Bosch Axxis Washer Manual
Posted on May 27, 2015
3 Suggested Answers
  • 1294 Answers
SOURCE: Part number
Go to> espares.co.uk
or > RepairClinic.com
Posted on Mar 16, 2008
uniman9310
  • 189 Answers
SOURCE: remove bosch axxis 2060 washer motor
Remove the back panel to get to the motor which is at the bottom at the back. Notice two bolts holding the motor into the mount. Remove these two bolts. Notice the back part of the motor is sitting in the mount with black rubber washers. Carefully, pull the motor forward, and this will be abit hard. You can take a flat head screw driver and tap down (in between) on each front plastic washer and the motor will slowly come forward. Becarefull because there is a wire harness still attached to the motor. You have to take wire cutters and clip the placstic band holding the wire harness to the motor. Then grip the harness and wiggle it free. Then remove the single wire also. Putting the belt back is a bit tricky too. Make sure you put back the two black rubber washers and the two front plastic washers.
Posted on Jun 03, 2009
Need instructions to stack Bosch Axxis washer & dryer - 24"
You can find the manuals at this link
http://www.bosch-home.co.uk/customer-service/download-instruction-manuals.html
Dec 22, 2012 | Bosch Axxis WFL 2060 Front Load Washer
I have a 3-year old WFL 2090 Axxis Washing Machine. The door will latch initially, but unlatches during wash cycles and blinking lights come on. It was working fine until the machine was moved. ...
There is likely to be a problem with either the lid/door solenoid/lock or the 'lid/door closed' sensor becoming apparent with the extra movement of washing requiring a service engineer's attention I suggest. Sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jul 15, 2011 | Bosch Axxis WFL 2060 Front Load Washer
Bosch AXXIS dryer # WTA 3510 uc slipping / grinding sound when drum reverses direction. Difficult to turn drum by hand. Belt or motor?
drum baring or rollers if you can get belt off try to turn drum if it still hard to turn you will know its not the motor may be something in blower give it a try
Sep 30, 2010 | Bosch Axxis WTA 3510 Electric Dryer
Bosch Axxis WTA 3510 Electric Dryer. I changed the fuse but it won't turn. Could it be the motor because I don't hear any sound?
there is a switch next to the belt tension arm behind the motor that needs to be reset push the switch needs to be pushed to the right andthis should get your unit running as long as you have power
Sep 16, 2009 | Bosch Axxis WTA 3510 Electric Dryer
We have a WFL 2090 UC Bosch Axxis Front end load washer. When we use the Power Wash option, the clothes are soaking wet when the cycle is completed. Are we supposed to use the Power Temp or Power Boost...
Are you sure that your washer spins? that your pump drains? You should not have this problem. Do you load your laundry properly (too much laundry- should not be more than 3/4 of the diameter of the drum)?
Jun 28, 2009 | Bosch Axxis WFL2090UC
Bosch Axxis WTA 4400 dryer
if you can hear a whirring then the motor is probably spinning, and the problem may just be a broken belt.
If no sound, then probably power not getting to motor via PCB
Apr 09, 2008 | Bosch Axxis WTA4400 Dryers
Part number
Mar 12, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Power to washer is on, but display not responding
maybe door not closing correctly
try a bit of crc in lock to lube otherwise controller shot and brushes worn out in motor
Dec 31, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis WFL2090UC Logo
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
