Question about L.A. Baby Play Yard 89
How can i repair holes in the mesh netting in baby playyard.
There are holes in it from (i guess) mice biting on it when it was in storage
Drywall repair
Just saw your question but no answer. Sorry about the repair on the glass tape. Crack are pretty common with mesh tape, especially if the mesh was covered with premix all purpose compound. Mesh tape should be covered with setting type compounds. More info can be found on the tapebuddy.net how-to manual. They cover the reasons for the different compounds.
Jan 24, 2014 | FibaTape Drywall Crack Repair Tape...
Manual for carter's playard to fold up
All playyards require you to have the bottom of the playyard pulled upward.
There should be a pull on the floor of the playyard/ Lift it up and then and ONLY then
can you lower OR raise the sides. This is a safety feature.
Mar 09, 2011 | Summer Infant Carters Bumble Comfort n...
I need a babytrend playyard mattress but dont know where to get one. Any ideas?
Please check both the links below for various Babytrend Playyard products and check if they deliver
to your country.Hope it helped.
http://www.nextag.com/baby-trend-play-yard/stores-html
http://www.thefind.com/family/browse-baby-trend-playard
Nov 04, 2010 | Toys
I have the hood of an English Pram carriage that the mice found and ate about a 2" hole in the fabric. I do have an accessory made of the same fabric that a "patch could be taken from if needed. Can this...
Hi there is a place in London that does repairs & veleting of prams but I can not think of the name of it, they do an excellent job if you can find out the name, sorry I can't be of anymore help
Jun 13, 2010 | Baby Gear
Don't have manual for fisher price ocean wonders deluxe playyard? How do you keep the sides up?
All pack and play play yards require the bottom floor to lifted like a little volcano in the middle before the side will go up or down. Some have a twist lock others just pull upward. Lift the middle handle up about 6" to 12" and then raise the sides. Once all the sides are up, press the floor flat. Done. Nothing goes up or down until the middle safety is up like a volcano.
Apr 25, 2010 | Fisher Price Deluxe Perfect Support Baby...
Need to assemble a J Mason surround play yard properly
Hi there. I assume it's the same one I have, and I have to say, it's the best! Totally safe...can't see any reason it could be unsafe.
First, underneath the nylon part, you'll find 4 legs in "pockets". Take them out, and (obviously) one goes in each corner. Insert one at a time (I typically do diagonals to keep it upright, but it doesn't matter), making sure to put them through the mesh corners. Simply screw each into the top of the playyard.
I believe there are also some nylon "flaps" that you can re-velcro underneath the playyard (writing this from memory).
Most important is to make sure that the legs are securely screwed in and that they are through the mesh.
Hope that helps.....
May 18, 2009 | J Mason Baby Gear
Eddie bauer playyard
Dorel Juvenile Group is the company you contact for any thing dealing with eddie bauer
Misplacing product instruction manuals can be such a headache. That’s why a downloadable version of many of our instruction manuals are available right here online. Simply fill out the form below and click Search!
link: http://eddiebauer.djgusa.com/instructions/
call for help: (800) 544-1108
(7 a.m. to 6 p.m. EST Monday through Thursday,
and 7 a.m. to 4:30 p.m. EST on Fridays)
Jan 05, 2008 | Eddie Bauer Booster Seat
Mouse inside dishwasher
I have an MDBH945AWW.
I FIXED IT! They are getting in thru the water inlet/vent in the lower bottom left of the dishwasher. Here's how we fixed it:
1. Turn off water to machine if possible. Open the door, remove screws on side and top that hold dishwasher in place. Pull the dishwasher out from under the counter. Remove racks from inside.
2. Remove the sound insulation blanket. Mine was a mouse nest so I threw the thing out. Not going to replace it as the noise increase is minimal.
3. On the left side of the tub outside there is a tube that comes from under and is hooked to a small plastic box with an open top. THIS is the point of entry!
4. Poke a long screwdriver or something down into the box and pop the plastic tension prongs free. Reach into the dishwasher and remove the circular plastic grill.
5. Twist the plastic box to the right or left until the tabs line up and it will pop out of the side of the tub. Remove the tube from the box. The box should now be free.
6. Cut a square of 1/4 hardware mesh cloth (flexible metal grid) and cut a hole to fit over the nipple for the tube. Put mesh over the top of the box, secure in place with really heavy duty tape. Something strong like Gorilla Tape or even metal tape for ducts.... conventional duct tape will not hold after a year or so. I taped all around the edges and sealed it down only leaving the top with the mesh exposed.
7. Put the tube back on and then reinstall the box and then the grill.
8. Take this time to SUPER CLEAN the area under and around the dishwasher. Even the outside of the washer. Mice return to the smell of their poop.
9. Put the washer back in and don't forget the screws as well as turning the water back on.
$5 fix or a $500 new machine... you choose!
Oh yeah, and I'm a girl too...
:D
Tracy
Feb 01, 2007 | Maytag 24 in. MDB5600A Jetclean II...
L.A. Baby Play Yard 89 Logo
247 people viewed this question
Top L.A. Baby Baby Gear Experts
Dorel UK
Dorel UK
Are you a L.A. Baby Baby Gear Expert? Answer questions, earn points and help others
