Question about Pentair White/Gray Legend Platinum Automatic Pool Cleaner - Ll105pm
Hose keeps twisting - Pentair White/Gray Legend Platinum Automatic Pool Cleaner - Ll105pm
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Pentair Master
  • 1,448 Answers
Check to see if all the swivels are rotating if not replace them
Posted on Sep 07, 2014
My kreepy krauly hose is always getting twisted what can I do
ive had great luck with installing a piece of non rusting wire curled up like a spring inside 1st 3foot of hose and keeping floats on last 15 feet of hose
aluminum welding wire works a charm
Oct 04, 2014 | Universal Kreepy Krauly In-Ground Pool...
Need to twist hose to keep power on
you must changed the wire it could be damaged that why the power eventually cut off..
Jun 20, 2008 | Kenmore 22812 Bagged Canister Vacuum
How do i use the hose on featherlite bagless
Hello! To use the hose on your Featherlight follow these simple steps below.
· Cleaner must be in its upright position. Remove lower hose from the side of the cleaner by twisting to the right and then pull off.
· Remove the hose from the tool caddy.
· Slide the tool hose into the lower dirt hose with the notch facing up. Push together and twist to secure.
· Choose any of the handy accessories or use the hose alone. Simply push the attachment firmly onto the end of the wand or hose handle. To remove tool, twist and pull apart gently.
I have also included a link to the instruction manual if needed. Hope this was helpful!
http://dirtdevil.com/file/661/
May 17, 2014 | Dirt Devil Featherlite Bagless Vacuum...
I have three nav vacs and two pools. each pool has a working nav vac and I keep one for a spare. Pool #1- the vac started turning only to the left and in 15 minutes the hose was completely twisted...
This is a common problem with the Navigator. If you grab the part sticking out where the lead hose attaches to the unit, you should be able to turn it fairly easily with your hand. This is the swivel that is supposed to keep the hoses from getting twisted. When you take the unit apart, you will find a large gear plate with teeth that controls the swivel action. All it takes is one leaf or small rock to jam this plate solid and then there is no swivel action and the hose twists. Leslies should have know all about this.
Aug 22, 2011 | Hayward Navigator Pool Cleaner
I have the suncast model of hose reel that u have to manually wind. i tried to put a new hose in but it seems i loaded it wrong. When i went to use it the hose that hangs out that hooks to another would...
The hose on the side that connects to the water supply is not the same hose that goes inside.
The side hose connects to the faucet and the fitting on the hose reel is not supposed to rotate.
The hose that the homeowner installs connects to the adapter on the center of the reel and this goes around when the spool is turning. Beyond that, I don't really understand the question. Hopefully this will give you some information that you can use and then post back.
Gary
Apr 17, 2011 | Garden
New pool cleaner , pool hose just keeps twisting up have laid in sun, but as soon as connected back up it twists
Is the pool cleaners hose actually twisting in the pool or before you put it in? If it is twisting outside of the pool, it might still straighten out when you put it in the water. It it is twisting in the water, you might need to add some additional hose lengths to help it operate smoothly.
Feb 26, 2011 | Hayward Navigator Pool Cleaner
Filter motor leaking water when off and filter chamber only filling half way. Think the motor chamber is sucking in air.
It now won't come off? hmm....I would think that the leak is cause from a worn (or lack of) a black o ring that should be on the stem of the motor. (where you attached the hose).
If it now won't come off, I'm thinking maybe the black O ring has become twisted and wedges in the hose/stem, making it difficult for the hose to come back off.
Keep trying to pull it off. Maybe twist and pull in various directions. It should eventually come off. If it's done that, the black O ring is probably damaged, so you will need a replacement. Once that is replaced, you shouldn't have a leak anymore.
I hope this helps. Good luck!
Jul 29, 2009 | Intex Easy Set 2500 Gph Filter Swimming...
Two hoses that are hard to disconnect. the last two thats holding it together. how to disconnect them on my 1998 chevy suburban
What two hoses?
1.Some sort of cooling system hose? Such as the two that go to the heater core? See how much slack you have in the hose, and cut the hose off, right after the outlet tube it attaches to. If there is enough slack you can remount the hose. Use finesse to remove the stuck piece of hose.
If the example IS the heater core, the heater core is made of brass, or aluminum, (<-Not likely), and you can easily damage it's hose outlet tubes. Careful cut along the side, and try to Not go deep enough, to scratch the outlet tube. Peel back one edge with your fingers, and grab it with a pair of pliers. Try to twist the hose. Again, use finesse. Do not twist so tight that you crimp the outlet tube! Work around the hose on the tube. Eventually you will get it broke loose, where you can twist it off of there.
2.Radiator hose? Same thing applies here as listed above. I HAVE used a flat tip screwdriver to get under the edge of the hose, then worked my way around the hose edge. This helps break it loose from the water pump, or radiator, to where you can twist the hose, and twist it off. Using a flat tip screwdriver in conjunction with a brass or aluminum radiator, is ->NOT SMART!
I used the finesse of a surgeon operating on a heart, took my time, and sweated bullets!
Jul 13, 2009 | 1998 Chevrolet Suburban
Replacing front calipers
It is usually easier to disconnect the flexible brake hoses where they join up to the solid ones first then you can remove them from the caliper end without getting them twisted.
Oct 19, 2008 | 1988 Volvo 740
Pentair White/Gray Legend Platinum Automatic Pool Cleaner - Ll105pm Logo
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
