Question about Interlink Epad II USB with Integrisign Software
Esconfig.cfg file missing - Interlink Epad II USB with Integrisign Software
How to delete all configurations of the S2300?
To delete all the configurations, delete the vrpcfg.cfg file from the flash memory, and then restart the Huawei S2300 switch. The vrpcfg.cfg file cannot be deleted when it is running because it is used as the system file. To delete the file forcibly, perform the following steps:
1. Restart the Huawei S2300 switch and press Ctrl+B to enter the BootROM menu, and then enter the default password huawei.
2. Press Ctrl+Z to enter the hidden menu, and then select option 2 to enter flash memory.
3. Delete the vrpcfg.cfg file from the flash memory, and then restart the device.
More related:
Huawei S2309TP-EI-AC
Huawei S2309TP-EI-DC
Huawei S2309TP-PWR-EI
May 17, 2017 | Cell Phones
Error loading 0004f220429c.cfg
This means the phone cannot find its <mac>.cfg file on the boot server, and does not have one loaded in its own flash memory.
You will need to configure a boot server to host the SIP software, BootROM, and all the config files (these are included in with the SIP software).
You can download these from Polycom's product support page:
http://www.polycom.com/support/voice/soundpoint_ip/soundpoint_ip330_320.html
Aug 18, 2009 | Polycom SoundPoint 330 IP Phone
COD 1.3 build win-x86 Mar 2 2004 -----
For this you have to back up your file and they it can work or you can restore the computer that day when it was good . Just cilcke on Strat then click on programmes and accress and system tools and and at last clike on system restore ...
Jul 11, 2009 | Computers & Internet
Cant' play the game : Rap[ala Pro Fishing (Activision)
A. There is a known fix to the problem that you have experienced and if you follow the instructions below, you will be able to resolve it. What you're going to need to do is find the file called 'Console.cfg'. This is located in your game's install folder (My Computer -> C:\Program Files\ActivisionValue\MagicWand\Rapala\Rapala\Cfg) inside the \Cfg folder. It might be easiest to just do a search from the start menu for 'Console.cfg'. Once you find that file, open it up with notepad or wordpad. You will see a series of lines, the 5th line says: "addvar r_windowed int; r_windowed = 0". You're going to want to change that to: "addvar r_windowed int; r_windowed = 1". Towards the bottom of the file (scroll down) you'll see two lines: "addvar rWaterReflect int; rWaterReflect = 1" and "addvar rWaterRefract int; rWaterRefract = 1" . You're going to want to change those to: "addvar rWaterReflect int; rWaterReflect = 0" and "addvar rWaterRefract int; rWaterRefract = 0". Make sure you save the file and that it asks you to replace it when you save. Then you can start the game. It will not take up the whole screen, but you can fix that by going into the options menu from the main menu and increasing the resolution.
Apr 08, 2009 | Activision Rapala Pro Fishing for Windows
Counter-strike 1.6
see if your mouse has left hand properties
control panel set up mouse OR
If you cannot switch your weapon to the right-hand, please go to your advanced video options and change the renderer to either OpenGL or Direct3D. The software renderer does not support right-handed models.
You can select left or right-handed models by typing the following command into the Console:
  • To use your left-hand: cl_righthand 0
  • To use your right-hand: cl_righthand 1
You may wish to create a userconfig.cfg file with the cl_righthand 0 command if you would like to keep the left-handed setting. Please follow these instructions to create a user.cfg file:
  1. Locate the subfolder in your game folder that holds the config.cfg file
    For example, you can find the config.cfg file for Counter-Strike at [Steam installation directory]\steamapps\[your Steam account name]\counter-strike\cstrike\config.cfg
  2. Create a new text file in that directory called userconfig.cfg
  3. Open the file with Notepad and enter cl_righthand 1 (to use the right-handed model) or cl_righthand 0 (to use the left-handed model)
  4. Save the file
  5. Launch the game to test the user.cfg settings
Jan 21, 2009 | Sierra Online, Inc. Half-Life:...
HE tratado de instalar CALL OF DUTY , Y PIDE ARCHIVO OPENGL
you need to uninstall the game and reinstall and make sure your disk is clean i have had this myself
Nov 16, 2008 | Tablets & eReaders
The RCA Easy Rip Installer has detected that a critiical file is missing : Setup.XML
If you are not prompted to install easyRip, you can find the installer on the device itself or download it at the URL listed below.
If you are getting the message that a critical file is missing, download the latest installer at:
http://voxrightnow.custhelp.com/cgi-bin/voxrightnow.cfg/php/enduser/std_adp.php?p_faqid=2253
Please clarify about the player stuck initializing. What model of player is it? Is the device itself stuck initializing or is a firmware update for your device (would be on your PC) stuck initializing?
Jul 20, 2008 | Audio Players & Recorders
Faulty DFL-700 image - missing FWCore.cfg
Possible problems:
1. IDE Flash device is damaged
2. IDE controller is damaged
2. Firmware is corrupt
Try and download the firmware, and install. You should then get a better idea if the IDE device or controller is bad if it won't install or see the device.
Download Link:
http://www.opendrivers.com/freedownload/232591/d-link-dfl-700-vpn-firewall-firmware-1.33su-download.html
May 05, 2008 | D-Link NetDefend DFL-700 Firewall
Interlink Epad II USB with Integrisign Software Logo
521 people viewed this question
Top Interlink Computers & Internet Experts
David Payne
David Payne
Are you an Interlink Computer and Internet Expert? Answer questions, earn points and help others
