Question about Janome D'cor Excel Pro 5124 Mechanical Sewing Machine
Correct stitch setting on Janome New Home My excel 23X
What is the correct stitch setting on Janome New Home My excel 23X?
bargainbox
  • 1388 Answers
SOURCE: My Janome my excel 23x
Ensure that all is clean and free of lint jams....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tension to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your
projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with
a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to
disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
If you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Posted on Apr 25, 2008
SOURCE: manual for New Home/Janome My Excel 23L
i have a manual for this machine. i can make a copy for you if you are willing to pay for paper and postage. it would be less than $10. i know that it is out of print and had trouble myself when i could not find it. peggy pott4@wyan.org.
Posted on Aug 14, 2009
bargainbox
  • 1388 Answers
SOURCE: Hi, how old would a janome my excel 23x be & being
23X is getting on 20years...the 18W is still current model and an EXCELLENT machine....go for it !
Posted on Nov 13, 2011
bargainbox
  • 1388 Answers
SOURCE: My Janome Excel 23x will not reverse. Any
In base, there is a collar around bottom shaft that is "glued" with old oil & lint...needs to be cleaned with alcohol, then lube.
bargainbox
  • 1388 Answers
SOURCE: I am looking for a service manual for a Janome My
Service manuals are not available to the public, only User Manuals
Posted on Nov 15, 2011
Reverse does not work on my New Home Janome Excel 23L
it will only reverse in straight stitching if it's not reversing at all,I'd return!
Jan 15, 2014 | Janome D'cor Excel Pro 5124 Mechanical...
New home excel 23x
New Home is one of those machines that has multiple families. I have one that was made by White, and yours appears to be made by Janome. I hope that information can be helpful int he future.
Does the slider seem to be bent in any way? If not, the insides of your machine may be full of bits and pieces of fuzz, lint and thread,, thus forcing the lever to the far right position. I have had that happen with mine. It had to be taken apart and cleaned. I hope you get it going soon! There are some independent repair shops that don't charge a king's ransom for machine repair. I hope you are sewing again soon!
Dec 08, 2013 | Sewing Machines
My stitch length varies whilst I'm sewing. Why does this happen and what can I do to prevent this from happening?
Is the stitch selector set to a straight stitch or is it possibily in another stitch pattern but with the width turned down to zero?
If machine is set on a straight stitch but is giving varying stitch length for no reason then it could be that the feed dogs are not functioning correctly, could be out of time with the needle or very worn. Or are you pulling the fabric through rather than letting it feed through. Also check the pressure being delivered by the foot pressure if the machine has a variable adjustment for this. It may have just been turned down for very heavy fabric feeding and needs to be turned up to normal setting again.
Feed dogs can wear - replacement parts may be available. Just remember to search under either Janome or New Home as I believe New Home was bought out by Janome some years ago. Certainly New Home was a common brand in UK in the 80's.
You might find parts on www.sewingpartsonline.com or http://www.sewingparts.co.uk/
I hope that this helps you out.
Apr 25, 2011 | New Home Sewing Machines
Lost my sewing instruction manual when moving house. Can't remember stitch patterns adjustments. Need a new sewing manual for my Janome Decor Excel 11 5024 Thank you
Hi
You can download some partial manuals from the Janome site.
This is for the Janome D'cor Excel Pro 5124:
http://content.janome.com/documents/File/ManualFile/DecorExcelPro5124.pdf
Which should be similar to the ohter model number you mention.
Hope this helps!
Nov 16, 2010 | Janome D'cor Excel Pro 5124 Mechanical...
Janome D'cor Excel Pro 5124 Mechanical Sewing Machine Logo
192 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
