Question about Uhu SAUNDERS CERVICAL HOMETRAC DELUXE
No pressure in pump model 100399
No pressure in pump! Help!
Changed fuel pump oil pressure keeps going to 0 put in new oil sensor same oil pressure no problem before pump
Jeff, you or somebody else will have to hook up a external oil pressure Gage and verify oil pressure OK, before you have a catastrophic engine failure.
Feb 29, 2016 | Cars & Trucks
Water won't go through pressure washer, even with the water on and the pressure hose off the machine, no water comes through the pressure washer.
Back behind the water outlet tube are components that have small orifices that become clogged from lime, clay, mud and other contaminants. Mud and clay mostly from well water. I've had over 60 pressure washers in the past three years. I bought them because they didn't work and I would repair the pumps unless they were cracked, then I would buy new pumps to install. It would help to know the pump model details or even the make. Faip, Himore, Annovi Reverberi etc...or even the pressure washer model number as long as it is the original pump. If it is an Annovi Reverberi then it could also be a bad shutter valve. Now there is a revised design of the shutter valve. The part number for that valve is AR42497.
May 20, 2015 | Garden
Water not heating, low pressure pump needs reset. How?
When you say low pressure pump and high-pressure pump...? Are you referring to low-speed water flow, and high-speed/Jets, waterflow?
do you have a one pump system with a two speed single pump? Or do you have two separate pumps? Is one pump, which is normal, a two speed pump? Answers to these questions, will help us, help you!
make and model?
Mar 07, 2015 | Pool & Spa
Portercable Pressure Washer Model PCH2401
when the trigger for the wand is not pulled , there is a pressure relief valve that bypasses the water in the pump and so there is no pressure until the trigger is pulled again.
with the pump getting hot and not being able to pull the motor to restart, it indicates that that pressure relief valve has jammed ( faulty ) and the pump is running at full pressure all the time
That will heat the pump and stop the engine from restarting
That valve is where I would start looking for a problem
Apr 25, 2017 | Porter Cable Garden
Pressure switch no longer making contact
First try to clean the contact points, maybe it's help
Mar 26, 2013 | Flotec Pressure Switch 40/60 TC2153
Where can I get a rebuild kit for pump?model XR-2600.
remove the pump and throw it away. Buy a better designed pump on eBay. just search your pressure washer model number or the obsolete rebuild kit part number a14292 you'll find the better pump.
Apr 03, 2012 | Honda Black Max 2600 PSI Pressure Washer
Need head pressure on 1hp shallow well pump SDTS10
reducing the pipe size helps build head pressure.
Mar 18, 2010 | Plumbing
How can I order a part for Saunders Cervical Hometrac Deluxe?
I called the manufacturer and spoke with their repair department. The O-ring is in the mail...gratis.
Dec 01, 2009 | Uhu SAUNDERS CERVICAL HOMETRAC DELUXE
Model #1578961A. The pump pressure cuts in and
usually caused by a supply problem, make sure you have enough water comming into the pump and that the screen in the connection is clean
Nov 15, 2009 | Northstar Pressure Washer 3000 PSI
I need a manual for a 83-84 ford f150 pick up, as i need to posibbly replace the fuel pump , where can i d/l a free manual ?
Ford Pick-Ups/Bronco 1976-1986 Repair Guide
Electric Fuel Pump - Removal & Installation
Two electric pumps are used on fuel injected models; a low pressure boost pump mounted in the fuel tank and a high pressure pump mounted on the vehicle frame. Some models equipped with the 8-460 (7.5L) carbureted engines use a single low pressure pump mounted in the fuel tank.On injected models the low pressure pump is used to provide pressurized fuel to the inlet of the high pressure pump and helps prevent noise and heating problems. The externally mounted high pressure pump is capable of supplying 15.9 gallons of fuel an hour. System pressure is controlled by a pressure regulator mounted on the engine.
With internal fuel tank mounted pumps tank removal is required when servicing the pump. Frame mounted models can be accessed from under the vehicle. Prior to servicing release system pressure (see Fuel Supply Manifold details). Disconnect the negative battery cable prior to pump removal.
More details can find in autozone.com (free register); select the year, make, model and engine.
I hope help you with this (remember rated this help) Good luck.
Oct 16, 2009 | 1983 Ford F150
Uhu SAUNDERS CERVICAL HOMETRAC DELUXE Logo
Top Uhu Luggage & Travel Experts
Dave braun
Dave braun
Tom Chichester
Bobby Lewis
Bobby Lewis
Are you an Uhu Luggage and Travel Expert? Answer questions, earn points and help others
