Question about Eltax Atomic A-8.2 Subwoofer
Loud boom when going in standby mode.
Every time my Eltax Atomic A-8.2 has been idle for app. 10 mins it gives a loud "BOOM" as if it exploded. I assume this happens when it turns to standby mode. It still works perfectly fine, but it is VERY annoying. Please help!
  • sonnyboy16 May 20, 2009
    Tried different volume settings. It turns out, it starts making small booms at volume level 5 and loud booms at 7. Didn't turn it up any higher. Problem solved, thanks buddy!
  • 92 Answers
I would check your sub connection also make sure the volume isnt set to high. sometimes unplugging the power and cables also helps
Posted on May 20, 2009
Loud boom and burning smell in microwave
Is there any holes burnt into the liner inside the micro wave.? Or burn spots showing.? If there is thow it out. It is not safe to be useing it.It could start on fire. That problem is from when they are not clean out once in a while. End food is burn,t onto the interior liner end grease end oil,
Oct 22, 2012 | Sharp KB6001NS 24 Inch Microwave Drawer...
Fading picture
Most likely power supply within television.If its a big screen it might be worth a electronic technician to look at it.Get a quote
Sep 29, 2012 | LG 42LC2D 42 in. LCD HDTV
Action is a bit high. Everyone is saying the DC16RGTE guitar sounds great and gives good volume. I found the one I have is not loud and it has too much boom. Is there a problem with this guitar?
Make sure the guitar CANNOT "HEAR" the amp you are using. Local regeneration (feedback below the level to sustain full feedback) will give a boom sound like in a cave. If you get near enough to the amp for feedback to build up, you can actually see the string vibrating and building up. The loudness has much to do with the amp you connect this too and the settings
Aug 30, 2011 | CF Martin DC16RGTE Aura Drednought Cutaway...
Kenmore gas range, loud boom sound when igniting,how to use clean
dont clean
you have a weak ignitor
and this is very bad
it should be replaced quickly
Sep 30, 2009 | Kenmore Kitchen Ranges
THUNDER 5601 WHEN VEHICLE TURNED ON, SUBS BOOM, THEN WORKS OK. ALSO WHEN RADIO TURNED OFF
If the amp produces no boom with no signal input cables connected, I'd suggest using an LOC.
Let me know if you have any other questions.
Sep 30, 2008 | MTX Thunder 3401 Car Audio Amplifier
BOOM BOOM BOOM
The Bose engineers in their "infinite" wisdom developed a $300 radio with no, that is NO, tone control. This means the only way to tune bass response is to reposition the Wave radio itself. If you put it in a corner of a room, it will produce the most bass. If it is only against one wall, not so much bass. To reduce bass response to a minimum, you would have to suspend the device from a wire in the middle of the room. Good luck. I would never buy a radio without a tone control; I literally inherited by Bose Wave Radio and use external speakers which do have tone controls.
Jun 10, 2008 | Bose Wave Radio
Systems shuts off if sound gets too loud.
Yes, i had this same problem. If it was too loud, at level 37+, any loud boom would shut down the subwoofer, subsequently shutting down the speakers. As such, I figured it might have been the 8 pin dim cable, but that wasn't it. What solved the problem was lowerin the BASS level. Not the level on the subwoofer, but the actual BASS level. I had it at +10 (the max) and it was too much for the system to handle. I don't think I ever had it like that so I'm assuming someone, maybe my daughters, moved the settings. But anyway, moving the bass level back down to either 0 or +3 at most maintains the "boom" effect of the subwoofer minus the shutting off of the system.
Oct 20, 2006 | JVC TH-C60 System
Eltax Atomic A-8.2 Subwoofer Logo
402 people viewed this question
Top Eltax Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Eltax Audio Player and Recorder Expert? Answer questions, earn points and help others
