Question about Numark ICDMIX3 iCDMIX3
No disc reading - Numark ICDMIX3 iCDMIX3
Dvd player reads "no disc" when I put disc in
Are the discs copy's or originals if there copy's some systems will not read them, if there originals then clean disc on laser eye with a cleaner disc
Mar 07, 2014 | Sony BDP-S350 Blu-ray Disc / DVD Player,...
Tip
How to resolve Xbox 360 disc read errors. Xbox will not play disc.
Is your xbox360 having trouble reading disc? In this guide I will provide some common solutions to help you fix your disc read issues.
1)Remove any memory devices or usb flash drives.
2)If the disc you are using is excessively scratched, this can cause the xbox to have trouble reading the disc. You can use a damp soft cloth to try and clean the disc. Grab the disc by the edges and using a soft damp cloth lightly wipe the disc from the center going outward.
3)Try removing your Xbox hard drive and then play a disc. Turn off the console. Locate the hard drive on the top of your system(depending on how you have it positioned). Press the release button on the hard drive.
If your system can read disc without the hard drive attached then you may need to replace the drive.
4)Clear the Xbox360 cache. Clearing the cache may remove updates to certain games. Keep this in mind.
Go to System Settings in the My Xbox menu. Select Memory, highlight your storage device and select Clear System Cache. Try and play the disc.
If after the above steps you are still having trouble. You may want to contact Microsoft Xbox live support to have your system serviced. You can find the support information in the link below,
Xbox Support
Regards,
G33k
Visit the links below for other technical articles
Connect your Nintendo Wii to the internet
Connect your Xbox 370 to the internet
Connect your Nintendo DSi to the internet
Connect your PlayStation 3 to the internet
How to access Windows 7 God Mode
Tips to clean and speed up your computer
How to configure a wired/wireless home connection
How to access facebook when it is blocked at school
Extensive list of device driver links for common electronic devices
Keywords
xbox 360 disc read errors, xbox 360 disc read, 360 disc read errors, xbox disc read issues, xbox 360 disc read issue, xbox 360 scratched disc, xbox360 disc not playing, xbox360 cant play disc, xbox360 disc will not play
on May 14, 2011 | Microsoft Xbox 360 Console
Disc inserted but NO DISK message appears
Try other discs to see if its still working properly...most likely the recording on the disc is not burnt properly or there's something wrong with the disc, (ie, scratched or surface dirt etc) or the DVD player just can't read the disc...for example can it read the type of disc(does it read dvd+r or dvd-r, or both?--- if i remember rightly)..... I've had discs that have had bad recordings but can still be read if placed into tray a particular way around... randomly try different positions, also cleaning disc as you go...depending on how desperately you want it to read the disc...could also be bad disc batch... there could be many reasons...
Sep 22, 2012 | Televison & Video
Getting disc read error
THere are a number of problems that can cause a disc read error. The lens can be damaged or very dirty. The motor that moves the les could be stuck or damaged. The disc could be dirty or scratched. Or the disc format might not be able to be read by the player. Do you try more than one disc? Are you trying different types of discs? like store boght discs and recordable discs. Some players wont read mp3 or cd-rw discs.
Jun 20, 2010 | Alpine CDA-7894 CD Player
No disc
has it been reading discs previously? If it has been reading discs previously, then it means the lens (laser) of your player is weak and that's why it cannot read disc.
You need to change the lens for it to be able to read disc again.
Good luck.
Apr 15, 2010 | Panasonic DMP-BD30K Blu-Ray Player
Mariokart disc could not be read. manual said
Did it ever work? Or did you just get the disc?
If the game never worked, you may have gotten a defective game disc. Take it back to where you purchased it and they will exchange it.
Nov 11, 2009 | Nintendo Mario Kart (Wii) for Wii
Wii can"t read disc
If Wii gives can't read disc, so first step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide,that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide
Dec 14, 2008 | Nintendo Wii Console
How to download unreadable disc for lexmark printer
The printer install disc may be faulty or your disc drive is faulty.
Insert the disc into a different computer, if it can be read then the problem is your disc drive.
If it is your disc drive, turn off your computer, open your computer and remove and reconnect the power and data cables on the "faulty" drive, switch on your computer, let it boot up and install the printer disc.
If it still cannot read the disc then you need to replace the faulty disc drive with a new one.
Sep 24, 2008 | Lexmark Office Equipment & Supplies
Unable to read wii discs
I had the same problem, I take it you have a modded wii(chipped), if you use a backup disc it is of a lower quality then original discs, the wii gets read errors without you noticing and tries to read those disc areas again sometimes suceeding and the gaming goes on, sometimes it fails, and a disc read error occurs. Over time the dvd assembly will take some damage it will loose it rigidity it once had and the wii stops reading discs. The problem gets worse if you have standing up, so first thing si to flip it down and try. Otherwise you (or someone you trust) will have to open the wii and adjust the lens sled so it wont flap as much up and down. Hope this helps..
Oct 01, 2007 | Nintendo Wii Console
Numark ICDMIX3 iCDMIX3 Logo
20 people viewed this question
Top Numark Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Numark Audio Player and Recorder Expert? Answer questions, earn points and help others
